Page 19 of 52 FirstFirst ... 91011121314151617181920212223242526272829 ... LastLast
Results 181 to 190 of 517
Like Tree2Likes
Thread: BT Mobilephone Plugin
  1. #181
    Jan 2006
    Dublin, Ireland
    Quote Originally Posted by pierrotm777 View Post
    Need help for convert some C++ lines in VB.NET please !!!
    Code:
    typedef BTSDKHANDLE (*Btsdk_OpenFile_Func)(const BTUINT8* file_name);
    typedef BTSDKHANDLE (*Btsdk_CreateFile_Func)(const BTUINT8* file_name);
    typedef BTUINT32 (*Btsdk_WriteFile_Func)(BTSDKHANDLE 	file_hdl, BTUINT8* 	buf, BTUINT32 	bytes_to_write);
    typedef BTUINT32 (*Btsdk_ReadFile_Func)(BTSDKHANDLE file_hdl, BTUINT8* buf, BTUINT32 len, BTBOOL *is_end);
    typedef BTUINT32 (*Btsdk_GetFileSize_Func)(BTSDKHANDLE 	file_hdl);
    typedef BTINT32 (*Btsdk_RewindFile_Func)(BTSDKHANDLE 	file_hdl, BTUINT32 		offset);
    typedef void (*Btsdk_CloseFile_Func)(BTSDKHANDLE 	file_hdl);
    typedef struct _BtSdkPBAPFileIORoutinesStru{
    	Btsdk_OpenFile_Func    		open_file;
    	Btsdk_CreateFile_Func  		create_file;
    	Btsdk_WriteFile_Func   		write_file;
    	Btsdk_ReadFile_Func    		read_file;
    	Btsdk_GetFileSize_Func 		get_file_size;
    	Btsdk_RewindFile_Func  		rewind_file;
    	Btsdk_CloseFile_Func   		close_file;
    } BtSdkPBAPFileIORoutinesStru, *PBtSdkPBAPFileIORoutinesStru;
    My colleague in work says that you probably need to have the original code of the functions which are called in order to re-write them somewhat in order to know what the passing of the particular arguments does. Maybe PM me.
  2. #182
    Mod - Driveline forum
    ClockWorK's Avatar
    Oct 2003
    Michigan
    Also see this:
    http://www.codeproject.com/Questions...lback-Function
    Looks like some has converted this BlueSoleil code to C#. From C# to VB.Net should be a lot easier.
    edit: Actually, this might not apply directly, but I think it could be helpful.
  3. #183
    Jun 2013
    Texas USA
    In this version , i have improved the auto swap phones feature , but i have always some issues with!
    By default , this feature is off. If you want to test it change False by True into the .xml file AutoSwapPhone>True</AutoSwapPhone> .
    The mobile phone screen indicate what phone is connected (1 or 2).
    See post #34
    I tried 109 and 110. I can't get either one to install properly. I uninstalled 107, rebooted then installed 109. Same for 110. Neither one shows up in plugin manager. They both show up in add\remove programs. If I go back to 107 the phone works and it shows up in plugin manager. I'm running XP Pro SP3, RR June 2013 & BS10.
    Nanner1
  4. #184
    Jan 2006
    Dublin, Ireland
    I am just trying this plugin now. I can receive a call (the screen popup comes to answer a call). However, I cannot make a call. I type the number of my landline and click to call. The Green light starts to flash but nothing arrives to my landline.
    Have I missed a setting in BlueSoleil to setup for making a call out from RideRunner ?
  5. #185
    Raw Wave pierrotm777's Avatar
    May 2008
    Bordeaux, France
    Quote Originally Posted by championc View Post
    Do you use the Carwing Dynamics skin ?
  6. #186
    May 2008
    Bordeaux, France
    Quote Originally Posted by Nanner1 View Post
    Nanner1
    Try to shutdown ans restart your bluesoleil software i see what's happening !
  7. #187
    Jan 2006
    Dublin, Ireland
    I'm actually using Reborn. I will try now with Carwings. I try many times after complete restarts, with the same result
  8. #188
    Jun 2013
    Texas USA
    I restarted the PC but it still doesn't get loaded or show up in plugin manager. 107 installs and works just fine. I installed the AlbumArt plugin and it installed just fine and worked right away. I'm using a reskinned Carwings.
    Nanner1
  9. #189
    Jun 2005
    I have the same Nanner1's problem but i haven't 1.07 to try
    I using xp sp 3 and 1.10
    May 2008
    Bordeaux, France
    The last version is now the v1.1.0 . Can you try it and see if you have the same issue ?
  1. .net Bluetooth Mobilephone Plugin
    By lambosprit in forum RR Released Plugins
    Last Post: 02-24-2015, 10:11 PM
  2. Andrea Stereo USB mic SUMA & Mobilephone Plugin
    By Paul Murray in forum Road Runner
    Last Post: 09-06-2011, 06:37 PM
  3. for Mobilephone Plugin,help!
    By wy_nb in forum Road Runner
    Last Post: 12-22-2009, 07:23 PM
  4. Mobilephone Plugin help
    By Joshc8503 in forum RR Plugins
    Last Post: 12-21-2009, 09:44 AM
  5. MobilePhone v1.0.0.2 (alpha)
    By Lucifer in forum RR Plugins No Longer Supported
    Last Post: 02-19-2009, 04:27 PM
Tags for this Thread
