Results 1 to 6 of 6
Thread: Sygic and senkey command
    Raw Wave pierrotm777's Avatar
    May 2008
    Bordeaux, France
    Smile Sygic and senkey command
    I try to create a RR dll that interface Sygic , Ig4 , Gmpc , AutoMapa with Google Maps .
    But for now i look for the key that control Sygic
    I have found ,f1,left,right,up,down,enter and all numbers .
    So i can to use for to go to the menu:
    Code:
    ACTIVATE;Sygic Drive||SENDKEY;{f1}
    A KeyMap.ini exist into the sygic folder that configure the control by keys.
    But into the menu 'Enter Gps Position' , on the right bottom exist a 'done' button.
    Who know what key command i can send for to simulate this button?
    Thanks for all help
    RoadRunner Mastermind
    guino's Avatar
    Nov 2004
    Toronto, Canada
    I would assume ENTER should be it.. I'm assuming that if you ENTER does not work, you have pressed the "done" button with the mouse and verified that it works ? in which case, you'd have to simulate a mouse button click there.
    Ride Runner RR's Myspace
    May 2008
    Bordeaux, France
    If i don't found the sendkey command , my other idea is to simulate a mouse click on the coordinates , x=780 and y=520 by example , with the dll.
    How can i do that easly please in vb6.
    May 2008
    Bordeaux, France
    OOps thanks Guino, for your help that i haven't seen.
    If you can to help me with an example .
    I have found this class but i don't know how to use it .
    Code:
    Option Explicit
    Private Type POINTAPI
       x As Long
       y As Long
    End Type
    Private Declare Sub mouse_event Lib "user32" ( _
       ByVal dwFlags As Long, _
       ByVal dx As Long, ByVal dy As Long, _
       ByVal cButtons As Long, _
       ByVal dwExtraInfo As Long)
    Private Const MOUSEEVENTF_ABSOLUTE = &H8000 '  absolute move
    Private Const MOUSEEVENTF_LEFTDOWN = &H2 '  left button down
    Private Const MOUSEEVENTF_LEFTUP = &H4 '  left button up
    Private Const MOUSEEVENTF_MIDDLEDOWN = &H20 '  middle button down
    Private Const MOUSEEVENTF_MIDDLEUP = &H40 '  middle button up
    Private Const MOUSEEVENTF_MOVE = &H1 '  mouse move
    Private Const MOUSEEVENTF_RIGHTDOWN = &H8 '  right button down
    Private Const MOUSEEVENTF_RIGHTUP = &H10 '  right button up
    Private Declare Function GetCursorPos Lib "user32" (lpPoint As POINTAPI) As Long
    Public Property Get x() As Long
    Dim tP As POINTAPI
       GetCursorPos tP
       x = tP.x
    End Property
    Public Property Get y() As Long
    Dim tP As POINTAPI
       GetCursorPos tP
       y = tP.y
    End Property
    Public Property Let x(ByVal x As Long)
       MoveTo x, y ' y from property get
    End Property
    Public Property Let y(ByVal y As Long)
       MoveTo x, y ' x from property get
    End Property
    Public Sub MoveTo(ByVal x As Long, ByVal y As Long)
    Dim xl As Double
    Dim yl As Double
    Dim xMax As Long
    Dim yMax As Long
       ' mouse_event ABSOLUTE coords run from 0 to 65535:
       xMax = Screen.Width \ Screen.TwipsPerPixelX
       yMax = Screen.Height \ Screen.TwipsPerPixelY
       xl = x * 65535 / xMax
       yl = y * 65535 / yMax
       ' Move the mouse:
       mouse_event MOUSEEVENTF_MOVE Or MOUSEEVENTF_ABSOLUTE, xl, yl, 0, 0
    End Sub
    Public Sub Click(Optional ByVal eButton As MouseButtonConstants = vbLeftButton)
    Dim lFlagDown As Long
    Dim lFlagUp As Long
       Select Case eButton
       Case vbRightButton
          lFlagDown = MOUSEEVENTF_RIGHTDOWN
          lFlagUp = MOUSEEVENTF_RIGHTUP
       Case vbMiddleButton
          lFlagDown = MOUSEEVENTF_MIDDLEDOWN
          lFlagUp = MOUSEEVENTF_MIDDLEUP
       Case Else
          lFlagDown = MOUSEEVENTF_LEFTDOWN
          lFlagUp = MOUSEEVENTF_LEFTUP
       End Select
       ' A click = down then up
       mouse_event lFlagDown Or MOUSEEVENTF_ABSOLUTE, 0, 0, 0, 0
       mouse_event lFlagUp Or MOUSEEVENTF_ABSOLUTE, 0, 0, 0, 0
    End Sub
    This class are named 'CMouse'
    Then i know that i do to write :
    Code:
    Private m_cMouse As CMouse
    But where on my script
    and where needed call the click
    use 'm_cMouse.Click' but where also
    Thanks for your help
    May 2008
    Bordeaux, France
    Ok,
    I have found a solution !
    I have found this module (.bas)
    Code:
    Dim iniFile As New ClsIniFile
    Dim tmpFile As New ClsIniFile
    Dim Longitude As String
    Dim Latitude As String
    Public Declare Function GetAsyncKeyState Lib "user32" (ByVal vKey As Long) As Integer
    Public Declare Sub mouse_event Lib "user32.dll" (ByVal dwFlags As Long, ByVal dx As Long, ByVal dy As Long, ByVal cButtons As Long, ByVal dwExtraInfo As Long)
    Public Const MOUSEEVENTF_LEFTDOWN = &H2
    Public Const MOUSEEVENTF_LEFTUP = &H4
    Public Sub Mouse_LeftClick(xIni, yIni)
        Dim x As Integer
        Dim y As Integer
        x = xIni ' where to move and click the mouse
        y = yIni
    mouse_event MOUSEEVENTF_ABSOLUTE, x, y, 0, 0
    mouse_event MOUSEEVENTF_LEFTDOWN, x, y, 0, 0
    mouse_event MOUSEEVENTF_LEFTUP, x, y, 0, 0
    End Sub
    and i call this module like that,
    Code:
    Public Function ProcessCommand(CMD As String, frm As Object) As Integer
                iniFile.FileName = App.Path & "/NavCMD.ini"
                tmpFile.FileName = App.Path & "/NavCMD.tmp"
        Select Case LCase(CMD)
            Case "sygicmenu" 'acces au menu: "Menu principal"
                iniFile.ApplicationKey = "SYGIC"
                RRSDK.Execute (iniFile.GetValue("SYGICMENU", ""))
                ProcessCommand = 2
            Case "sygicdefposgps" 'acces au menu: "Définir Position GPS"
                tmpFile.ApplicationKey = "GPS COORDINATES"
                RRSDK.Execute (iniFile.GetValue("SYGICDEFPOSGPS", "") & "||ACTIVATE;Sygic DRIVE||SENDKEY;" & tmpFile.GetValue("Longitude", ""))
                Sleep 500
                iniFile.ApplicationKey = "MOUSECLICK"
                Call Mouse_LeftClick(iniFile.GetValue("XMOUSE", ""), iniFile.GetValue("YMOUSE", "")) ' click mouse on XMOUSE and YMOUSE position
                Sleep 500
                RRSDK.Execute ("ACTIVATE;Sygic DRIVE||SENDKEY;" & tmpFile.GetValue("Latitude", ""))
                ProcessCommand = 2
        End Select
    End Function
    With the 'sygicdefposgps', i send the latitude and after the longitude found into NavCMD.tmp file .
    NavCMD.ini
    Code:
    [SYGIC]
    SYGICMENU="ACTIVATE;Sygic Drive||SENDKEY;{F1}"
    SYGICDEFPOSGPS="ACTIVATE;Sygic Drive||SENDKEY;{F1}{ENTER}{RIGHT}{RIGHT}{RIGHT}{RIGHT}{ENTER}"
    [MOUSECLICK]
    XMOUSE=780
    yMOUSE=530
    NavCMD.tmp
    Code:
    [GPS COORDINATES]
    Longitude = 2.318459
    Latitude = 48.863064
    The mouse click well on the good position, but i have some issue that i don't understand,
    but the command is send sevral times
    guino's Avatar
    Nov 2004
    Toronto, Canada
    Either post or email me your sources and I can take a look at it for you.
    Your code seems very close to it.. if the command is being sent several times it may be some sort of focus/event issue.. I would try the following change:
    Instead of:
    Try:
    mouse_event MOUSEEVENTF_ABSOLUTE+MOUSEEVENTF_MOVE, x, y, 0, 0
    mouse_event MOUSEEVENTF_LEFTDOWN, 0, 0, 0, 0
    mouse_event MOUSEEVENTF_LEFTUP, 0, 0, 0, 0
    Or:
    mouse_event MOUSEEVENTF_ABSOLUTE+MOUSEEVENTF_LEFTDOWN, x, y, 0, 0
    mouse_event MOUSEEVENTF_ABSOLUTE+MOUSEEVENTF_LEFTUP, x, y, 0, 0
    Or even:
    mouse_event MOUSEEVENTF_ABSOLUTE+MOUSEEVENTF_LEFTDOWN+MOUSEEVE NTF_LEFTUP, x, y, 0, 0
    Just a few suggestions.. some applications may act differently upon the above calls.
