Page 4 of 52 FirstFirst 1234567891011121314 ... LastLast
Results 31 to 40 of 520
Like Tree2Likes
Thread: BT Mobilephone Plugin
  1. #31
    Jun 2013
    Texas USA
    The tranfer button should switch the phone audio between the carpc and the phone.
  2. #32
    Raw Wave pierrotm777's Avatar
    May 2008
    Bordeaux, France
    I have found a method for load the Contacts from the Phone and create a custom list !
    BUT, some phone don't accept this method !(AT command issue)
    New version as soon as possible !
  3. #33
    Jun 2013
    Texas USA
    I have an HTC HD7 Windows Mobile 7.8. When you release it I'll do a test. Thanks.
    Nanner1
  4. #34
    May 2008
    Bordeaux, France
    This is a new version that read all Phone Book data from your phone and save them into several custom list !
    Now, all Phone's infos are visible (that was an issue into the old code that request too quickly the info)!
    Check if SMS is received !
    Speech recognition is now available !
    You must edit the last line of the .xml file if you want change the language !
    <PhoneSpeechNumbers>zero,one,two,three,four,five,six,seven,eight,nine, more,star,sharp,delete,cancel,call,stop call,help call,by name,-,-,-</PhoneSpeechNumbers>
    You can use 5 new events:
    ONMOBILEPHONESPEECHLOAD Raises an event when the phone speech recognition is loaded
    ONMOBILEPHONESPEECHUNLOAD Raises an event when the phone speech recognition is unloaded
    ONMOBILEPHONESPEECHHELP Raises an event when the phone speech recognition ask the speech help
    Change the last '-' by your own word:
    ONMOBILEPHONESPEECHSUPP1 Raises an event when the phone speech recognition ask the speech supplement 1
    ONMOBILEPHONESPEECHSUPP2 Raises an event when the phone speech recognition ask the speech supplement 2
    ONMOBILEPHONESPEECHSUPP3 Raises an event when the phone speech recognition ask the speech supplement 3
    Phone screen
    Settings screen
    Phone Contacts
    Phone Edit Contact
    Sms Send
    Phone's Alarms
    The plugin create a phone list of all devices paired with Bluesoleil !
    If your phone('s) are paired, go to the settings and select your device , and use the 'APPLY' button .
    !!! No need to rerun RR !!!
    Bluetooth Chipsets Supported
    BlueSoleil 10 supports mainstream chipsets such as CSR, Broadcom, ISSC, Texas Instruments, Atheros, 3DSP, Marvell, Accel Semiconductor, Conwise, etc. and supports more Bluetooth laptops, e.g. Lenovo ThinkPad, HP, Dell, Sony, ASUS, Samsung, TOSHIBA and LG etc.
    After the 1.1.6.0 , the plugin can run with the GpsLockout by Blue ZX3 plugin
    With this feature ON, the SMS screens are stopped when the car is in motion !
    For use this feature, edit the settings file MobilePhone.xml !
    <LockInMotion>true</LockInMotion>
    After the 1.1.7.1 , the plugin can translate a SMS message (before a SMS send or after a received SMS)
    For that, you need to install the plugin RRTANSLATOR .
    As soon as possible
    ----------oooooooo0000000000000oooooooo----------
    Bluesoleil Install
    See these explains on the Driveline thread
    How to configure the plugin:
    The best way is to check one time (first run) this option with true option (<PhoneBookListUpdate>true</PhoneBookListUpdate>) and see what phone book is found in your phone .
    For exemple, my Sony K610i return this list!
    <PhoneBookList>FD,LD,ME,SM,DC,RC,MC,MV,HP,BC</PhoneBookList>
    If you see the phone book ME,SM,DC,RC and MC then use these settings for all time !
    <PhoneBookListUpdate>false</PhoneBookListUpdate>
    <PhoneBookList>ME,SM,DC,RC,MC</PhoneBookList>
    After the version 1.1.7.0, each time you run RR, the phone book DC,RC and MC are always updated !
    And, if PhoneBookUpdate is set to true (<PhoneBookUpdate>true</PhoneBookUpdate>), ME and SM are also updated and a MT file is build.
    You must wait several minutes for obtain this MT file !
    MT = ME +SM .
    SMS read and write:
    Your phone must understand the AT commands AT+CNMI=? , AT+CMTI=? and AT+CSCA=? .
    If CNMI command is accepted, try the command AT+CNMI=2,1,0,0,0 . If the return is OK, the ckeck SMS will be accepted !
    If CMTI command is accepted, try the command AT+CMTI=? . That must return you the number of SMS found .
    If the phone accept this command, the Sms Service Centre Address is saved automatically !
    ex: <SmsServiceCentreAddress>+33xxxxxxxxx</SmsServiceCentreAddress>
    For receive or send SMS, your phone must understand the AT command AT+CMGF=?.
