Page 2 of 52 FirstFirst 123456789101112 ... LastLast
Results 11 to 20 of 520
Like Tree2Likes
Thread: BT Mobilephone Plugin
  1. #11
    Raw Wave pierrotm777's Avatar
    May 2008
    Bordeaux, France
    I try to read the phone's contacts but my list is empty !
    http://www.mp3car.com/rr-plugins/154...ne-plugin.html
    Dim myphonebook As phoneBook = New phoneBook
    Dim result As String = " 0 " & vbCrLf
    For Each phonecontact In myphonebook.List
    result = result & "LST" & phonecontact.Number & "||" & phonecontact.Name & vbCrLf
    Next
    SaveContactToFile(result, MainPath & "MyContacts.txt")
    Where is my error please ?
  2. #12
    Jul 2013
    I Hope someone can help out a newbie.
    How do I install this plugin? I don't see any installer.
    May 2008
    Bordeaux, France
    This is only a source not a dll . Prefer the MobilePhone.NET plugin !
  4. #14
    Jul 2013
    Quote Originally Posted by pierrotm777 View Post
    Hi,
    I did put in my phones Bluetooth mac address and built it. If I put the dll in THE RR plugin folder it does not recognize it as a plugin.
    Moblephone.net plugin crashes RR half the time with me starting and closing RR. I was hoping this might work better for me.
  5. #15
    May 2008
    Bordeaux, France
    Quote Originally Posted by Philip21 View Post
    Hi,
    This is a compiled version. I have added an .xml file where you need to add your phone's mac address !
    NB:
    This version isn't also complete that the MOBILEPHONE.NET
    I should like to add an automatic load phone's book but need help and nobody want help me :-(
    See the post #34 for download !!!
  6. #16
    Jul 2013
    NB:
    Thanks pierrotm777 for the compiled version and for Fox_Mulder for this plugin.
    pierrotm777 I wish I knew how to help you automatic load phone's book (if you find out please post it so I could do that too that would be great to use) but as you can tell I don't know anything about coding, making RR Plugins or skinning. I wish I knew where to start learning.
    Do you know how to manually add your contacts (like in the mobilephone.net plugin?)
    I see the mobilephone_pc.txt file with a phone number in it and a picture of a pig but I can't get nothing to show up in the skin.
    I put in my phones MAC address and I can make and Receive calls and it doesn't seem like this plugin crashes RR like the mobilephone.net plugin did for me on occasion which is why I like this plugin.
    I would like to manually add my contacts (like in mobilephone.net plugin) also be able to see missed, Received & Dialled calls if possible, but what ever I try it shows nothing.
    I would really like to get the contacts & other lists working if possible.
    Any ideas what I can try to get it working in the supplied Carwings sample skin files?
    Thanks you very much.
  7. #17
    Jul 2013
    Also I don't know if it matters but I was looking through the MobilePhone Skin Commands.txt file and it was saying something about a .ini file. I don't have any .ini files with this plugin.
    Also do you know if everything in the MobilePhone Skin Commands.txt should work in the plugin or is most of that from the mobilephone.net plugin?
  8. #18
    May 2008
    Bordeaux, France
    It's an error of me . This plugin don't use a .ini file !
  9. #19
    May 2008
    Bordeaux, France
    I have found an very easy method for save a new contact into the phone but i don't understand actually how to save the phone's phone book .
    Each phone answer differently to the AT commands !!! And it's a problem
  10. #20
    Mod - Driveline forum
    ClockWorK's Avatar
    Oct 2003
    Michigan
    I've been down the AT command road. Some phones support all of the AT commands. Some do not. So it seemed like a dead end. It might be limited to GSM phones, and also by the software running on the phone. My Droid4 with the stock OS responds to AT commands correctly. But if I'm running a Cyanogen ROM, the AT commands don't do a thing.
  1. .net Bluetooth Mobilephone Plugin
    By lambosprit in forum RR Released Plugins
    Last Post: 02-24-2015, 10:11 PM
  2. Andrea Stereo USB mic SUMA & Mobilephone Plugin
    By Paul Murray in forum Road Runner
    Last Post: 09-06-2011, 06:37 PM
  3. for Mobilephone Plugin,help!
    By wy_nb in forum Road Runner
    Last Post: 12-22-2009, 07:23 PM
  4. Mobilephone Plugin help
    By Joshc8503 in forum RR Plugins
    Last Post: 12-21-2009, 09:44 AM
  5. MobilePhone v1.0.0.2 (alpha)
    By Lucifer in forum RR Plugins No Longer Supported
    Last Post: 02-19-2009, 04:27 PM
Tags for this Thread
