Results 1 to 2 of 2
Thread: Error in RRMediaDB
    Aug 2006
    Hong Kong
    Error in RRMediaDB
    I had a question about the RMBuilder, when I install the DFX and use the Rescan DB-> Build Music Database, the error of "Input past end of file RMBuilder" occur and progress stay in "Scanning & Importing"
    Following is the debug log when I enable in RRMediaDB icon.
    Quote Originally Posted by RRMedia(Builder)_Debug.txt
    2011/12/2 上午 10:02:24: ------ Builder Started --------
    2011/12/2 上午 10:02:24: Builder ver: 1.3.0
    2011/12/2 上午 10:02:24: Storepath: C:\Documents and Settings\Administrator\Application Data\RRMedia\
    2011/12/2 上午 10:02:24: RoadRunner communitation OK!
    2011/12/2 上午 10:02:24: LiteX communitation OK!
    2011/12/2 上午 10:02:24: CddbID3Tag communitation OK!
    2011/12/2 上午 10:02:24: MediaInfo communitation OK!
    2011/12/2 上午 10:02:24: Db_Exists=True : DB_Complete=False : ReScaning=False : QuickImport=False : ByFolder=False
    2011/12/2 上午 10:02:30: Input past end of file
    Quote Originally Posted by RRMedia(Ext PI)_Debug.txt
    2011/12/2 上午 10:01:02: Initializing RRMedia
    2011/12/2 上午 10:01:02: DLL v1.3.2
    2011/12/2 上午 10:01:02: Main v1.3.0.3
    2011/12/2 上午 10:01:02: Builder v1.3.0.0
    2011/12/2 上午 10:01:02: Plugin Path: C:\Program Files\RideRunner\Plugins\RRMedia
    2011/12/2 上午 10:01:02: Store Path: C:\Documents and Settings\Administrator\Application Data\RRMedia\
    2011/12/2 上午 10:01:02: MainPath: C:\Program Files\RideRunner\Plugins\RRMedia\RRMediaDb.exe
    2011/12/2 上午 10:01:02: DbPath: D:\Mp3\RRMediaDB.db
    2011/12/2 上午 10:01:02: Initz Labels
    2011/12/2 上午 10:01:02: Labels Done
    2011/12/2 上午 10:01:02: Checkin for nessary files
    2011/12/2 上午 10:01:02: Checkin for nessary files...Done
    2011/12/2 上午 10:01:03: Staring Main Exe
    Quote Originally Posted by RRMedia(Main)_debug.txt
    2011/12/2 上午 10:01:03: --------> At_Startup
    2011/12/2 上午 10:01:03: SQL Communication is OK!
    2011/12/2 上午 10:01:03: Waiting for an instance of RR to be Started
    2011/12/2 上午 10:01:05: RR Communication is OK!
    2011/12/2 上午 10:01:06: Checking for a valid RRMedia Db....
    2011/12/2 上午 10:01:06: Checking for a valid RRMedia Db....OK!
    2011/12/2 上午 10:01:06: Creating default Disk Names using settings
    2011/12/2 上午 10:01:06: Creating default Disk Names using settings...Done
    2011/12/2 上午 10:01:06: --------> createlistboxinfo
    2011/12/2 上午 10:01:06: Getting Disk Names from the TOC...
    2011/12/2 上午 10:01:06: Getting Disk Names from the TOC...Done
    2011/12/2 上午 10:01:06: <-------- createlistboxinfo
    2011/12/2 上午 10:01:06: --------> Create_FolderCache
    2011/12/2 上午 10:01:06: Creating Music Folder cache list file...
    2011/12/2 上午 10:01:06: Creating Music Folder cache list file...Done
    2011/12/2 上午 10:01:06: <-------- Create_FolderCache
    2011/12/2 上午 10:01:06: --------> UpdateRRCDNameTable
    2011/12/2 上午 10:01:06: Getting Disk Names & Track Info for Labels...
    2011/12/2 上午 10:01:06: --------> BuilderCheck
    2011/12/2 上午 10:01:06: <-------- BuilderCheck
    2011/12/2 上午 10:01:06: Getting Disk Names & Track Info for Labels...Done
    2011/12/2 上午 10:01:06: --------> RR_Execute
    2011/12/2 上午 10:01:06: <-------- RR_Execute
    2011/12/2 上午 10:01:06: <-------- UpdateRRCDNameTable
    2011/12/2 上午 10:01:06: <-------- At_Startup
    2011/12/2 上午 10:02:43: --------> OpenStorePath
    2011/12/2 上午 10:02:44: <-------- OpenStorePath
    I use the Traditional Chinese as file name and ID Tag 3v1, and all ID Tag 3v2 (v2.3) I use Unicode-LE
    Thank you very much to help me.
    Aug 2006
    Hong Kong
    Anyone can help me?
  1. Plugin Error loading - Automation error
    By efun in forum RR Plugins
    Last Post: 10-11-2009, 09:41 AM
  2. RideRunner not playing nicely with RRMediaDb
    By MGD in forum RR Bug Tracker
    Last Post: 02-18-2009, 12:55 PM
  3. Replies: 2
    Last Post: 10-23-2007, 09:22 AM
  4. Error -2147024770 and Error 91 inside RR
    By Pistolen08 in forum MM Bugs
    Last Post: 04-02-2007, 04:15 AM
  5. Replies: 1
    Last Post: 01-03-2006, 12:17 PM
