Page 28 of 52 FirstFirst ... 181920212223242526272829303132333435363738 ... LastLast
Results 271 to 280 of 520
Like Tree2Likes
Thread: BT Mobilephone Plugin
  1. #271
    Raw Wave pierrotm777's Avatar
    May 2008
    Bordeaux, France
    Quote Originally Posted by championc View Post
    I did not manually touch any config files - everything is obtained like you say to do. However, I think I selected MOBILEPHONE and NOT PI-MOBILEPHONE. I will try it later tonight.
    Any thoughts on how the error is coming ?
    What is exactly your error ! I don't understand !
  2. #272
    Jan 2006
    Dublin, Ireland
    The error is in post #265
    My config file is
    Code:
    <?xml version="1.0" encoding="utf-8"?>
    <cMySettings xmlns:xsi="http://www.w3.org/2001/XMLSchema-instance" xmlns:xsd="http://www.w3.org/2001/XMLSchema">
      <PhoneMacAddress>0C:DF:A4:0E:51:37</PhoneMacAddress>
      <PhoneMacAddress2>07:08:09:10:11:12</PhoneMacAddress2>
      <PhoneBookUpdate>True</PhoneBookUpdate>
      <PhoneBookList>ME,SM,RC,DC,MC</PhoneBookList>
      <SmsServiceCentreAddress>0102030405</SmsServiceCentreAddress>
      <EmergencyNumber>112</EmergencyNumber>
      <AutoSwapPhone>False</AutoSwapPhone>
      <PhoneSpeechNumbers>zero,one,two,three,four,five,six,seven,eight,nine,more,star,sharp,delete,cancel,call,stop call,help call,by name,-,-,-</PhoneSpeechNumbers>
    </cMySettings>
  3. #273
    Variable Bitrate navputer's Avatar
    Jan 2007
    DFW Area
    Quote Originally Posted by jomama27 View Post
    I have got my phone to connect and I can make calls, but when someone calls me my phone itself rings, but rr doesn't make any sound or any indications of an incoming call. Also my phone book only goes trough the letter "D" in my contacts. I am running car wings lite dynamic and I installed the btmobilephone setup in post #247. any help would be greatly appreciated.
    I am having similar problem. I can make calls but when someone calls me, my physical phone rings and nothing happens in DFX5 or Carwings Lite. I don't get a popup screen or any sound indications of incoming call in either skin. I have the mobilephone call skin in the skin folder. What am I missing?
    RR 3/14
    DFX 5.1
    Installed BT Mobilephone from post #34
    Win7 32bit
    Thanks for your help....
    Gee
  4. #274
    May 2008
    Bordeaux, France
    Do you use the profile mode or normal ?
  5. #275
    Jan 2007
    DFW Area
    I am using profile mode.
    Gee
  6. #276
    May 2008
    Bordeaux, France
    Quote Originally Posted by navputer View Post
    OK, for your mobilephone tests, can you uninstall mobile phone plugin and RR and install RR with the no profile mode (normal) and reinstall the plugin !!!
  7. #277
    Jan 2007
    DFW Area
    Hi Pierrotm777,
    Sorry for the late response on this and thanks for your help....
    I installed this on my main carpc in profile mode and I have all my other plugins working great so don't want to uninstall everything on it for now. However, I will try this on my test pc in non-profile mode and see if this works. I was hoping there was something else I missed in the install or some other setting. Anything else I can check to be sure? Also, are you using RR in non-profile mode?
    Thanks,
    Gee
  8. #278
    May 2008
    Bordeaux, France
    Hi Pierrotm777,
    Thanks,
    I have tried a new install with profile mode and run very well ! It's a W7 issue ?
  9. #279
    Jan 2007
    DFW Area
    Ok...thx for response. I will do some other checks in Windows 7 and my Bluetooth.
    Gee
  10. #280
    Jan 2006
    Dublin, Ireland
    Quote Originally Posted by pierrotm777 View Post
    Hi @pierrotm77
    I have done fresh install on both WinXP and Win7 and Both give me problems with v1.1.2 Force Closing RR. When I un-install v1.1.2, RR works OK. I have installed .Net 2.0, 3.0, 3.5 and 4.0
    What version of this plugin are you using ? Do you do roll up installs from older versions rather than a complete fresh install ?
  1. .net Bluetooth Mobilephone Plugin
    By lambosprit in forum RR Released Plugins
    Last Post: 02-24-2015, 10:11 PM
  2. Andrea Stereo USB mic SUMA & Mobilephone Plugin
    By Paul Murray in forum Road Runner
    Last Post: 09-06-2011, 06:37 PM
  3. for Mobilephone Plugin,help!
    By wy_nb in forum Road Runner
    Last Post: 12-22-2009, 07:23 PM
  4. Mobilephone Plugin help
    By Joshc8503 in forum RR Plugins
    Last Post: 12-21-2009, 09:44 AM
  5. MobilePhone v1.0.0.2 (alpha)
    By Lucifer in forum RR Plugins No Longer Supported
    Last Post: 02-19-2009, 04:27 PM
Tags for this Thread
