Page 21 of 52 FirstFirst ... 111213141516171819202122232425262728293031 ... LastLast
Results 201 to 210 of 520
Like Tree2Likes
Thread: BT Mobilephone Plugin
  1. #201
    Raw Wave pierrotm777's Avatar
    May 2008
    Bordeaux, France
    Quote Originally Posted by jcmcdougall View Post
    For the benefit of use newbies who are still trying to understand all this code, it would be really helpful to post a step by step guide to integrating the Carwings sample that comes with this plugin into the carwings skin. Understanding the parts and pieces to add for this skin, would help anyone trying to integrate the other samples into the other skins. i.e. what lines of code should be added where ??
    The installer copy automatically the mobilephone screens into the Carwings_Dynamic_Lite skin folder !
    If you use the dynamics menus , you just need to hold a button and choose into the list the PI-Mobilephone line !
    After that just use the buttons and for better help read the MobilePhone Skin Commands.txt file !!!
  2. #202
    May 2008
    Bordeaux, France
    I work on a new version that add the speech recognition feature ! That code run very very well .Just the call function has an issue ! But i hope found how to solve this issue !!!
    The code will run very well on Vista 32bits !!! You can change your language words into the settings !!!
  3. #203
    Feb 2011
    i've tested with version 6.4.249 and 8.0.338, the basic functions are working on my Nokia N82 and other serveral nokia phones, not working the sms indicator and got problems with the phonebook cause it says that the files are missing.
    And i have also tested with the 10.0.453 and works the same as on 6.4 and 8.0. I can't use the latest version (10.0.464) cause it doesn't recognize my usb card that i have just buy (this is the second-one that i buy).
    What i can suggest is to have the coice on some features, for example the double phone feature and the message that popup when phone is selected would be nice to have the possibility to set if have or not, if someone wants advanced bluetooth controls or just basics. And first of all really a goodwork, this one is the plugin that RR comunity was most missing i guess
  4. #204
    May 2008
    Bordeaux, France
    The problem with Bluesoleil is the compatibility :-(
    Code:
    1.0 Release
    Jan. 18th, 2008
    Initial version.
    1.0.1
    Jan. 24th, 2008
    Added HFP/HSP Audio Gateway APIs and structures.
    1.1.0 Alpha
    Jan. 31st, 2008
    Added Hands-free Unit/Headset APIs and structures.
    1.1.1
    Mar. 24th, 2008
    Added HFP/HSP Audio Gateway sample. Added HFP/HSP Device sample. Added HSP/HFP specific event.
    1.1.2
    Apr. 2nd, 2008
    Added call back functions of pairing and authentication. Added call back relevant macros.
    1.1.3
    Apr. 7th, 2008
    Added pairing APIs and relevant macros.
    1.1.4
    Apr. 15th, 2008
    Added call back functions of pairing and authentication. Added releavant call back events. Added Bluesoleil activating API. Added sample code of pairing and authentication.
    1.1.5
    May. 14th, 2008
    Added Hands-free Unit/Headset APIs about wavein/waveout device configuration.
    1.1.6
    May. 23rd, 2008
    Added Btsdk_AGAP_SetDialHandlerFlag function. Modified the description of the callback event BTSDK_APP_EV_AGAP_HF_LASTNUM_REDIAL_IND.
    1.1.7
    Jun. 5th, 2008
    Added offline activation APIs for BlueSoleil 6.x.
    2.0.0
    Oct. 15th, 2008
    Updated Hands-free/Headset profile from Version 1.1 to Version 1.5. Added APIs about setting and getting fixed pincode of local device. Modified the description of the API: Btsdk_GetAvailableExtSPPCOMPort
    2.0.1
    Feb. 26th, 2009
    Added SPP Profile sample application code.
    2.0.2
    Apr. 10th, 2009
    Added A2DP Profile APIs.
    2.0.4
    Sept. 22 nd, 2009
    Modified the API: Btsdk_GetRemoteRSSI
    2.0.5
    Nov. 27 th, 2009
    Added HID Profile structures and APIs.
    2.0.6
    Aug. 26th , 2010
    Added local SPP service APIs
    2.0.7
    Sep. 8th, 2010
    Added link key APIs.
