New version that accept now le Indicator called by FILE; !
Variables are accepted for the path and the picture !
Code:I,150,200,100,100,"FILE;$Pluginspath$GPSExec\Pictures\$language$\$gpsexecpanel$","All"
Printable View
Great news. Can't wait to give it a try.
Hope to make it work whits sliders to.
I have problem whit new version. ElcosMenu.exe is hungry for memory and CPU.
when send command:SETVAR;GPSEXECPANEL;McDonald's.png it is show picture fine, but when new command is sent:SETVAR;GPSEXECPANEL;HOMEZONE.PNG it is just make one picture over other. Any help?
http://i52.tinypic.com/2hx3995.png
If i understand well, the picture is well launched when you launc the menu but the update of the picture don't run ?
Yes update of the picture don't run. Also tried whit: SENDMSG;ElcosMenu;UPDATE whit no result.
SENDMSG;ElcosMenu;UPDATE is only for the Labels as the first ElcosMenu does !
Mali_Arkan,
I have updated the first post, please use this new version, the indicator's updated is ok for me !
It is still the same for me. If i tried to used whit *.png pictures i could see that it is just open over first one for example:
http://i51.tinypic.com/dfvj88.png
Also when send command: SENDMSG;ElcosMenu;Exit - you will see that first close *.png and then *.gif
Now whit update version when i restart ElcosMenu.exe and start it again i get thease message, and i can see that it is delete my *.png pictures.
http://i55.tinypic.com/de2mhs.png
What about memory usage?
-In fact , i don't delete the first file, so you have 2 pictures on the same position, i must work on that issue !
-Sorry for the .png , in fact , i delete the .png when the input file is an other picture's type than .png !
I must to work a little bit on this issue !
No problem. Yes i want to me it work whit GPSExec Plugin....
