Page 3 of 52 FirstFirst 12345678910111213 ... LastLast
Results 21 to 30 of 518
Like Tree2Likes
Thread: BT Mobilephone Plugin
  1. #21
    Raw Wave pierrotm777's Avatar
    May 2008
    Bordeaux, France
    Quote Originally Posted by ClockWorK View Post
    I've been down the AT command road. Some phones support all of the AT commands. Some do not. So it seemed like a dead end. It might be limited to GSM phones, and also by the software running on the phone. My Droid4 with the stock OS responds to AT commands correctly. But if I'm running a Cyanogen ROM, the AT commands don't do a thing.
    Your work in Driveline is very cool and i should like to do the same thing for RR
  2. #22
    Jul 2013
    Looks like I'll have to stick with a picture of a text file with my contacts on them At least I can see them on the screen.
  3. #23
    May 2008
    Bordeaux, France
    Actually, i play with the libraries 32feet.NET and see what i can to do with !
  4. #24
    Mod - Driveline forum
    ClockWorK's Avatar
    Oct 2003
    Michigan
    32feet will let you dial and connect to a profile, but it doesn't transfer the audio. :-\
    Also, it's a pain to debug. If you need, I have VB.Net code that will dial the phone using 32feet
    And if you want to access the phonebook profile, you need to use an additional OBEX componenet called Brecham.
  5. #25
    May 2008
    Bordeaux, France
    Thanks for your help ! Yes , i should like to see your VB.NET code for read the phonebook and why not send a SMS
  6. #26
    Jun 2013
    Texas USA
    BT Mobilephone Plugin Contacts-Phonelists Question
    Thank you for the compiled version of this plugin. After several days of struggling with the .NET plugin I decided to try this one. It seems to be working so far for placing and receiving calls but I'm unable to get the contact list or any call list to display or even be created. Do these lists work at all with this plugin? Do they need to be in a particular location other than the phonebook folder? Is there any other info that can be added to the XML file that might get these working? Thank you again.
    Nanner
  7. #27
    May 2008
    Bordeaux, France
    The list must to be under the MobilePhone plugin folder into a folder named PhoneBook :
    C:\Program Files\RideRunner\Plugins\MobilePhone\PhoneBook\Mob ilePhone_PC.txt
    An example:
    0
    LST0102030405||Paul
    LST0607080910||Jean
    You load this list like that:
    "B01,650,73,150,60,"CLLOAD;C:\Program Files\RideRunner\Plugins\MobilePhone\PhoneBook\Mob ilePhone_PC.txt"
  8. #28
    Jun 2013
    Texas USA
    I tried it and it works. I appreciate your help. A few more questions about this plugin. Do the received, dialed, and missed lists populate? The answer and hangup buttons work but the transfer button doesn't transfer back and forth from the CARPC and phone.
    Code for the transfer button: B02,173,274,154,113,"MOBILEPHONE_TRANSAUDIO",""
    Thank you,
    Nanner1
  9. #29
    May 2008
    Bordeaux, France
    Quote Originally Posted by Nanner1 View Post
    No , i need to work on that.
    No, i can see that.
    What does the transfer button ?
  10. #30
    Jul 2013
    Quote Originally Posted by pierrotm777 View Post
    An example:
    0
    LST0102030405||Paul
    LST0607080910||Jean
    Thanks x2
    I got mine working too.
  1. .net Bluetooth Mobilephone Plugin
    By lambosprit in forum RR Released Plugins
    Last Post: 02-24-2015, 10:11 PM
  2. Andrea Stereo USB mic SUMA & Mobilephone Plugin
    By Paul Murray in forum Road Runner
    Last Post: 09-06-2011, 06:37 PM
  3. for Mobilephone Plugin,help!
    By wy_nb in forum Road Runner
    Last Post: 12-22-2009, 07:23 PM
  4. Mobilephone Plugin help
    By Joshc8503 in forum RR Plugins
    Last Post: 12-21-2009, 09:44 AM
  5. MobilePhone v1.0.0.2 (alpha)
    By Lucifer in forum RR Plugins No Longer Supported
    Last Post: 02-19-2009, 04:27 PM
Tags for this Thread
