View Poll Results: Do you think to use it ?
Voters
0. You may not vote on this poll
  • yes
    0 0%
  • no
    0 0%
Results 1 to 2 of 2
Thread: CheckZones for RR
    Raw Wave pierrotm777's Avatar
    May 2008
    Bordeaux, France
    CheckZones for RR
    This new little script for RR check the zones where a button exist and add a Tooltip balloon with a text defined into you .skin file.
    Just one issue , run only if you use a command input that simulate the mouse ! Sorry
    For that, you need to add a new field for each button like that:
    Code:
    B01,1,-2,50,36,"MINIMIZE","","Zone 1"
    B02,10,561,57,39,"MUTE","","Zone 2"
    Add these lines into your exectbl.ini file:
    "ONSCREENCHANGE","SENDMSG;CheckZone;NEWSCREEN"
    "CHECKZONESSCREEN","RUN;$SKINPATH$Scripts\CheckZon esScreen\checkzone.exe"
    "OnSkinStart","CHECKZONESSCREEN"
    If you want use the SkinEditor with this option , just modify into the objects.txt file the ligne:
    Button,B,x,y,w,h,Command;COMMANDCODES,Tooltip
    by
    Button,B,x,y,w,h,Command;COMMANDCODES,Tooltip,Ball oon
    You can to disable it without kill the function :
    "SETVAR;!Checkzone;OFF"
    Attached Files Attached Files
    May 2008
    Bordeaux, France
    little update:
