View Poll Results: Do you think to use it ?
Voters
6. You may not vote on this poll
  • yes
    5 83.33%
  • no
    1 16.67%
Page 1 of 3 123 LastLast
Results 1 to 10 of 23
Thread: Elevation screen for RR
    Raw Wave pierrotm777's Avatar
    May 2008
    Bordeaux, France
    Smile Elevation screen for RR
    This new little script give you the slope of the road where you are.
    It's cool in 4x4 or when you are in mountain !
    The screen is just for to give you an example:
    I need to test it in real situation (i have not CarPc).
    If you use it , please say me if this script run well in metre and in miles!!!
    History:
    V0.5 12/11/2010
    If your altitude is negative, the up or down indicator give the good picture.
    The arrows pictures are on the good skin folder.
    V0.4 09/09/2010
    SAPI Vocal Alarm Option
    (This version is already compatible with the v0.3d WEBRADIO script that add a WEBRADIOTRACKNAME label)
    V0.3 08/09/2010
    Now the vertical slider give you the slope between +45° à -45°
    (Thanks to JohnWPB for this good idea and thanks to the french autoit forum for his help!)
    V0.2 07/09/2010
    Can use miles or metre units( heu, i think !)
    V0.1 01/09/2010
    First version
    Attached Files Attached Files
    Mod - all of it.
    Jul 2007
    Buena Park, So Cali
    Where can I download? Where do I install the script? Where does the script get the info? GPS? Sensor?
    Thanks. This is cool.
    CAR: 2007 G35 Sport Coupe 5AT
    HARDWARE: Dell D630 w/ dock, internal 80G HD, internal 320G HD, Verizon Wireless Card, iBlue GM-2 GPS w/iGuidance, OBDPros w/DashCommand, Visteon HD Radio w/ Home Made Cable, Current Version of RR w/ DFX Skin. My Install.
    May 2008
    Bordeaux, France
    Smile
    Quote Originally Posted by drewbp View Post
    Thanks,
    The first post is updated and you can to test it now.
    The gps info are got directly from RR.
    May 2008
    Bordeaux, France
    First post is updated with the slider for the skin.
    Mod - all of it.
    Jul 2007
    Buena Park, So Cali
    Also elevation here in the U.S. means distance above sea level. Grade would be the slope of the hill you are on. I also only have it on my test computer, but will check it this weekend.
    Super Moderator
    JohnWPB's Avatar
    Sep 2005
    West Palm Beach, Florida
    Blog Entries
    1
    This looks promising, and a nice bit of information to have available.
    I have found a few problems though, sorry.....
    - The GPSSIGNAL sliders are missing from the .zip file
    - The images in the top right are also missing from the .zip
    - While sitting still (GPS hooked to my desktop PC) I am getting really crazy readings for the % of incline. (2627% incline?! haha) It look like it needs some sort of error trap to only read between 0 and 90 degrees. BTW, I have 9 satellites locked when I took the screen capture.
    On another note, I think it would be better to use the RR sliders instead of using the old style individual image ones. This way the slider bar would move up and down.
    Oh, and Yes, that 37 feet altitude is correct, as I live in South Florida, and it is pretty much FLAT here
    My Fiero Build Thread
    May 2008
    Bordeaux, France
    It's normal , I am not solved the calculation in miles.
    The script run well only in metre , but if think to work on the miles option as soon as possible .
    May 2008
    Bordeaux, France
    Smile
    This new version run in miles as in metre .
    With certainly some bugs !
    I have tried to add, (just for test )some swf dfx4 files, but all don't run , and i don't know why.
    May 2008
    Bordeaux, France
    Smile
    Quote Originally Posted by JohnWPB View Post
    What is the good format please?
    Do you have an example ?
    Super Moderator
    JohnWPB's Avatar
    Sep 2005
    Blog Entries
    1
    It is actually pretty easy, being you are using a script to calculate the slider bars already.
    Put this line of code in your skin:
    S,725,77,70,447,720,77,60,447,v,01,"Bar.png",60,"$ ElevSlider$",
    Now, in your script you just need to set the limit of the $ElevSlider$ variable to be between 0 and 65535. For instance 32767 would be the very center, or the middle, of the slider.
    Being there are 20 steps of this slider, the formula to calculate it would be
    $ElevPosition = ($YourNumber * 65535)/20
    rr.Execute ("SetVar;ElevSlider;" & ElevPosition)
    Where your number is between 1 and 20. It is best to round the number up to 1 so there is no division or multiplication by 0.
    To test it to see how it works, its best to put that line in a skin, and in the skin tool fire the command SetVar;ElevSlider;32650. By changing that number you will see the slider move in the skin. Once you see that, it should be fairly simple to figure it out
  1. Replies: 14
    Last Post: 09-11-2008, 03:14 PM
  2. Constantly removing the screen 7" lilliput advice
    By steveb in forum LCD/Display
    Last Post: 04-17-2007, 10:56 AM
  3. Cracked Touch Screen!
    By bmather9 in forum LCD/Display
    Last Post: 04-17-2007, 04:31 AM
  4. FAQ: LCD Technologies
    By dontpntpool in forum LCD/Display
    Last Post: 03-15-2007, 12:20 AM
  5. Replies: 4
    Last Post: 01-26-2006, 02:35 AM
