Page 26 of 52 FirstFirst ... 161718192021222324252627282930313233343536 ... LastLast
Results 251 to 260 of 520
Like Tree2Likes
Thread: BT Mobilephone Plugin
  1. #251
    Raw Wave pierrotm777's Avatar
    May 2008
    Bordeaux, France
    Quote Originally Posted by jomama27 View Post
    I have got my phone to connect and I can make calls, but when someone calls me my phone itself rings, but rr doesn't make any sound or any indications of an incoming call. Also my phone book only goes trough the letter "D" in my contacts. I am running car wings lite dynamic and I installed the btmobilephone setup in post #247. any help would be greatly appreciated.
    You haven't a popup screen when someone call you ?
  2. #252
    Feb 2014
    No I don't get a pop up screen. I am pretty new to this stuff so I may have overlooked some install steps. I installed RR, then I installed the skins. Then I installed the bt mobile phone plug in. I had previously registered a a.DLL file when installing the
    mobilephone.Net plugin. I'm not sure if there was a separate a.DLL file to register when installing the btmobilephone plugin? But my phone will connect and I can make calls in car wings dynamic, but not in dfx 5.
  3. #253
    May 2008
    Bordeaux, France
    You use mobilephone.Net or BTMobilePHone ?
    I am a little beat bysy but i shall see the DFX5 update !!!!
  4. #254
    May 2008
    Bordeaux, France
  5. #255
    Variable Bitrate navputer's Avatar
    Jan 2007
    DFW Area
    I am interested in getting this setup to try out. To clarify to get this to work properly.
    1) Download, install and setup BlueSoleil / pair phone / make sure working properly first
    2) Download from post #34 to run the installer or post #254 (for DFX5 in my case)
    3) Make configuration changes such as MAC address
    Anything I am missing?
    My setup - Win7 32bit / RR 1/1/14 update / DFX 5.1
    Gee
  6. #256
    May 2008
    Bordeaux, France
    Quote Originally Posted by navputer View Post
    Yes !
    Download from the post 34
    When you run RR , If you click on your phone button, if the plugin see that the mac address is bad , it load the settings screen.
    Select your phone into the list !
  7. #257
    Jan 2007
    DFW Area
    Ok...great. Thanks for the follow-up.
    Gee
  8. #258
    Jan 2007
    DFW Area
    I see someone else stated they connected iPhone with Bluesoleil and I have a question. I have it connected (paired) but my iPhone 4 only shows 1 service available. Will this all still work? I have not yet setup on my carpc w/frontend yet...testing this part first.
    Using BS 8.0.370.0
    Gee
  9. #259
    May 2008
    Bordeaux, France
    The v8 isn't the v10.
    Use the v10 for best use !
  10. #260
    Jan 2006
    Dublin, Ireland
    After installing v1.1.2 (on Win7) I get an popup windows during startup of RR
    "Cannot find the requested data item, such as a data key or value"
  1. .net Bluetooth Mobilephone Plugin
    By lambosprit in forum RR Released Plugins
    Last Post: 02-24-2015, 10:11 PM
  2. Andrea Stereo USB mic SUMA & Mobilephone Plugin
    By Paul Murray in forum Road Runner
    Last Post: 09-06-2011, 06:37 PM
  3. for Mobilephone Plugin,help!
    By wy_nb in forum Road Runner
    Last Post: 12-22-2009, 07:23 PM
  4. Mobilephone Plugin help
    By Joshc8503 in forum RR Plugins
    Last Post: 12-21-2009, 09:44 AM
  5. MobilePhone v1.0.0.2 (alpha)
    By Lucifer in forum RR Plugins No Longer Supported
    Last Post: 02-19-2009, 04:27 PM
Tags for this Thread
