Page 20 of 52 FirstFirst ... 101112131415161718192021222324252627282930 ... LastLast
Results 191 to 200 of 520
Like Tree2Likes
Thread: BT Mobilephone Plugin
  1. #191
    Jun 2005
    Sorry, my version is the last, but it not shows up in plugin manager.
  2. #192
    Raw Wave pierrotm777's Avatar
    May 2008
    Bordeaux, France
    Quote Originally Posted by dreadlocks View Post
    What Bluesoleil version do you have ?
  3. #193
    Jun 2005
    Quote Originally Posted by pierrotm777 View Post
    10.0.417.0
    skin dfx
    xp
    thanks
  4. #194
    May 2008
    Bordeaux, France
    The last Bluesoleil version is IVT_BlueSoleil 10.0.464.0 . Can you try it ?
  5. #195
    Jun 2013
    Texas USA
    Try to shutdown ans restart your bluesoleil software i see what's happening !
    Did some more checking. Shutting down and restarting BlueSol does nothing. I updated my BlueSol to 10.0.464.0 as you suggested to another. I tested with plugin 1.0.7, works fine. Updated the plugin to 1.1.0 and it doesn't work. Does not show up in plugin manager but shows in Add/Remove programs. Roll back to 1.0.7 and works fine again.
    From debug.txt
    With 1.1.0 plugin version
    16:52:34.375: Plugin Manager: loading Global Plugins...
    16:52:34.453: Plugin Manager: Plugin Found: SkinTool
    16:52:34.453: Plugin Manager: Plugin loaded (Global): SkinTool
    16:52:34.469: Plugin Manager: Plugin Found: Weather
    16:52:34.469: Plugin Manager: Plugin loaded (Global): Weather
    16:52:34.703: Plugin Manager: Plugin Found: MobilePhone(.NET) plugin found but will be unable to create (most likely NOT registered)[skipped].
    16:52:34.797: Plugin Manager: Plugin Found: Mp3Art
    16:52:34.797: Plugin Manager: Plugin loaded (Global): Mp3Art
    16:52:34.797: Plugin Manager: loading Global Plugins Completed.
    with 1.0.7 plugin version
    16:55:45.781: Plugin Manager: loading Global Plugins...
    16:55:45.859: Plugin Manager: Plugin Found: SkinTool
    16:55:45.859: Plugin Manager: Plugin loaded (Global): SkinTool
    16:55:45.875: Plugin Manager: Plugin Found: Weather
    16:55:45.875: Plugin Manager: Plugin loaded (Global): Weather
    16:55:45.984: Plugin Manager: Plugin Found: MobilePhone(.NET)
    16:55:45.984: Plugin Manager: Plugin loaded (Global): MobilePhone
    16:55:51.719: Plugin Manager: Plugin Found: Mp3Art
    16:55:51.719: Plugin Manager: Plugin loaded (Global): Mp3Art
    16:55:51.719: Plugin Manager: loading Global Plugins Completed
    Worked from plugin version 1.0.0 up through 1.0.7. 1.0.9 and 1.1.0 have not worked for me. Hope you can help. Thanks.
    Nanner1
    XPPRO SP3, RRJUNE13, BS10.0.464
  6. #196
    May 2008
    Bordeaux, France
    Quote Originally Posted by Nanner1 View Post
    From debug.txt
    Nanner1
    I have an idea . Actually, i work on a speach recognizing feature but i am on vista on may be that the XP version is different (5.1 for XP and 5.3 for vista).
    I disable that and send you version without this version as soon as possible !!!
  7. #197
    May 2008
    Bordeaux, France
    Nanner1
    If you have a vista installed in another pc can you try the 1.1.0 version ?
  8. #198
    Feb 2011
    i've tested last version (1.1.0?) and it works tested with bluesoleil 8.0.338.0, just wondering if is possible to have a single number version? also is a little buggy expecially if you "reset" the settings it will only set 01;02;03;04;05 under the first number and also much times when i select a mobilephone in the setting list and i select it it still give me 01;02;03 set and not his MacAddress
  9. #199
    May 2008
    Bordeaux, France
    The SDK isn't the same as the las 10 SDK . For a better use , please update your Bluesoleil version !
  10. #200
    Nov 2013
    For the benefit of use newbies who are still trying to understand all this code, it would be really helpful to post a step by step guide to integrating the Carwings sample that comes with this plugin into the carwings skin. Understanding the parts and pieces to add for this skin, would help anyone trying to integrate the other samples into the other skins. i.e. what lines of code should be added where ??
  1. .net Bluetooth Mobilephone Plugin
    By lambosprit in forum RR Released Plugins
    Last Post: 02-24-2015, 10:11 PM
  2. Andrea Stereo USB mic SUMA & Mobilephone Plugin
    By Paul Murray in forum Road Runner
    Last Post: 09-06-2011, 06:37 PM
  3. for Mobilephone Plugin,help!
    By wy_nb in forum Road Runner
    Last Post: 12-22-2009, 07:23 PM
  4. Mobilephone Plugin help
    By Joshc8503 in forum RR Plugins
    Last Post: 12-21-2009, 09:44 AM
  5. MobilePhone v1.0.0.2 (alpha)
    By Lucifer in forum RR Plugins No Longer Supported
    Last Post: 02-19-2009, 04:27 PM
Tags for this Thread
