Page 13 of 52 FirstFirst ... 34567891011121314151617181920212223 ... LastLast
Results 121 to 130 of 519
Like Tree2Likes
Thread: BT Mobilephone Plugin
  1. #121
    Jan 2006
    Dublin, Ireland
    Has anyone got this working well on an Android 4.x Smart Phone please ?
  2. #122
    Raw Wave pierrotm777's Avatar
    May 2008
    Bordeaux, France
    I have an Xperia U in 4.x that run well
  3. #123
    May 2006
    Markham, Ontario, Canada
    Quote Originally Posted by pierrotm777 View Post
    I think that all bluetooth device can work with BlueSoleil, no ?
    I am not sure if bluetooth adapter with broadcom chipset would be supported by BlueSoleil because I usually install the driver straight from the chipset manufacturer. Even so Bluesoleil software is pricey while Broadcom driver can be downloaded free on its website.
  4. #124
    Jan 2006
    Dublin, Ireland
    I downloaded the Eval version of BS 10.0.453 and everything looking good. It now reads the phonebook.
    I have just one big issue and two minor ones.
    Minor Issue
    How do I set the ringtone for incoming calls ?
    Should I be able to hear ringtone when making an outbound call ?
    Major Issue
    I tested receiving an incoming call and the call screen correctly popped up. After shutting down RR, the next time I launched it, it just would not connect the PC to the Phone - The BT icon stayed Blue and did not change to Green The only way to correct this would seem to be a PC reboot. Does this sound like a BlueSoleil or a RR Plugin issue ?
    EDIT: I cannot get it to re-connect at all !!
    Regards
    C
  5. #125
    May 2008
    Bordeaux, France
    Quote Originally Posted by championc View Post
    Minor Issue
    Can you try these commands ?
    mobilephone_microvolume;x set the volume of the micro where x is 0 to 15
    mobilephone_speakervolume;x set the volume of the speaker where x is 0 to 15
    Major Issue
    Can you try to shut-down Bluesoleil and restart it and do again your tests ?
  6. #126
    Jan 2006
    Dublin, Ireland
    Sorry to be a complete newbie but where do I put these commands ?
  7. #127
    May 2008
    Bordeaux, France
    Sorry :-)
    OPen the Skintool program (C:\Program Files\RideRunner\SkinTool\Skintool.exe)
    Load RR and type the command you want to test into the first input line
  8. #128
    May 2008
    Bordeaux, France
    New little version: v1.0.6
    -add paired, unpaired and delete device
    -add stop and start BlueSoleil without quit RR
    -new update devices version
    I think that this version accept to list a device that isn't a phone . Can you test that and return me ?
    See post #34
  9. #129
    Feb 2011
    i've tested some of new commands with bluesoleil i think version 6 or 8 (with version 10 my usb card isn't recognized >.>), so far i got this:
    - mobilephone_settings_updatedevicelist: works now, i used it with TMR function and it updates the list with the devices, the only problem is that bluesoleil doesn't "update" the list automatically, so for example if i find a device called "Nokia" then it place on the list, but if Nokia is on the list and i change the name of the device the list doesn't update, i have to go in bluesoleil and press for find other devices, then the name updates. Also if the device is bluetooth active it's on the list also if the bluetooth is deactivated.
    -mobilephone_paired / mobilephone_unpaired: makes me crash ride runner (is possible now to pair directly inside riderunner writing the password for pair with osk? if so is AWSOME)
    -mobilephone_settings_updateserviceslist: also make crash ride runner
  10. #130
    Newbie Asterix1965's Avatar
    Jan 2007
    Hello Pierrottm777,
    thanks for the great job.
    If I click on the service list RR crashes
    For the rest, it all seems ok, now I do of other tests and fill you.
    I use BlueSoleil 10.0.453 version 1.06 of your plugin and the latest version of RR
  1. .net Bluetooth Mobilephone Plugin
    By lambosprit in forum RR Released Plugins
    Last Post: 02-24-2015, 10:11 PM
  2. Andrea Stereo USB mic SUMA & Mobilephone Plugin
    By Paul Murray in forum Road Runner
    Last Post: 09-06-2011, 06:37 PM
  3. for Mobilephone Plugin,help!
    By wy_nb in forum Road Runner
    Last Post: 12-22-2009, 07:23 PM
  4. Mobilephone Plugin help
    By Joshc8503 in forum RR Plugins
    Last Post: 12-21-2009, 09:44 AM
  5. MobilePhone v1.0.0.2 (alpha)
    By Lucifer in forum RR Plugins No Longer Supported
    Last Post: 02-19-2009, 04:27 PM
Tags for this Thread
