View Poll Results: Do you have a car?
Voters
45. You may not vote on this poll
  • Yes
    39 86.67%
  • No
    6 13.33%
Results 1 to 10 of 12
Thread: Add On plugin for the GPSExec by Guino
    Raw Wave pierrotm777's Avatar
    May 2008
    Bordeaux, France
    Smile Add On plugin for the GPSExec by Guino
    Thanks to Guino that have accepted this version !!!
    New features:
    1-A !Gpsexec1 indicator is put ON.
    2-A 'GPXLAT1' and 'GPXLON1' (the POI latitude and longitude)
    3 A 'GPXDIST1' (distance between your position and the POI)
    4 A 'GPXSLIDER1 (slider that use the GPXDIST1 variable)
    5-A 'GPSEXECEVENT1' this event is send when GPSExec1 is launched
    6-A 'ONSLDGPXSLIDER1' event that is automatically launched each time that the slider 'GPXSLIDER1' status change.
    7-A Settings.ini file where you can set on or off the events and a delai .
    Code:
    [SETTINGS]
    LoginsOK=1
    GPXLatLon=yes
    GPXDIST=yes
    GPXSlider=yes
    GPXSound=yes
    Distance=500
    Range_All=yes
    Range_Clo=yes
    Range_Mid=yes
    Range_Far=yes
    Units=M
    Maxhdg=
    Minhdg=
    Delai=2
    Screen=gpsexec.skin
    RadarType1=REDLIGHT_SPEEDCAM
    RadarType2=FIXED_SPEEDCAM
    RadarType3=MOBILE_SPEEDCAM
    RadarType4=COMBO_SPEEDCAM
    RadarType5=DANGEROUS_INTERSECTION
    RadarType6=DANGEROUS_CURVE
    RadarType7=NARROW_BRIDGE_AHEAD
    RadarType8=TOOL_BOOTH
    RadarType9=SCHOOL_ZONE
    RadarType10=HOME
    RadarType11=WORK
    RadarType12=SPARE
    GPXCountry=us
    SpeedType1=10
    SpeedType2=30
    SpeedType3=55
    SpeedType4=65
    SpeedType5=70
    SpeedType6=
    SpeedType7=
    SpeedType8=
    SpeedType9=
    SpeedType10=
    SpeedType11=
    SpeedType12=
    Alarm_All=yes
    Alarm_Clo=yes
    Alarm_Mid=yes
    Alarm_Far=yes
    [TRAPSTER]
    username=trapster_login
    password=trapster_password
    [GPSPASSION]
    username=gpspassion_login
    password=gpspassion_password
    [SPEEDCAMERAPOI]
    username=speedcamerapoi_login
    password=speedcamerapoi_password
    [POCKETGPSWORLD]
    username=pocketgpsworld_login
    password=pocketgpsworld_password
    You can download your Trapster or GpsPassion ... into RR and create a gpsexec.ini file with :
    -the distance alarm you want
    -the unit for the distance you want
    -the flag type(only us or fr for the moment).You can create your own planels folder, just create one and change this setup.
    -if Maxhdg and Minhdg exist on the setup, they are used for create the gpsexec.ini file
    -Trapster:
    You must have an account for Speed Trap Sharing System - Trapster, you can directly download TrapsterGarminCSVData.zip file and convert it to a gpsexec.ini file .
    You must use Internet explorer on you Carpc and logging you one time
    -GpsPassion:
    You must have an account for GpsPassion, you can directly download the 47s_RFPW_.ZIP and 47s__RMPW_.ZIP files and convert it to a gpsexec.ini file .
    -SpeedCameraPoi: (Only for the France, but i change that as soon as possible !)
    You must have an account for SpeedCameraPoi, you can directly download the .txt file and convert it to a gpsexec.ini file .
    Please add a !Gpsexec1 into your screens as:
    I,528,33,39,33,"!GPSEXEC1:b",300,500
    If you want to put off the indicator and to quit GpsExec, just use the command
    CLOSEWINDOW;GPSExec1||setind;!gpsexec1;off
    But these adds use more cpu when an event is fired !
    You can launch the plugin by two way:
    Click on the !Gpsexec1 indicator or use the command "load;gpsexec.skin"
    History:
    V1.3 7/02/2011
    -you can download from the SpeedCameraPoi web site and make your own gpsexec.ini into RR.
    -i have added a file manager (copy file, delete file, rename file, detail file, choose a folder)
    and GPSExec Path,Drives Info/Type,Refresh Drives,Copy To GPSExec
    -specific speed panels for Eu or Us
    V1.2 16/12/2010
    -you can now download from the GpsPassion web site and make your own gpsexec.ini into RR
    -now the event is not only an event but also a picture (full compatible with Trapster's alarm)
    V1.1 1/12/2010
    -pluginmgr;about;gpsexec ready
    -pluginmgr;settings;gpsexec ready
    V1.0
    -first release
    Attached Files Attached Files
    FLAC Nomader's Avatar
    Apr 2006
    Greece
    this is cool,
    how does it compare to RR gatso plugin?
    May 2008
    Bordeaux, France
    I don't know the 'gatso plugin'
    Apr 2006
    Greece
    May 2008
    Bordeaux, France
    This version is based on the Guino's GPSExec plugin and it is just adapted to RR
    Apr 2006
    Greece
    i know, i would have to try it to compare.. good work pierrotm777, thanks for sharing
    May 2008
    Bordeaux, France
    The version 1.3 is on.
    Thanks for your feed back
    Nov 2009
    once the new dfx is released and i get the compute rin my car i am gonna use trapster
    May 2008
    Bordeaux, France
    Cool !
    Aug 2008
    Hi
    Download link is broken...
