Results 1 to 7 of 7
Thread: plugin confusions?
    Jul 2010
    plugin confusions?
    I started looking through some plugins to extend the functionality of the install of RR. I thought that it would be kind of self explanatory but figured out that it's not very well documented, or I can't find anything on it and tried searching forums/faqs to no avail? I figured I would try the Wifiman and bassrr plugins to see how they worked.
    The documentation would appear to be non-existant, or it seems like it to me. I followed the readme, coping the folder to plugins and the skins to inside the default skins folder (carwings). I tried adding stuff to the exec.tbl and skins.tbl files and nothing made a difference.
    Even registering the .dll's didn't help. Nothing besides the normal weather and skintool would show up in the plugin manager. Changing the RR.ini to use the new bass.dll audio library had no effect either.
    I don't want to sound like a pain if there is a simple plugin explanation on installs somewhere, but suffice I couldn't find in in any of the plugin subforums or RR faq forums I searched through, but a little help would be greatly appreciated.
    Confusion Master
    Enforcer's Avatar
    Sep 2003
    This illustrates how to add the button code to the carwings skin.
    http://www.mp3car.com/vbulletin/atta...utton-menu.pdf
    As far as installing a plugin goes, they should be stored in a subfolder of the RR\plugins folder
    the folder name should be the same as the DLL name.
    THE EXPERIMENTER
    carputer1's Avatar
    Sep 2007
    UK,Surrey
    Bassrr comes with its own WORKING test skin ,
    drop the bassrr plugin folder into Riderunner\plugins
    run register.bat this will reg all the needed dll for you
    then take the default skin and drop that into your skin folder
    open rr config
    set bassrr as your player in Music section
    set Carwings_bass as the skin in the skins section ,
    save & close rrconfig
    and run Ruderunner.exe
    this should give you the Carwings_Bass skin loading and will do a few checks on 1st start......like build a database for you etc
    i'm in the middle of doing some sort of help on my website forum , for Bassrr & the up comming Genesis skin ,, so i would pop over to the site forum and keep a eye on it ,,
    link in sig below
    Thankyou for chooseing Bass hope to get you working to Enjoy its features
    Riderunner / Genesis
    Wifiman_NET:Version 1.0.0
    Mar 2009
    Question
    Ok I understand how to add the plugin for example, rrvechiclemaintenance and see it listed in the pluggins manager in Carwings. I also understand, sort of, how to add or modify the button. What I don't understand is how to add the skin for rrvechiclemaintenance. The skin is in its own folder call "RRVM skin". Do I add this folder under C:\Program Files\RideRunner\Skins or do I add it to C:\Programs Files\RideRunner\Skins\Carwings_Dynamic_Lite? If the answer is to put it under C:\Programs Files\RideRunner\Skins\Carwings_Dynamic_Lite do I leave it in its own folder so that it would look like this, C:\Programs Files\RideRunner\Skins\Carwings_Dynamic_Lite\RRVM skin" or do I just copy the contents directly into the Carwings_Dynamic_Lite folder which then overwrites some of the files contained in their because they have the same names. This is where I am confused. To add to this confusion, if the answer is to keep it in its own folder how do I tell the button in ExecTBL.ini, "MyApp21","WIFIMAN" to point to a subfolder? Sorry for the long post, hopefully it makes some sense.
    THE EXPERIMENTER
    carputer1's Avatar
    Sep 2007
    UK,Surrey
    i think for RRvm thats a working test skin to , check the folder for exetbl.ini , skin.ini, general.ini if these are present in that folder then its a working test skin , you will only need to port over some of the skin files to your main skin , 9 times out of 10 , the skin files relevant to the plugin , are named , like rrvm_osk.skin etc , just move over those skin files.
    if you have further issues , i can break the skin files down , to the 1's needed for your main skin , which ever that is...
    Mar 2009
    thank you for the quick response, that answered my question.
  1. DigitalFX 4.0
    By JohnWPB in forum RR Skins No Longer Supported
    Last Post: 03-27-2014, 05:48 PM
  2. Build on Mandriva 2010
    By yoshihiro in forum RevFE
    Last Post: 02-23-2010, 06:50 AM
  3. music defaults to first song on open
    By soundman98 in forum Road Runner
    Last Post: 11-23-2009, 03:36 AM
  4. Replies: 13
    Last Post: 05-28-2009, 04:18 PM
  5. pc reboot on sd startup
    By duanes7 in forum StreetDeck
    Last Post: 12-14-2007, 09:55 AM