    The plugin use the PDU mode AT+CMGF=0 for read or write the SMS (not the text mode AT+CMGF=1).
    For these tests, you can use the DEBUG ON window (RR command is MOBILEPHONE_DEBUGON )
    You can also edit the MobilePhone_ATCMD.lst file with the AT command you want to test !
    PS: I think the iPhone don't accepted this feature !
    ----------oooooo PBAP MAP PAN AVRCP Version oooooo----------
    This new version use the ClocWork code in it's future DriveLine version .
    I must to say a great thank to him for this share !
    This new code extract directtly 5 vcard files and convert these vcard to RR Lists !!!
    PAN,MAP and AVRCP feature are added!
    This version begin with the V1.2.1 version !
    We have a bug on this version that kill RR after the vcard extract !
    ----------oooooo Know issue oooooo----------
    If you have found an incompatibility between BTMobilePhone and the Vehicule Maintenace plugin !
    If you have found an incompatibility between BTMobilePhone and the RRGoogleMapsTools plugin !
    In the BTMobilephone xml setting file , define RunOnStart as false !!!!!!
    It's true for the two BTMobilePhone version !!!!
    It's result that the BT connection isn't done on RR start, but only when you click the first time on the button Phone(or 'MOBILEPHONE' RR command) !!!
  5. #35
    Jan 2006
    Dublin, Ireland
    Super stuff. I can't wait to try it out BUT ....
    The instructions refer to a mobilephone.ini file. This does not seem to have been part of the installation exe.
    Regarding the Phonebook, I have an Android 4.1 Smartphone. Does your plugin support downloading of my phones' phonebook ? It's just that BlueSoleil don't seem to support any Android JellyBean Smartphones using PBAP - I've a Samsung Galaxy S2
  6. #36
    Jul 2013
    Quote Originally Posted by pierrotm777 View Post
    http://www.mediafire.com/?1mdkujm8e447k89
    If your phone('s) are paired, go to the settings and select the your device , and use the 'APPLY' button .
    Rerun RR , that all !
    Seems to work great on my iPhone on my home computer.
    Now I just need to put it in my carputer.
    Thanks!!!!!
  7. #37
    Jun 2013
    Texas USA
    I've posted twice to this thread in the last several days but they haven't shown up. Thank you for the help with the contacts list. Transfer switches between the phone and carpc. I have an HTC HD7 Windows mobile 7.8. I'll test my phone with the new version.
    Thanks.
    Nanner1
  8. #38
    May 2008
    Bordeaux, France
    Quote Originally Posted by championc View Post
    Sorry , this version use only a .xml file and not a .ini file (an error of me)
    If Bluesoleil don't accept your Android phone , you can't use this plugin !
    This plugin need that the phone accept Bluesoleil SDK and the AT commands !
    See the post 31 for a new installer with the info updated !!!
    PBAP issue see this post
    http://forums.androidcentral.com/and...-vehicles.html
  9. #39
    Jan 2006
    Dublin, Ireland
    Sorry, I check again but do not see any *.XML files in the Plugins/MobilePhone Folder
    I checked again and see that I can manually select Phone Manu as SmartPhone and phone model as Misc.
    I have pairing working but when running Ride Runner, I just cannot seem to get it to work the Bluetooth within it. I mean, when I run with the Carwings Lite, the BT icon is still OFF. Where can I check this ?
    Debug says
    16:06:02.656: Plugin Manager: Plugin Found: MobilePhone(.NET) plugin found but will be unable to create (most likely NOT registered)[skipped].
  10. #40
    May 2008
    Bordeaux, France
    Debug says
    The .xml file is build when RR load the plugin the first time .
    After this first time , you can edit the .xml and replace the default mac address 01:02:03:04:05:06 by your phone's mac address or use the settings ! (Plugin manager and settings button)
  1. .net Bluetooth Mobilephone Plugin
    By lambosprit in forum RR Released Plugins
    Last Post: 02-24-2015, 10:11 PM
  2. Andrea Stereo USB mic SUMA & Mobilephone Plugin
    By Paul Murray in forum Road Runner
    Last Post: 09-06-2011, 06:37 PM
  3. for Mobilephone Plugin,help!
    By wy_nb in forum Road Runner
    Last Post: 12-22-2009, 07:23 PM
  4. Mobilephone Plugin help
    By Joshc8503 in forum RR Plugins
    Last Post: 12-21-2009, 09:44 AM
  5. MobilePhone v1.0.0.2 (alpha)
    By Lucifer in forum RR Plugins No Longer Supported
    Last Post: 02-19-2009, 04:27 PM
Tags for this Thread
