Results 1 to 5 of 5
Thread: Need help with a vb6 plugin
    Raw Wave pierrotm777's Avatar
    May 2008
    Bordeaux, France
    Hello all,
    I want to made a RR command that can do a left mouse click !
    I should like to have a command as:
    Code:
    clickleft;1;750;719
    where ,
    1 is the left mouse button
    750 the x position
    719 the y position
    Actually, i have a command like that who run very well but who is fixe !
    Code:
            Case "clickleft" 'click left mouse button (1) on 750x519
                Call MouseButtonDownXY(1, 750, 519)
                Call MouseButtonClick(1)
                ProcessCommand = 2
    How can i do that please ?
    May 2008
    Bordeaux, France
    Smile
    I have tried to add these lines after the end select but without succes:
    Code:
        If Left(LCase(CMD), 10) = "clickleft;" Then
            If Len(CMD) > 11 And InStr(CMD, ";") Then
                CmdArray = Split(CMD, ";")
                CMD = "clickleft;" & CmdArray(1) & ";" & CmdArray(2)
                ProcessCommand = 3
            Else
                ProcessCommand = 2
            End If
        End If
    Vb6 don't know the Left function ?
    Confusion Master
    Enforcer's Avatar
    Sep 2003
    instr is not boolean
    try
    If Len(CMD) > 11 And InStr(CMD, ";")<>0 Then
    THE EXPERIMENTER
    carputer1's Avatar
    Sep 2007
    UK,Surrey
    try this
    Dim CmdArray() As String
    If UBound(CmdArray) = 2 Then 'Make sure you have the correct data.
    Call MouseButtonDownXY(1, CLng(CmdArray(1)), CLng(CmdArray(2)))
    End If
    ProcessCommand = 2
    End If
    Riderunner / Genesis
    Wifiman_NET:Version 1.0.0
    May 2008
    Bordeaux, France
    Smile
    I have writen that who run very well !
    Code:
        If InStr(CMD, "clickmouse;") Then
                Call MouseButtonDownXY(CmdArray(1), CmdArray(2), CmdArray(3))
                Call MouseButtonClick(CmdArray(1))
                ProcessCommand = 2
            End If
        End If
    Thanks to all
  1. Build on Mandriva 2010
    By yoshihiro in forum RevFE
    Last Post: 02-23-2010, 05:50 AM
  2. music defaults to first song on open
    By soundman98 in forum Road Runner
    Last Post: 11-23-2009, 02:36 AM
  3. Replies: 13
    Last Post: 05-28-2009, 03:18 PM
  4. pc reboot on sd startup
    By duanes7 in forum StreetDeck
    Last Post: 12-14-2007, 08:55 AM
  5. IRMAN plugin
    By knyarko in forum StreetDeck
    Last Post: 01-05-2007, 08:26 PM