    2.0.8
    Sep. 13th, 2010
    Added PBAP Profile APIs and sample code
    IVT BlueSoleil SDK Developer Guide
    3
    2.0.9
    Oct. 13th, 2010
    Added MAP profile APIs
    2.1.0
    Nov. 5th, 2012
    Added BLE GATT APIs
    2.1.1
    Feb. 28th, 2013
    Added AVRCP1.4 APIs Change Btsdk_EnumAVDriver to Btsdk_EnumAudioDriver
    2.1.2
    Mar. 11th, 2013
    Modify AVRCP event changed notification from XXX_RSP to XXX_NOTIF. Added MAP Server APIs
    2.1.3
    Jun.8 th, 2013
    Delete some AVRCP TG Sample codes.
  5. #205
    Jun 2013
    Texas USA
    Mobilecall skin and phonebook lists - questions
    Hi,
    I appreciate all your work on this plugin. It's working well as far as receiving and making calls. However, when I receive a call and the caller hangs up the mobilecall screen stays up and I have to close it with the hangup button. Same thing happens if I get a text and I have it read to me, when it finishes the mobilecall screen has to be closed with the hangup button. Is it supposed to detect that the call has ended and close on its own?
    I would also like to know what each of the phone lists are. I'm guessing mc is missed calls, dc is dialed calls, rc is received calls but I'm not sure about sm, me, or pc. When I do a sync I get some entries in the mc, dc, rc, me & sm. Nothing populates in the pc. None of the lists are even close to what displays on the phone.
    I've succeeded in having a sound played when there is an incoming call. It also plays when I initiate a call, not a problem though.
    Thanks,
    Nanner1
  6. #206
    May 2008
    Bordeaux, France
    See the RR events , may be ONMOBILEPHONEHUNGUP ?
    "ONMOBILEPHONEHUNGUP","ESC"
  7. #207
    May 2008
    Bordeaux, France
    Speech recognition is now available !
    You must edit the last line of the .xml file if you want change the language !
    <PhoneSpeechNumbers>zero,one,two,three,four,five,six,seven,eight,nine, more,star,sharp,delete,cancel,call,stop call,help call,-,-,-</PhoneSpeechNumbers>
    You can use 5 new events:
    ONMOBILEPHONESPEECHLOAD Raises an event when the phone speech recognition is loaded
    ONMOBILEPHONESPEECHUNLOAD Raises an event when the phone speech recognition is unloaded
    ONMOBILEPHONESPEECHHELP Raises an event when the phone speech recognition ask the speech help
    Change the last '-' by your own word:
    ONMOBILEPHONESPEECHSUPP1 Raises an event when the phone speech recognition ask the speech supplement 1
    ONMOBILEPHONESPEECHSUPP2 Raises an event when the phone speech recognition ask the speech supplement 2
    ONMOBILEPHONESPEECHSUPP3 Raises an event when the phone speech recognition ask the speech supplement 3
    see post 34
  8. #208
    Sep 2012
    Germany - Munich
    Very cool Features.
    And a small Trick. You can link directly the Postnumber #34:
  9. #209
    Dec 2006
    istanbul
    Seems like this plugin is far better and usefull than the others. I want to give it a go with my setup. Can someone please share the reborn skin files?
  10. #210
    Sep 2012
    Germany - Munich
    You can find the Reborn Skin in this Thread:
    http://www.mp3car.com/rr-released-sk...5-17-12-a.html
  1. .net Bluetooth Mobilephone Plugin
    By lambosprit in forum RR Released Plugins
    Last Post: 02-24-2015, 10:11 PM
  2. Andrea Stereo USB mic SUMA & Mobilephone Plugin
    By Paul Murray in forum Road Runner
    Last Post: 09-06-2011, 06:37 PM
  3. for Mobilephone Plugin,help!
    By wy_nb in forum Road Runner
    Last Post: 12-22-2009, 07:23 PM
  4. Mobilephone Plugin help
    By Joshc8503 in forum RR Plugins
    Last Post: 12-21-2009, 09:44 AM
  5. MobilePhone v1.0.0.2 (alpha)
    By Lucifer in forum RR Plugins No Longer Supported
    Last Post: 02-19-2009, 04:27 PM
Tags for this Thread
