View Poll Results: Do you think to use it ?
Voters
1. You may not vote on this poll
  • yes
    1 100.00%
  • no
    0 0%
Page 6 of 9 FirstFirst 123456789 LastLast
Results 51 to 60 of 89
Thread: Elcosmenu 2 (Overlay menu)
  1. #51
    Aug 2008
    Quote Originally Posted by pierrotm777 View Post
    Version V2.09 with the sliders option is out .
    Please note that this version update well the slider if only one slider is defined !
    Hi
    I have problem whit sliders in 2.09a version. Slider shows up but after 3 seconds just disappear. Any idea?
    My ***.skin file
    RideRunner Skin
    RRScreen
    /EFFECT=0
    /TRANSTIME=0.1
    /POSX=0
    /POSY=0
    /MAXTOPPOS=20
    /MAXBOTTOMPOS=20
    /MAXLEFTPOS=543
    /MAXRIGHTPOS=800
    /CLICKIND=0
    /UPDATELABELS=1
    /UPDATELABELSDELAY=1
    /UPDATEINDICATORSDELAY=5
    /UPDATESLIDERSDELAY=5
    /TIPTEXT=1
    /BUTTON_CLICKED=Sounds\Button_Clicked.wav
    /BUTTON_HOLD=Sounds\Button_Hold.wav
    /OFFSETFONT=-5
    V,90
    Y01,"VOLUME_SLIDER\SLIDER_*.gif"
    S01,0,264,300,21,62,103,70,20,H,01,"",015,"MASTER" ,"master"
    B,3,119,56,56,"VOL-",
    B,240,119,56,56,"VOL+",
    B,61,61,175,176,"MUTE",
    END
  2. #52
    Raw Wave pierrotm777's Avatar
    May 2008
    Bordeaux, France
    yes ,
    When the menu is launched, i put the sliders to 65535, and just after that the update begin
  3. #53
    May 2008
    Bordeaux, France
    Please, for the slider, you must to prefer the .png to the .gif files .
    May 2008
    Bordeaux, France
    New version v2.1 that accept all type of files for the sliders,
    but please always prefer the .png files !
    [Sliders]
    Y01,"Dfx5_Slider\slider_*.png"
    Y02,"SignalSliderImages\slider_*.gif"
    Y03,"SlopeSliderImages\slider_*.png"
    S01,85,140,250,330,62,103,70,20,H,01,"",015,"$DFXS PEED$","DFX Speed"
    S02,460,400,100,20,62,103,70,20,H,02,"",015,"GPSSI GNAL","Gps Signal"
    S03,700,120,47,300,736,97,47,339,V,03,"",015,"$GPX SLIDER1$","GPX SLIDER"
    I have always an issue if you use several sliders, just the last is updated !
  5. #55
    May 2008
    Bordeaux, France
    This new version update very well now the sliders.
    I have found an issue with the indicators with the format "FILE;..."
    Please, use just one indicator with this format !
  6. #56
    May 2008
    Bordeaux, France
    The version V2.12 solve the issue with the indicators (use better the memory)
    You can also use several indicators.
  7. #57
    May 2008
    Bordeaux, France
    The version V2.13 add the option MOUSEHOVER .
    When you are over a button, the _on.png picture is active 1 second !
  8. #58
    May 2008
    Bordeaux, France
    No body like this job , no poll used ?
  9. #59
    May 2008
    Bordeaux, France
    New little version (2.14).
    -You can now change in real time the opacity of the ElcoMenu ("SETVAR;ELCOSOPACITY;X") where X = 0 to 100
    -You can now stop and rerun the updates of labels,indicators and sliders
    New options for the .skin file:
    Code:
    /UPDATELABELS=1                             labels's update is active or not (0/1) (new)
    /UPDATEINDICATORS=1                         indicators's update is active or not (0/1) (new)
    /UPDATESLIDERS=1                            sliders's update is active or not (0/1) (new)
    Code:
    SETVAR;UPDATELABELS;1/0                           labels are updated or not
    SETVAR;UPDATEINDICATORS;1/0                        indicators are updated or not
    SETVAR;UPDATESLIDERS;1/0                           sliders are updated or not
    SETVAR;ELCOSOPACITY;X                           where X = 0 to 100
  10. #60
    May 2008
    Bordeaux, France
    V2.15 10/17/2011
    Solved 2 little bugs with the v2.14 (the MOUSEONOVER option now run well)
    The good option is:
    /MOUSEONOVER=1 and not /MOUSEONHOVER=1
    You can set on or off with the command
    SETVAR;MOUSEONOVER;1/0
    I have added the TMR option.
    You must to define your command with the good .skin name into your ExecTBL.ini file !
    Code:
    "TIMER","DFXTIMER",MyElcosMenu.skin
    "DFXTIMER","EVAL;DFXSPEEDINPERCENT;($DFXSPEED$*100)\65535"
  1. Replies: 39
    Last Post: 07-31-2012, 08:56 PM
  2. Replies: 1
    Last Post: 09-22-2010, 07:23 AM
  3. transparent menu overlay?
    By skeurton in forum Road Runner
    Last Post: 02-20-2008, 06:17 PM
  4. RR Menu to emulate MM Menu button
    By GizmoQ in forum Map Monkey
    Last Post: 09-05-2006, 02:02 PM
  5. Overlay menu question
    By Custommx3 in forum RR Skins
    Last Post: 07-13-2006, 09:19 AM
