Page 17 of 52 FirstFirst ... 789101112131415161718192021222324252627 ... LastLast
Results 161 to 170 of 520
Like Tree2Likes
Thread: BT Mobilephone Plugin
  1. #161
    Jan 2006
    Dublin, Ireland
    Hey all,
    I'm running with XP and use BT for both the GPS and my Phone. Without the Bluesoleil software, I can connect to my GPS OK but I have major problems with 10.0.457. Connecting the Phone can also be a bit hit and miss.
    Can anyone recommend a USB BT Dongle which they have working well with the BlueSoleil software ? I am reluctant to spend $42 on a simple Dongle from them in case this is not the issue. SHould I maybe try running with Win7 instead ? I wanted to stick with XP since it's booting in only about 30 secs.
    Regards
    C
  2. #162
    Raw Wave pierrotm777's Avatar
    May 2008
    Bordeaux, France
    Quote Originally Posted by championc View Post
    Regards
    C
    I have a feedback by hadaak that said me than the better compatible dongle with BS must to have a chipset CSR.
  3. #163
    Jan 2006
    Dublin, Ireland
    I found this one which looks close enough to fitting the bill. I just don't know about the PBAP possibilities.
    http://www.ebay.ie/itm/USB-2-0-Mini-...item3f28c8dbba
  4. #164
    Jun 2013
    Texas USA
    Hey all,
    Regards
    C
    I'm running XP Pro SP3, RR June13, BS 10.0.457. I'm using this BT dongle http://www.ebay.com/itm/MINI-USB-2-0...item2c6c826692 and it seems to work well. I bought 2 to have a backup just in case. It connects every time and right away.
    I also get the popup from BS shortly after my phone connects. HTC HD7 Windows Phone 7.8.
    I also have another issue. If I don't have the phone available to connect then within the first 10 minutes or so I'll get the error message "Riderunner encountered and error and needs to close." I click OK and RR closes. This only happens if the phone is not connected. I've never got the error when the phone is connected. Debug doesn't show anything.
    Nanner1
  5. #165
    Jan 2006
    Dublin, Ireland
    Do you only connect a phone or do you connect a GPS or any other device simultaneously ?
    And can you give me the ebay link again please - that one will not work.
  6. #166
    Jun 2013
    Texas USA
    Here is the link, hope it works. http://www.ebay.com/itm/MINI-USB-2-0...ht_2505wt_1174
    If not do an Ebay search for MINI USB 2.0 BLUETOOTH V2.0 EDR DONGLE WIRELESS ADAPTER
    The only BT device is the phone. I do have a GPS receiver that connects via USB. I only get the error if the phone is not connected. Seems like RR or the plugin keeps searching for and trying to connect the phone until it errors. System is still on the bench, hasn't been in the car yet. I've let it run a couple hours with the phone connected and no error. If the phone is not connected then it usually errors within the first 10 minutes or so.
    Nanner1
  7. #167
    May 2008
    Bordeaux, France
    If you use Windows 8 and the BT plugin Bluesoleil give a new version of this software who is compatible with W8 !
    This is the BlueSoleil 10.0.464.0
  8. #168
    May 2008
    Bordeaux, France
    New version is available see post #34 !
    new indicators:
    mobilephone_batterycharging TRUE/FALSE | Shows if the battery is charging.
    mobilephone_batteryisfull TRUE/FALSE | Shows if the battery is full.
    new events:
    ONMOBILEPHONECONNECTED Raises an event when the phone is connected.
    ONMOBILEPHONEDISCONNECTED Raises an event when the phone is disconnected.
    ONMOBILEPHONERINGING Raises an event when an incomming call is detected.
    ONMOBILEPHONEINCALL Raises an event when you first answer a call
    ONMOBILEPHONEHUNGUP Raises an event when quit a call
    ONMOBILEPHONENETAVAIL Raises an event when first connect to a network.
    ONMOBILEPHONENETUNAVAIL Raises an event when first disconnect from a network.
    ONMOBILEPHONEBATTERYFULLCHARGE Raises an event when the battery is 100%
    ONMOBILEPHONEEMERGENCY Raises an event when the phone number = 911 (US) or 112 (EU) (define into the .xml file)
    ONMOBILEPHONEVOICEON Raises an event when voice activation is on
    ONMOBILEPHONEVOICEOFF Raises an event when voice activation is off
    ONMOBILEPHONEEXTPOWERON Raises an event when an external power is connected to the phone
    ONMOBILEPHONEEXTPOWEROFF Raises an event when the phone use it's own battery
    ONMOBILEPHONE2NOTFOUND Raises an event when the phone 2 isn't found.
    This new version accept two phones device in the settings !
    If the main phone isn't found the plugin check if is found the second device !
  9. #169
    May 2008
    Bordeaux, France
    Quote Originally Posted by Nanner1 View Post
    Nanner1
    What OS do you use and what plugin version ?
  10. #170
    Jun 2013
    Texas USA
    I'm running XP Pro SP3, RR June13, BS 10.0.457. Plugin 1.0.7 right now but it's done it with 1.0.0, 1.0.2 and 1.0.4.
    Nanner1
  1. .net Bluetooth Mobilephone Plugin
    By lambosprit in forum RR Released Plugins
    Last Post: 02-24-2015, 10:11 PM
  2. Andrea Stereo USB mic SUMA & Mobilephone Plugin
    By Paul Murray in forum Road Runner
    Last Post: 09-06-2011, 06:37 PM
  3. for Mobilephone Plugin,help!
    By wy_nb in forum Road Runner
    Last Post: 12-22-2009, 07:23 PM
  4. Mobilephone Plugin help
    By Joshc8503 in forum RR Plugins
    Last Post: 12-21-2009, 09:44 AM
  5. MobilePhone v1.0.0.2 (alpha)
    By Lucifer in forum RR Plugins No Longer Supported
    Last Post: 02-19-2009, 04:27 PM
Tags for this Thread
