Page 5 of 52 FirstFirst 123456789101112131415 ... LastLast
Results 41 to 50 of 517
Like Tree2Likes
Thread: BT Mobilephone Plugin
  1. #41
    Jul 2013
    pierrotm777:
    I wanted to thank you for working on this plugin it is great.
    The phone book list loads good from my phone but have a question with the populated received list. If the person that called is not in the contacts it just leaves a blank line in the list.
    I don't know if it is possible but is there a way to have the phone # show up in the list or maybe say unknown?
    Raw Wave pierrotm777's Avatar
    May 2008
    Bordeaux, France
    New version , please see the post #34
  3. #43
    Jul 2013
    Quote Originally Posted by pierrotm777 View Post
    Thanks for the update,
    I am having a different performance with the new version compared to the last version. The newest version does not display my signal strength anymore and the display manufacture name changes from Apple to something else (see pictures) and phone model # changes from the manufacture model # (see pics) it changed the model # from iPhone 4.1 to something different.
    I also get a "pop up" with the newest version, It is a little window with title MobilePhone and says +CGSN: (It displays my serial #)
    I am not sure if I am doing it right but with both versions I also can not get my 2 paired phones to show up in the plugin settings. Both of my phones are paired in Bluesoleil. It only shows up the first phone I ever used the plugin with.
    EDIT: The signal strength will start working once I close out the pop up.
  4. #44
    Jul 2013
    This is a new version that read all Phone Book data from your phone and save them into several custom list !
    No all Phone's infos are visible (that was an issue into the old code that request too quickly the info)!
    http://www.mediafire.com/?01y0u4v4lqjj292
    Phone screen
    Attachment 70019
    Settings screen
    Attachment 70020
    The plugin create a phone list of all devices paired with Bluesoleil !
    If your phone('s) are paired, go to the settings and select your device , and use the 'APPLY' button .
    !!! No need to rerun RR !!!
    To DO:
    -Check if SMS is received !
    -Read SMS
    -Write SMS
    Quick question.
    When I use the Carwings I get a generic Windows folder icon next to each name in the phone book list. In the DFX skin it is not there. How can I remove the generic folder icon? I like your Bluetooth Icon next to them
    Can't wait for the SMS version
  5. #45
    May 2008
    Bordeaux, France
    Can you send me your MOBILEPHONE.skin ?
    About the signal strength, i think than you use :
    I06,151,58,102,14,"FILE;$mobilephone_signalstrengt h$"
    Replace this line by:
    S01,151,58,102,14,151,58,102,14,H,"h_slider\bar.pn g",,60,"mobilephone_signalstrength",""
    IMG,151,58,102,14,"h_slider\background.png",all
    The second line isn't important !
    About the icon :
    RideRunner Skin
    RRScreen MobilePhone.
    MOBILEPHONE_OFF.png,MOBILEPHONE_OFF.png,MOBILEPHON E_ON.png,MOBILEPHONE_DOWN.png,,,Indicators\BT_01.png
    You need to have the BT_01.png file into your skin folder under the folder Indicators
    I see that you have +CGMI added before the Phone Manufacturer, i have solved that .
  6. #46
    Jul 2013
    About the icon :
    RideRunner Skin
    Here is my skin file.
    I got the icon working.
    Attached Files Attached Files
  7. #47
    May 2008
    Bordeaux, France
    Cool!
  8. #48
    May 2008
    Bordeaux, France
    New version in the post #34 . Now, the plugin check if a new SMS is received !!!
  9. #49
    Jul 2013
    Thanks again for a quick update !!
    Will SMS received work with (iMessages, Apple's version of messaging)?
    It don't work on my computer. I sent a text from a LG Lotus to the iPhone and no notifications.
    What I have noticed with this version.
    No more pop up.
    Signal meter works.
    Display own # now working
    +CGMI still showing up
    How does the battery charging work? only when it is plugged in and charging or when battery is above a certain %?
    It seems like the light is on all the time now.
  10. #50
    May 2008
    Bordeaux, France
    Quote Originally Posted by Philip21 View Post
    I hacen't iPhone and don't do test !
    If LG Lotus is well an email software , it's normal , SMS isn't EMAIL .
    Send an sms with your iPhone to your iPhone number , id do my test like that !
    Do you use the last version? Can you send me a picture ?
    I have done an error with the charging led that is on if the power is 100%.
    It's a bad utility of this led that must to indicate if the phone is connected to a power charger !
  1. .net Bluetooth Mobilephone Plugin
    By lambosprit in forum RR Released Plugins
    Last Post: 02-24-2015, 10:11 PM
  2. Andrea Stereo USB mic SUMA & Mobilephone Plugin
    By Paul Murray in forum Road Runner
    Last Post: 09-06-2011, 06:37 PM
  3. for Mobilephone Plugin,help!
    By wy_nb in forum Road Runner
    Last Post: 12-22-2009, 07:23 PM
  4. Mobilephone Plugin help
    By Joshc8503 in forum RR Plugins
    Last Post: 12-21-2009, 09:44 AM
  5. MobilePhone v1.0.0.2 (alpha)
    By Lucifer in forum RR Plugins No Longer Supported
    Last Post: 02-19-2009, 04:27 PM
Tags for this Thread
