View Poll Results: Do you think to use it ?
Voters
5. You may not vote on this poll
  • yes
    5 100.00%
  • no
    0 0%
Page 2 of 2 FirstFirst 12
Results 11 to 16 of 16
Thread: GoogleMapsTools for RideRunner
  1. #11
    Aug 2006
    Hong Kong
    I just installed and error occur after running.
    When set to ElcosMenu
    Exectbl.ini
    Code:
    "MyApp23","load;GoogleMapsTools.skin||run;$skinpath$Scripts\GoogleMapsTools\GoogleMapsTools.exe;GoogleMapsTools
    Code:
    B01,681,38,114,31,"RUN;$SKINPATH$SCRIPTS\ElcosMenu\ElcosMenu.exe|gta_el_menuV.skin","","Run Overlay Menu"
    Run the GoogleMapsTools is no error, but error occur when click "Menu >"
    When set to FlyToMenu
    Exectbl.ini
    Code:
    "MyApp23","load;GoogleMapsTools.skin||run;$skinpath$Scripts\GoogleMapsTools\GoogleMapsTools.exe;GoogleMapsTools||RUN;$SKINPATH$SCRIPTS\FlyToMenu\FlyToMenu.exe|gta_fl_menuV.skin"
    Code:
    B01,681,38,114,31,"RUN;$SKINPATH$SCRIPTS\FlyToMenu\FlyToMenu.exe|gta_fl_menuV.skin","","Run Overlay Menu"
    Error occur when the GoogleMapsTools start
    Moreover, when the GPS is not ready, and I click the button of "Update is OFF", the skin of messagebox.skin is not found message shown. I think this is because the installation files doesn't contain this skin file, all related image files are exist in skin folder (messagebox_ok_down.jpg, messagebox_ok_off.jpg, messagebox_ok_on.jpg and messagebox_ok_transparent.jpg)
  2. #12
    Raw Wave pierrotm777's Avatar
    May 2008
    Bordeaux, France
    Can you upload your gta_el_menuV.skin please ?
    Attached Files Attached Files
  3. #13
    Aug 2006
    Hong Kong
    Hi, I attached 2 files (gta_el_menuv.skin and gta_fi_menuv.skin) to you, because both of them shown error when start. Thanks!
  4. #14
    May 2008
    Bordeaux, France
    Ok,
    For El version,
    Delete the include colors.txt because you don't use it in your version.
    As i see, you use the drop shadow option , so you can use the RR format for the labels with drop shadows and delete the shadow lines
    Code:
    RideRunner Skin
    RRScreen Carwings
    /EFFECT=0
    /POSX=543
    /POSY=35
    V,100
    [Labels]
    L,100,4,28,23,255,255,0,19,"Webdings:B","=4","CENTER",,"DS=2,2,0,0,0"
    L,3,4,28,23,255,255,0,19,"Webdings:B","=3","CENTER",,"DS=2,2,0,0,0"
    L,46,6,51,23,255,255,0,16,"Arial:B","=Quit","CENTER",,"DS=2,2,0,0,0"
    L,36,36,105,23,255,255,0,16,"Arial:B","=GpsToAdd","CENTER",,"DS=2,2,0,0,0"
    L,36,65,105,23,255,255,0,16,"Arial:B","=AddToGps","CENTER",,"DS=2,2,0,0,0"
    L,55,93,105,23,255,255,0,16,"Arial:B","=Ruler","CENTER",,"DS=2,2,0,0,0"
    L,36,386,105,23,255,255,0,16,"Arial:B","=Optimized","CENTER",,"DS=2,2,0,0,0"
    L,39,493,105,23,0,0,0,16,"Arial:B","=Rst Route","CENTER",,"DS=2,2,0,0,0"
    L,39,435,105,23,255,255,0,16,"Arial:B","=Get Route","CENTER",,"DS=2,2,0,0,0"
    L,31,464,105,23,255,255,0,16,"Arial:B","=Undo Route","CENTER",,"DS=2,2,0,0,0"
    L,37,491,105,23,255,255,0,16,"Arial:B","=Rst Route","CENTER",,"DS=2,2,0,0,0"
    L,39,403,105,23,255,255,0,16,"Arial:B","=Direction","CENTER",,"DS=2,2,0,0,0"
    L,35,122,116,23,255,255,0,16,"Arial:B","=Panoramio","CENTER",,"DS=2,2,0,0,0"
    L,39,150,98,23,255,255,0,16,"Arial:B","=Elevation","CENTER",,"DS=2,2,0,0,0"
    L,60,322,98,23,255,255,0,16,"Arial:B","=Tilt","CENTER",,"DS=2,2,0,0,0"
    L,50,208,98,23,255,255,0,16,"Arial:B","=Traffic","CENTER",,"DS=2,2,0,0,0"
