Results 1 to 10 of 19
Thread: Need help with vb.net and inpout32.dll
    Raw Wave pierrotm777's Avatar
    May 2008
    Bordeaux, France
    Smile Need help with vb.net and inpout32.dll
    I made a new plugin around the parallel port with vb.net 2010 .
    All is ok , but i have a curious result when i try to send 10001000 or 00010001 to the parallel port.
    I obtain the same result as if i send 10001000.
    My code is:
    Code:
            If Left(LCase(CMD), 8) = "rrpp_on;" Then
                If Len(CMD) > 8 And InStr(CMD, ";") Then
                    Out(PortAddress, Convert.ToInt32(Mid(CMD, 9, 8), 2))
                    ProcessCommand = 2
                Else
                    ProcessCommand = 2
                End If
            End If
    So my RR command is : "rrpp_on;10001000"
    Where is my bug please ?
    I have other problem !
    With this command i can only change all bit in the same time .
    I should like to have one command by bit !
    How can i write that please ?
    Thanks for all help !
    MySQL Error
    Oct 2004
    please dont make ANY commands, VARS or or indicators, or such
    prefixed with "RR"
    this could lead to confusion, and future issues
    -Thanks
    Mitch
    www.rush2112.net
    Sun, Come shine my way
    Wind, Carry me home
    The piece of me that died
    Will return To live again
    Confusion Master
    Enforcer's Avatar
    Sep 2003
    Quote Originally Posted by mitchjs View Post
    prefixed with "RR"
    What you talking about.
    All my plugins have their ommands start with rr followed by either their full plugin name or a shorted plugin name.
    This was done so we can have unique commands for each plugin and not get mixed up.
    ie
    RRFuelPrices has commands, labels, indicators, and vars start with rrfp_
    RRTrafficcams has commands, labels, indicators, and vars start with rrtc_
    RRUpd8 has commands, labels, indicators, and vars start with with rrupd8_
    etc.
    MySQL Error
    Oct 2004
    yea.. well... there is a higher chance that there is a collision now
    all NEW internal commands/indicators and such and such, will start RRxxxxx
    ur using a underscore... so your ok...
    but dont do... say...
    RRMyCommand
    we cant really enforce it, unless we wanted to police all plugins, and we dont...
    even though there should be some...since technically one could make a plugin, that deletes all your files...or calls home
    with personal files/data
    -Thanks
    Mitch
    www.rush2112.net
    Wind, Carry me home
    RoadRunner Mastermind
    guino's Avatar
    Nov 2004
    Toronto, Canada
    You should READ the current data on the port (or have it previously saved in memory), then replace the bit you want to set in the data you've read, only then WRITE the resulting data to the port. That's the only way to control the output bit by bit without changing what's already there.
    Ride Runner RR's Myspace
    May 2008
    Bordeaux, France
    Thanks mitchjs and Enforcer for your positives critics .
    Thanks Guino, but should like a little example code !
    guino's Avatar
    Nov 2004
    Toronto, Canada
    try this with rrpp_biton;X or rrpp_bitoff;X -- X should be a bit from 0 to 7 (untested)
    Code:
            If Left(LCase(CMD), 11) = "rrpp_biton;" Then
                If Len(CMD) > 11 And InStr(CMD, ";") Then
                    CurrentValue = Inp(PortAddress)
                    CurrentValue = CurrentValue OR (Convert.ToInt32(Mid(CMD, 12, 1)^2)
                    Out(PortAddress, CurrentValue)
                End If
                ProcessCommand = 2
            End If
            If Left(LCase(CMD), 12) = "rrpp_bitoff;" Then
                If Len(CMD) > 12 And InStr(CMD, ";") Then
                    CurrentValue = CurrentValue AND (255- (Convert.ToInt32(Mid(CMD, 13, 1)^2))
                End If
                ProcessCommand = 2
            End If
    May 2008
    Bordeaux, France
    I have done some change but i have an big issue .
    If when i run RR all bit are equal to 1:
    rrpp_bitoff;0 don't run
    rrpp_bitoff;1 put well the bit 0 to 0
    rrpp_bitoff;2 put the bit 2 to 0 and not the 1
    rrpp_bitoff;3 put the bit 0 and 3 to 0 and not the bit 2 to 0
    etc...
    if i put all the bit to 0:
    rrpp_biton;0 don't run
    rrpp_biton;1 put the bit 7 to 1 and not the bit 0 to 1
    rrpp_biton;2 put always the bit 7 to 1 and not the bit 1 to 1
    etc...
    This is your code modified !
    Code:
                    Datavalues = Inp(DataPort)
                    Datavalues = Datavalues Or (Convert.ToInt32(Mid(CMD, 12, 1) ^ 2))
                    Out(DataPort, Datavalues)
                    Datavalues = 0
                End If
                ProcessCommand = 2
            End If
                    Datavalues = Datavalues And (255 - (Convert.ToInt32(Mid(CMD, 13, 1) ^ 2)))
                    Datavalues = 0
                End If
                ProcessCommand = 2
            End If
    An idea ?
    Confusion Master
    Enforcer's Avatar
    Sep 2003
    Try
    Code:
                     Datavalues = Datavalues Or (Convert.ToInt32(Mid(CMD, 12, 1)) ^ 2)
                    Datavalues = 0
                End If
                ProcessCommand = 2
            End If
                     Datavalues = Datavalues And (255 - (Convert.ToInt32(Mid(CMD, 13, 1)) ^ 2))
                    Datavalues = 0
                End If
                ProcessCommand = 2
            End If
    I think the issue is that Guino left out a close bracket (parenthesis) which meant you were trying to square a string value as opposed to the int value of the string (just my guess without testing)
    May 2008
    Bordeaux, France
    Enforcer, thanks for your help but , that don't run well !
    If all is off, the command rrpp_biton;5 put on the bits 8,7 and 3 (B8 to B1)
