Results 1 to 10 of 10
Thread: Need little help with vb6
    Raw Wave pierrotm777's Avatar
    May 2008
    Bordeaux, France
    In a settings.ini file i have a line with two commands (bike and fly)
    Code:
    [SETTINGS]
    cmd=bike fly
    I try to test if one of these two commands is used .
    So i have tried these lines without success.
    Can you help me please ?
    Code:
    Public Function ProcessCommand(CMD As String, frm As Object) As Integer
    Dim iniFile As New ClsIniFile
    Dim CommandName
    Dim DisableScreenName As String
    Dim i As Long
    iniFile.FileName = App.Path & "/settings.ini"
    iniFile.ApplicationKey = "SETTINGS"
    CommandName = Split(iniFile.GetValue("cmd", ""), " ")
        Select Case LCase(CMD)
            Case "testds"
                MsgBox "This is a test", vbOKOnly, "by pierrotm777"
                ProcessCommand = 2
        End Select
        For i = 0 To UBound(CommandName(i)) - 1
            If CMD = CommandName(i) Then
                CMD = "load;myskin.skin"
                ProcessCommand = 3
            End If
        Next i
    End Function
    Confusion Master
    Enforcer's Avatar
    Sep 2003
    cmd=bike fly
    will have entries in
    CommandName(0) - bike
    CommandName(1) - Fly
    ubound(commandname)=1
    you are subtracting 1 so it will only look at bike, not at fly
    Also I think you need to declare CommandName with brackets to make it an array and preferably as a type
    Dim CommandName() as string
    May 2008
    Bordeaux, France
    Ok ,
    So, i write that:
    Code:
    Dim CommandName ()
    Dim i As Long
    CommandName () = Split(iniFile.GetValue("cmd", ""), " ")
            Case "testds"
                ProcessCommand = 2
        End Select
                ProcessCommand = 3
            End If
        Next i
    End Function
    May 2008
    Bordeaux, France
    But i have an error on the Ubound
    Confusion Master
    Enforcer's Avatar
    Sep 2003
    Try
    Code:
    Dim CommandName () as String
    Dim i As Long
    Case "testds"
    ProcessCommand = 2
    End Select
    For i = 0 To UBound(CommandName)
    ProcessCommand = 3
    End If
    Next i
    End Function
    May 2008
    Bordeaux, France
    Enforcer,
    You are the best !
    Big thanks
    Confusion Master
    Enforcer's Avatar
    Sep 2003
    Quote Originally Posted by pierrotm777 View Post
    Enforcer,
    You are the best !
    Big thanks
    Now stop using app.path in the middle of the process command routine. Assign it to a variable at start up. Please!!!
    ---------- Post added at 09:56 AM ---------- Previous post was at 09:56 AM ----------
    Enforcer,
    You are the best !
    Big thanks
    THE EXPERIMENTER
    carputer1's Avatar
    Sep 2007
    UK,Surrey
    lol making sure the message gets trough lol....
    Riderunner / Genesis
    Wifiman_NET:Version 1.0.0
    Confusion Master
    Enforcer's Avatar
    Sep 2003
    Quote Originally Posted by carputer1 View Post
    Actually, I only posted it once.
    Then I edited it, looks like a bug with the Combining of posts.
    May 2008
    Bordeaux, France
    Where i must to do that and how ?
    Into the RRextension.cls, after that ?
    Option Explicit
    Dim RunOnce As Boolean ' set to prevent a double execution of code
    Dim RRSDK As RRSDK ' set type of var to the subclass
    ---------- Post added at 02:57 PM ---------- Previous post was at 02:55 PM ----------
    Ho, I think that i have found how to do.
    Public Sub Initialize(pluginDataPath As String)
    Dim t
    On Error Resume Next
    t = GetAttr(pluginDataPath) ' if error, then we dont have this directory existing
    If IsEmpty(t) = True Then CreateFolder pluginDataPath
    MainPath = pluginDataPath
    End Sub
