The only text box in RR is for the OSK as far as I know - for those you have to use OSKTOVAR, OSKTEXT and similar commands.
If you want to display some other text box, then you have the option to make a label that looks like a text box and just use on screen buttons to type/change it OR you can simply make a screen in your application and embed it in RR as any external application (using load command). Then you'll have full control of what to do with your text box which you can then use to set variables in RR if desired.
LinkBack URL
About LinkBacks
