Page 18 of 52 FirstFirst ... 8910111213141516171819202122232425262728 ... LastLast
Results 171 to 180 of 520
Like Tree2Likes
Thread: BT Mobilephone Plugin
  1. #171
    Jan 2006
    Dublin, Ireland
    That eBay one looks absolutely identical to the one I bought. It also looks identical to a Bluesoleil one which costs $42. Mine works for the Phonebook so it can't be too bad a unit.
    Quote Originally Posted by Nanner1 View Post
    I do have a GPS receiver that connects via USB
    That's actually the conclusion I'm coming to - to have the phone as the only BT device. I've wasted far too much time going around in circles, getting I'm trying to get it working with iGO831. I think iGO may be restricted to work with com ports 1 thru 8 only. So what com port was your usb gps assigned and have you an ebay link to the one you got please ?
  2. #172
    Jun 2013
    Texas USA
    Quote Originally Posted by championc View Post
    I did try to find one that looked like the Bluesoleil one. They're both from China. The GPS receiver is this one http://www.ebay.com/itm/NEW-20-chann...item43a6d5ddab If the link doesn't work search for NEW 20 channel USB GPS Receiver for PC laptop computer. I did a quick search on Ebay and these are 39.00. I got mine a few months ago for 24.99. I was using a GlobalSAT BU353 which worked well. This works just as well but is smaller which is what I wanted as I will be mounting it on the dash at the base of the windshield. I used IGuidance back in 2007-2008 on my old carpc and really liked it. I used IGO8 on my All-in-one Chinese units that I've used since then and really like it too. Now that I decided to build a carpc again I found out that IGO8 for PC does not have voice or turn by turn so I'm giving Garmin Mobile PC a try. My GPS receiver is on COM6, directed HD Tuner on COM1. Hope some of this helps.
    Nanner1
  3. #173
    Jun 2013
    Texas USA
    I tried the 1.0.9 version but couldn't get it to work. It created all the folders and the install completed successfully. It didn't show up in the plugin manager. I tried 3 uninstalls, reboots and reinstalls. I had to go back to 1.0.7 and it's working again.
    Nanner1
  4. #174
    Jan 2006
    Dublin, Ireland
    Good man, just bought this one. Maybe I can finally see some light at the end of the tunnel.
    Has anyone integrated Garmin into any RideRunner skin ?
  5. #175
    Raw Wave pierrotm777's Avatar
    May 2008
    Bordeaux, France
    In this version , i have improved the auto swap phones feature , but i have always some issues with!
    By default , this feature is off. If you want to test it change False by True into the .xml file AutoSwapPhone>True</AutoSwapPhone> .
    The mobile phone screen indicate what phone is connected (1 or 2).
    See post #34
  6. #176
    Jan 2006
    Dublin, Ireland
    Hi again,
    Have you had any joy with the re-writing of the code to import the Phonebook ?
  7. #177
    May 2008
    Bordeaux, France
    Hi again,
    No , i have some issue with the phonebook and hope that the last SDK will explain me better how to do !
  8. #178
    May 2008
    Bordeaux, France
    Need help for convert some C++ lines in VB.NET please !!!
    Code:
    typedef BTSDKHANDLE (*Btsdk_OpenFile_Func)(const BTUINT8* file_name);
    typedef BTSDKHANDLE (*Btsdk_CreateFile_Func)(const BTUINT8* file_name);
    typedef BTUINT32 (*Btsdk_WriteFile_Func)(BTSDKHANDLE 	file_hdl, BTUINT8* 	buf, BTUINT32 	bytes_to_write);
    typedef BTUINT32 (*Btsdk_ReadFile_Func)(BTSDKHANDLE file_hdl, BTUINT8* buf, BTUINT32 len, BTBOOL *is_end);
    typedef BTUINT32 (*Btsdk_GetFileSize_Func)(BTSDKHANDLE 	file_hdl);
    typedef BTINT32 (*Btsdk_RewindFile_Func)(BTSDKHANDLE 	file_hdl, BTUINT32 		offset);
    typedef void (*Btsdk_CloseFile_Func)(BTSDKHANDLE 	file_hdl);
    typedef struct _BtSdkPBAPFileIORoutinesStru{
    	Btsdk_OpenFile_Func    		open_file;
    	Btsdk_CreateFile_Func  		create_file;
    	Btsdk_WriteFile_Func   		write_file;
    	Btsdk_ReadFile_Func    		read_file;
    	Btsdk_GetFileSize_Func 		get_file_size;
    	Btsdk_RewindFile_Func  		rewind_file;
    	Btsdk_CloseFile_Func   		close_file;
    } BtSdkPBAPFileIORoutinesStru, *PBtSdkPBAPFileIORoutinesStru;
  9. #179
    Mod - Driveline forum
    ClockWorK's Avatar
    Oct 2003
    Michigan
    Looking over this for a few minutes, I remember why I hate BlueSoleil. It looks like all of the single-line typedefs are functions. Fair enough I guess. But then the struct is calling for pointers to these functions.
    In windows API, GetProcAddress and LoadLibrary can be used to get an address to a function in a DLL. This might be what you need to do.
    Dear god...
  10. #180
    Aug 2010
    Bahrain
    Everybody hates BlueSoleil. -_-
  1. .net Bluetooth Mobilephone Plugin
    By lambosprit in forum RR Released Plugins
    Last Post: 02-24-2015, 10:11 PM
  2. Andrea Stereo USB mic SUMA & Mobilephone Plugin
    By Paul Murray in forum Road Runner
    Last Post: 09-06-2011, 06:37 PM
  3. for Mobilephone Plugin,help!
    By wy_nb in forum Road Runner
    Last Post: 12-22-2009, 07:23 PM
  4. Mobilephone Plugin help
    By Joshc8503 in forum RR Plugins
    Last Post: 12-21-2009, 09:44 AM
  5. MobilePhone v1.0.0.2 (alpha)
    By Lucifer in forum RR Plugins No Longer Supported
    Last Post: 02-19-2009, 04:27 PM
Tags for this Thread
