Results 1 to 10 of 19
Thread: bluetooth phone
    Nov 2007
    bluetooth phone
    I am using a belkin dongle and how do u set up the configuration for it to work.
    getting frustrated.
    rr w/ built in phone control
    phone is htc evo
    thx drew
    MGD
    MGD is offline
    MGD's Avatar
    Feb 2005
    Los Angeles
    You need BlueSoleil in order for it to work with Ride Runner.
    I have an HTC Hero and it works great.
    Nov 2007
    Do i.configure it in the bluesoil program
    Nov 2007
    I must be the worst at this, cant figure it out. Dl the trial version and still cant figure out what to change so it connects.
    drew
    MGD
    MGD is offline
    MGD's Avatar
    Feb 2005
    Los Angeles
    You can't use RR build in Phone Control as it is absolete. You need to pair your phone in bluesoleil once, then it connects every time. Download .net Bluetooth Phone Control from the released plug in section (.net Bluetooth Mobilephone Plugin), run the installer and select bluetooth phone, then you ready for use in RR.
    Nov 2007
    I am running ur omega skin, after I install the plugin and go through the process. While in your skin and select phone it says trying to connect please wait
    Nov 2007
    I got it to work, but my contacts dont show up. changed the menu.skin txt file to read "load;mobilephone.skin;" copied all the files from carwings into the omega folder and it connects to phone. How do I get my contacts to show up when calling and is there a way to link the phone book?
    MGD
    MGD is offline
    MGD's Avatar
    Feb 2005
    Los Angeles
    Omega
    The OLD Omega skin used FreePhone, which is no longer supported.
    I am working on my new ONS skin, ONS=Only Nessesary Stuff.
    It uses the new Plugin and works like a charm, thanks to Lambosprit.
    It looks like this now.......
    Nov 2007
    u always do great work, looks mint
    lambosprit's Avatar
    Sep 2006
    UK
    Quote Originally Posted by diggla View Post
    You can't link to your phones phone book but you can put contacts into a text file called mobilephone_PC.txt. This allows you to call contacts fromm RR but only from this file.
    If an incomming number exists in you PhotoPath (see ini file) then that photo can be displayed in a skin using a special indicator. for example I01,340,66,120,150,"FILE;$mobilephone_photopath$"
