Page 29 of 52 FirstFirst ... 192021222324252627282930313233343536373839 ... LastLast
Results 281 to 290 of 520
Like Tree2Likes
Thread: BT Mobilephone Plugin
  1. #281
    Raw Wave pierrotm777's Avatar
    May 2008
    Bordeaux, France
    Quote Originally Posted by championc View Post
    Hi @pierrotm77
    I have done fresh install on both WinXP and Win7 and Both give me problems with v1.1.2 Force Closing RR. When I un-install v1.1.2, RR works OK. I have installed .Net 2.0, 3.0, 3.5 and 4.0
    What version of this plugin are you using ? Do you do roll up installs from older versions rather than a complete fresh install ?
    It use the FrameWork 3.5
  2. #282
    Feb 2011
    After reinstalling another version for win7 i had the plugin working no problems at loading, the first problem was about the "system.speech" cause i had a version of win7 lighted with speech recognition removed, then the next error was "Cannot find the requested data item, such as a data key or value" and i don't know why this error was caused with previous version of win7. I got some problems with the sound card on my carpc so i can't fully test it out at the moment but for now maybe the most stable version was the 1.1.0 (? don't remember) the one with single number no speech never gave me errors, but i have to fully test this one when i fix my carpc. Anyway still big thanks for the support and time for this important plugin, is really a good piece for RR comunity
    **about net. framework 3.5 watch out because it's part of win7 and is not possible to install apart, so i suggest to install a win7 original / fully and not lighted
    update: ok after some restart i got again the error "Cannot find the requested data item, such as a data key or value"..
  3. #283
    May 2008
    Bordeaux, France
    Quote Originally Posted by Diavoletto View Post
    Thanks for these return !
    With the last version , can try to change your xml file setinngs (<PhoneSpeechRecognition>False</PhoneSpeechRecognition>) and not True ?
  4. #284
    Jan 2006
    Dublin, Ireland
    I still have the problem of "Cannot find the requested data item, such as a data key or value" error, which pops up during the loading of the MobilePhone plugin. Is there some way that I can turn on some advanced debugging to give you a better idea as to what the problem is ? Does anyone still have a copy of 1.1.0 which they can share ?
  5. #285
    May 2008
    Bordeaux, France
    http://img.tapatalk.com/d/14/04/08/pytezeta.jpg
    What is you issue with the version 1.1.3 ?
  6. #286
    Jan 2006
    Dublin, Ireland
    1.1.2 is the version in post #34
  7. #287
    Feb 2011
    Quote Originally Posted by pierrotm777 View Post
    Tested, could not find the string PhoneSpeechRecognition so i've added it and nothing changed both (True and False)
    Also tryed disabling the PhoneBookUpdate but still same problem, at this point i really have no idea why this problem is caused
  8. #288
    May 2008
    Bordeaux, France
    That i can do is a version without speech !
  9. #289
    Feb 2011
    That's a good news atleast to checkout what causes the problem, also i would like to know if there is someone else that has the plugin fully working, i'm using win7 32bit en-US full and bluesoleil latest version full (not the demo)
  10. #290
    Feb 2011
    No news about the plugin? would like to have it working like before xD
  1. .net Bluetooth Mobilephone Plugin
    By lambosprit in forum RR Released Plugins
    Last Post: 02-24-2015, 10:11 PM
  2. Andrea Stereo USB mic SUMA & Mobilephone Plugin
    By Paul Murray in forum Road Runner
    Last Post: 09-06-2011, 06:37 PM
  3. for Mobilephone Plugin,help!
    By wy_nb in forum Road Runner
    Last Post: 12-22-2009, 07:23 PM
  4. Mobilephone Plugin help
    By Joshc8503 in forum RR Plugins
    Last Post: 12-21-2009, 09:44 AM
  5. MobilePhone v1.0.0.2 (alpha)
    By Lucifer in forum RR Plugins No Longer Supported
    Last Post: 02-19-2009, 04:27 PM
Tags for this Thread
