Page 2 of 2 FirstFirst 12
Results 11 to 19 of 19
Thread: Need help with vb.net and inpout32.dll
  1. #11
    Confusion Master
    Enforcer's Avatar
    Sep 2003
    Well the next steps I would take is to put some debugging code in to print out each calculation step by step.
    Code:
            If Left(LCase(CMD), 11) = "rrpp_biton;" Then
                If Len(CMD) > 11 And InStr(CMD, ";") Then
                    Datavalues = Inp(DataPort)
                   anothervariable= Convert.ToInt32(Mid(CMD, 12, 1)) ^ 2
                    debug.print datavalues,anothervariable
                    variable3=datavalues or anothervariable
                     debug.print  variable3
                     Datavalues = Datavalues Or (Convert.ToInt32(Mid(CMD, 12, 1)) ^ 2)
                    Out(DataPort, Datavalues)
                    Datavalues = 0
                End If
                ProcessCommand = 2
            End If
            If Left(LCase(CMD), 12) = "rrpp_bitoff;" Then
                If Len(CMD) > 12 And InStr(CMD, ";") Then
                     Datavalues = Datavalues And (255 - (Convert.ToInt32(Mid(CMD, 13, 1)) ^ 2))
                    Datavalues = 0
                End If
                ProcessCommand = 2
            End If
  2. #12
    Raw Wave pierrotm777's Avatar
    May 2008
    Bordeaux, France
    OK , i have tried your code but i don't see where to found the debug file !
  3. #13
  4. #14
    May 2008
    Bordeaux, France
    If i understand well, i create a little .exe (without RR and out the dll) and i modify this code for a form with one button by example ?
  5. #15
    Confusion Master
    Enforcer's Avatar
    Sep 2003
    Yes.
    I actually have a debug print subroutine bas file I add to all my applications which basically prints whatever I send to it to a text file, my debug.txt file.
    Then I just use that.
    But for now just test as a standalone exe.
  6. #16
    May 2008
    Bordeaux, France
    Ok , I am ready and i understand how do do this test .
    I have made a form with this code:
    Code:
        Private Sub WrieTestCMD_Click(ByVal sender As System.Object, ByVal e As System.EventArgs) Handles WrieTestCMD.Click
            PortAddress = &H378S
            Value = Inp(PortAddress)
            Text2.Text = CMD
            anothervariable = Convert.ToInt32(Mid(CMD, 12, 1)) ^ 2
            'Debug.Print(Value, anothervariable)
            variable3 = Value Or anothervariable
            'Debug.Print(variable3)
            Value = Value Or (Convert.ToInt32(Mid(CMD, 12, 1)) ^ 2)
            Out(PortAddress, Value)
            Value = 0
        End Sub
    And i have an error on this line (bad format on this string)
    The exact error is:
    Une exception de première chance de type 'System.FormatException' s'est produite dans mscorlib.dll
  7. #17
  8. #18
    May 2008
    Bordeaux, France
    Quote Originally Posted by Enforcer View Post
    What is in CMD?
    Heuuu, Text2.Text = CMD ?
    And when i run the example i put 10001000 into the text box 2
  9. #19
    Confusion Master
    Enforcer's Avatar
    Sep 2003
    But you are not putting the contents of text2.text into CMD, you are putting the contents of CMD into text2.text.
    Change that line to
    CMD = text2.text
