View Poll Results: Do you think to use it ?
Voters
1. You may not vote on this poll
  • yes
    1 100.00%
  • no
    0 0%
Page 4 of 9 FirstFirst 123456789 LastLast
Results 31 to 40 of 89
Thread: Elcosmenu 2 (Overlay menu)
  1. #31
    Raw Wave pierrotm777's Avatar
    May 2008
    Bordeaux, France
    Little update
    Little update around the update of the labels and the memory used.
  2. #32
    Aug 2008
    Quote Originally Posted by pierrotm777 View Post
    No and i am sorry !
    But if you don't need to update some labels , you can change /UPDATELABELSDELAY=1 by /UPDATELABELSDELAY=0
    Working good now... Thanks
    But it is still deleting my *.png pictures. It is only delet pictures whit *.png but all other format work fine.... Any idea?
  3. #33
    Aug 2008
    I have only one more request is there posible to make 3 scripts/plugins which will be independent?
    Example:
    The skin commands are:
    SENDMSG;ElcosMenu2;DRAGITRETURN idem but called by RR
    SENDMSG;ElcosMenu2;DRAGITTOP idem but called by RR
    SENDMSG;ElcosMenu2;DRAGITBOTTOM idem but called by RR
    SENDMSG;ElcosMenu2;DRAGITLEFT idem but called by RR
    SENDMSG;ElcosMenu2;DRAGITRIGHT idem but called by RR
    SENDMSG;ElcosMenu2;Exit quit the ElcoseMenu
    SENDMSG;ElcosMenu2;UPDATE labels are updated
    SETVAR;ELCOSUPDATE2;1/0 labels are updated or not
    =$ELCOSVER2$ elcosmenu version
    and for ElcosMenu3, ElcosMenu4...
    I found thease plugin very good
    May 2008
    Bordeaux, France
    I can to try that ! Do you see a difference with the memory ?
  5. #35
    Aug 2008
    Yes. Big difference. Now is used very little memory and it is stable...
  6. #36
    May 2008
    Bordeaux, France
    It's a very cool news . I have used 2 labels's update into the script ! I work now on the multiple instance version !
  7. #37
    Aug 2008
    Thanks. Looking forward for multiple instance version.
  8. #38
    May 2008
    Bordeaux, France
    Ok the multi instances version is now ready !
    You can launch the overlay menu as elcos menu:
    Code:
    You can always launch the menu with the normal version:
    Code:
    RUN;$SKINPATH$SCRIPTS\ElcosMenu\ElcosMenu.exe|gta_el2_menuV.skin
    With the v2.06 version the Elcos menu accept several instances:
    Code:
    RUN;$SKINPATH$SCRIPTS\ElcosMenu\ElcosMenu.exe|gta_el2_menuC.skin
    or
    RUN;$SKINPATH$SCRIPTS\ElcosMenu\ElcosMenu.exe|1|gta_el2_menuC1.skin
    RUN;$SKINPATH$SCRIPTS\ElcosMenu\ElcosMenu.exe|2|gta_el2_menuC2.skin
  9. #39
    Aug 2008
    Nice. What about thease command?
    SENDMSG;ElcosMenu;DRAGIT***
    SENDMSG;ElcosMenu;Exit
    Will thease command exit or move all ElcosMenu ( |2, |3,...)? Sometimes i will need to exit only one...
  10. #40
    May 2008
    Bordeaux, France
    Quote Originally Posted by Mali_Arkan View Post
    If you use the SENDMSG command you need to define the good instance number !
    As:
    Code:
    SENDMSG;ElcosMenuX;DRAGIT***
    SENDMSG;ElcosMenuX;Exit
    If you want to move the menu, you can use the direct command or the RR command with the SENDMSG command .
    NB:
    An issue exist if the .skin don't have no indicator defined !
  1. Replies: 39
    Last Post: 07-31-2012, 08:56 PM
  2. Replies: 1
    Last Post: 09-22-2010, 07:23 AM
  3. transparent menu overlay?
    By skeurton in forum Road Runner
    Last Post: 02-20-2008, 06:17 PM
  4. RR Menu to emulate MM Menu button
    By GizmoQ in forum Map Monkey
    Last Post: 09-05-2006, 02:02 PM
  5. Overlay menu question
    By Custommx3 in forum RR Skins
    Last Post: 07-13-2006, 09:19 AM