    L,36,236,126,23,255,255,0,16,"Arial:B","=Your Maps","CENTER",,"DS=2,2,0,0,0"
    L,58,264,126,23,255,255,0,16,"Arial:B","=Sky","CENTER",,"DS=2,2,0,0,0"
    L,45,292,126,23,255,255,0,16,"Arial:B","=Earth 3D","CENTER",,"DS=2,2,0,0,0"
    L,54,178,76,23,255,255,0,16,"Arial:B","=Level","CENTER",,"DS=2,2,0,0,0"
    L,160,36,105,23,255,255,0,16,"Arial:B","=GooleMap","CENTER",,"DS=2,2,0,0,0"
    L,169,65,105,23,255,255,0,16,"Arial:B","=Search","CENTER",,"DS=2,2,0,0,0"
    L,147,94,155,23,255,255,0,15,"Arial:B","=Maps Toolbar","CENTER",,"DS=2,2,0,0,0"
    L,142,123,155,23,255,255,0,15,"Arial:B","=Show/Hide Sun","CENTER",,"DS=2,2,0,0,0"
    [Buttons]
    B01,21,31,117,30,"SENDMSG;GoogleMapsTools;GPSTOADD","","Give an address"
    B02,21,62,117,27,"SENDMSG;GoogleMapsTools;SETADDTOGPS","","Give Latitude and longitude"
    B03,21,89,117,29,"SENDMSG;GoogleMapsTools;ADDRULER","","Create a ruler"
    B04,21,118,117,29,"SENDMSG;GoogleMapsTools;PANORAMIO","","Use the Panoramio pictures vues"
    B05,21,146,117,29,"SENDMSG;GoogleMapsTools;ALTITUDE","","Give the altitude"
    B06,21,175,117,29,"SENDMSG;GoogleMapsTools;TILT","","3d vue of buildings"
    B07,21,204,117,29,"SENDMSG;GoogleMapsTools;TRAFFICTT","","Tomtom Traffic"
    B08,21,233,117,29,"SENDMSG;GoogleMapsTools;FUSIONTABLE","","See your fusion table on Goole Maps"
    B09,21,261,117,29,"SENDMSG;GoogleMapsTools;EARTHSKY","","Sky vue with Google Earth"
    B10,21,288,117,29,"SENDMSG;GoogleMapsTools;EARTH3D","","3d Google Earth"
    B11,21,317,117,29,"SENDMSG;GoogleMapsTools;ELEVATION","","Elevation of your points"
    B12,21,378,117,57,"SENDMSG;GoogleMapsTools;CALCULROUTE","","Create a route"
    B13,21,430,117,31,"SENDMSG;GoogleMapsTools;GETROUTE","","Calcul a route"
    B14,20,487,119,31,"SENDMSG;GoogleMapsTools;RESETROUTE","","Reset a route"
    B15,21,459,117,31,"SENDMSG;GoogleMapsTools;UNDOROUTE","","Delete last point"
    B16,142,31,117,30,"SENDMSG;GoogleMapsTools;GOOGLEMAP","","Google Maps"
    B17,142,60,117,30,"SENDMSG;GoogleMapsTools;SEARCHINTOGOOGLEMAP","","Search with Google Maps"
    B18,142,90,117,30,"SENDMSG;GoogleMapsTools;MAPSTOOLBAR","","Maps Toolbar"
    B19,142,120,117,30,"SENDMSG;GoogleMapsTools;SHOWHIDESUN","","Show and hide the Sun"
    B22,41,1,52,35,"SENDMSG;ElcosMenu;Exit","","Exit Elcos Menu"
    END
    I send you two examples, one with inc,colors.txt and another without !
    The fl version (flytomenu) run only with flytomenu .
    NB: I work on a plugin That does the same things that this script and hope top give it to the RR community as soon as possible !
  5. #15
    Aug 2006
    Hong Kong
    Hi, I replaced the GTA_El_MenuV.skin by your attached, but the error is still same. I saw the error windows title is "AutoIt", Does it a applilcation I need to install first?
  6. #16
    May 2008
    Bordeaux, France
    You don't need to have a Autoit installed !
    I have tried the code that you have now , i don"t understand where is the issue !
  1. RideRunner for Android?
    By upspace in forum Road Runner
    Last Post: 09-24-2014, 02:20 PM
  2. MegaSquirt >> RideRunner
    By Jebus in forum Software & Software Development
    Last Post: 01-21-2011, 11:38 AM
  3. New to RideRunner
    By themlruts in forum Road Runner
    Last Post: 07-13-2010, 01:37 AM
  4. RideRunner Help
    By Joshc8503 in forum Road Runner
    Last Post: 11-30-2009, 01:10 PM
  5. riderunner phone help
    By danchappers in forum Road Runner
    Last Post: 05-17-2009, 03:28 AM
