Page 14 of 52 FirstFirst ... 456789101112131415161718192021222324 ... LastLast
Results 131 to 140 of 520
Like Tree2Likes
Thread: BT Mobilephone Plugin
  1. #131
    Jul 2013
    Quote Originally Posted by Diavoletto View Post
    mobilephone_settings_updateserviceslist: also make crash ride runner
    Quote Originally Posted by Asterix1965 View Post
    Hello Pierrottm777,
    thanks for the great job.
    If I click on the service list RR crashes
    Me three
  2. #132
    Raw Wave pierrotm777's Avatar
    May 2008
    Bordeaux, France
    Hello Pierrottm777,
    For the rest, it all seems ok, now I do of other tests and fill you.
    I use BlueSoleil 10.0.453 version 1.06 of your plugin and the latest version of RR
    Do you use Carwings as skin ?
  3. #133
    Newbie Asterix1965's Avatar
    Jan 2007
    Use carwings only for testing, I use Simplistique and I'm making the skin for the phone .... if I can
  4. #134
    May 2008
    Bordeaux, France
    The best method before use this plugin is to do over the BlueSoleil menu:
    Search devices,paired these devices, search the device's name for each device and search the services for each device.
    After that if a device's list doesn't exist, when you go to the mobilephone menu the plugin go to the settings menu. Use the update device list , select a device and use the APPLY command !
  5. #135
    Jan 2006
    Dublin, Ireland
    Quote Originally Posted by pierrotm777 View Post
    Can you try these commands ?
    mobilephone_microvolume;x set the volume of the micro where x is 0 to 15
    mobilephone_speakervolume;x set the volume of the speaker where x is 0 to 15
    Is a particular ringtone already pre-assigned ? If I call my mobile, the screen pops up OK but no ringtone plays - should one ?
    More issues
    1. If I disconnect / reject the call from the screen (pressing the Red Hangup button), RR crashes / closes immediately.
    2. When I go into the dialer screen, the sync light flashes ...... but then never stops. I clicked on Debug On and it looked like the same records were being accessed over and over (looping through about 30 phone records)
    3. The phonebook files fill up with a couple of entries. The _MC file = 18 entries, _DC = 33, _SM - 10, _ME = 2 and _RC = 24. These are nowhere near my full phonebook or call logs. Maybe did I not leave it long enough ?
    MobilePhone v 1.0.6
    BlueSoleil v 10.0.453
  6. #136
    May 2008
    Bordeaux, France
    Quote Originally Posted by championc View Post
    No, the ringtone are define into your phone only ! I don't understand this issue
    The 3 buttons on the MOBILECALL.SKIN use a RADIOMUTE option:
    Code:
    B01,20,274,154,113,"RADIOMUTE;ON||WAIT;0.2||MOBILEPHONE_PICKUP",""
    B02,173,274,154,113,"MOBILEPHONE_TRANSAUDIO",""
    B03,326,274,154,113,"MOBILEPHONE_HANGUP||WAIT;0.2||RADIOMUTE;OFF||ESC",""
    Can you delete these options and try again ?
    Code:
    [Buttons]
    B01,20,274,154,113,"MOBILEPHONE_PICKUP",""
    B03,326,274,154,113,"MOBILEPHONE_HANGUP||ESC",""
    Into the .xml file, put the Update Phone Book to false!
    Into the last version , the screen of settings has a command 'MOBILEPHONE_SETTINGS_SYNCONOFF' that set to TRUE or FALSE this update (toggle function)
    The phonebook feature run very bad ! I must to change this code
  7. #137
    Jan 2006
    Dublin, Ireland
    Many thanks. I will try things tonight / tomorrow
    I assume the idea you want to make is that Sync start > Phonebook Updates > Sync stop ?
  8. #138
    May 2008
    Bordeaux, France
    Yes
  9. #139
    May 2008
    Bordeaux, France
    This version accept all world formatted phone number
    1-Put your phone number into the variable 'MOBILEPHONE_UNFORMATEDNUMBER'
    2-use the command 'MOBILEPHONE_UNFORMATEDNUMBER'
    3-the result is put automatically into the label 'MOBILEPHONE_DIALBOX'
    Phone number with (,),-,space or . accepted.
    ex:My old RRGooleMapsTools plugin use now this feature:
    1-Launch the RRGooleMapsTools plugin
    2-Load the menu
    3-Select 'Local Search'
    4-select the place type and use the go button
    5-un zoom (bug) and click on the place you want
    6-Use the button 'Send To RideRunner'
    7-If the phone change from red to green , click on the phone button
    Other new feature:
    Emergency dial command (or your own immediate dial button)
    "EMERGENCY","mobilephone_dial;991"
    Changed the mobilephone_* that wrote + and not + and added mobilephone_+ command!
    See post 34
  10. #140
    May 2008
    Bordeaux, France
    It's the first time than i use the RR events:
    In this new version:
    ONMOBILEPHONECONNECTED Raises an event when the phone is connected.
    ONMOBILEPHONEDISCONNECTED Raises an event when the phone is disconnected.
    ONMOBILEPHONERINGING Raises an event when an incomming call is detected.
    ONMOBILEPHONEINCALL Raises an event when you first answer a call
    ONMOBILEPHONEHUNGUP Raises an event when quit a call
    ONMOBILEPHONENETAVAIL Raises an event when first connect to a network.
    ONMOBILEPHONENETUNAVAIL Raises an event when first disconnect from a network.
    ONMOBILEPHONEBATTERYFULLCHARGE Raises an event when the battery is 100%
    See post #34
  1. .net Bluetooth Mobilephone Plugin
    By lambosprit in forum RR Released Plugins
    Last Post: 02-24-2015, 10:11 PM
  2. Andrea Stereo USB mic SUMA & Mobilephone Plugin
    By Paul Murray in forum Road Runner
    Last Post: 09-06-2011, 06:37 PM
  3. for Mobilephone Plugin,help!
    By wy_nb in forum Road Runner
    Last Post: 12-22-2009, 07:23 PM
  4. Mobilephone Plugin help
    By Joshc8503 in forum RR Plugins
    Last Post: 12-21-2009, 09:44 AM
  5. MobilePhone v1.0.0.2 (alpha)
    By Lucifer in forum RR Plugins No Longer Supported
    Last Post: 02-19-2009, 04:27 PM
Tags for this Thread
