Hi all,
I would like to contribute an opensource hardware that will act similar to the Venice module.
It is basically
Keystone Module -----> FTDI FT232-----> Virtual Com Port
so the configuration will be similar to the Venice Radio plugin.
I had made one prototype and is now able to control the module through serial command and hope to get some guidance from you guys.
From the example plugin located in the RRExtension Plugin Examples, I managed to compile and and get the plugin showed on the Plugin Manager. However, after searching through nearly 100 pages of search result in this forum, I was not able to figure out how to make the plugin appears in the radio configuration on RRConfig and therefore I was not able to integrate it into the " o RADIO" button when clicked.
Any advise or skeleton radio plugin code is really appreciated.
Cheers
JP
