Page 6 of 52 FirstFirst 12345678910111213141516 ... LastLast
Results 51 to 60 of 520
Like Tree2Likes
Thread: BT Mobilephone Plugin
  1. #51
    Raw Wave pierrotm777's Avatar
    May 2008
    Bordeaux, France
    I try to add these two events for the battery status 'POWER EXTERNAL CONNECTED and FULL CHARGE) , i receive no event !
    i Have added a structure as:
    Code:
        'Battery Info
        <StructLayout(LayoutKind.Sequential)> _
        Public Structure BtSdkInformBattStatusReqStru
            Public size As UInt32
            Public Id As UInt16
        End Structure
    and my code is:
    Code:
    Case BTSDK_HFP_APP_EventCodeEnum.BTSDK_AVRCP_BATTERYSTATUS_EXTERNAL
                    ExternalPowerIsConnected = True
                    RaiseEvent PhoneInCharge()
                Case BTSDK_HFP_APP_EventCodeEnum.BTSDK_AVRCP_BATTERYSTATUS_FULL_CHARGE
                    BatteryFullCharge = Marshal.ReadByte(param)
    The SDK say:
    Definition
    typedef struct _ BtSdkInformBattStatusReqStru { BTUINT32 size; BTUINT8 id; } BtSdkInformBattStatusReqStru, *PBtSdkInformBattStatusReqStru;
    Description
    This structure is used in the input parameter of function 错误!未找到引用源。
    Members
    size
    Size of the stucture, in bytes. Should be size >= sizeof(BtSdkInformBattStatusReqStru).
    id
    Battery status, see the following table.
    id
    Description
    BTSDK_AVRCP_BATTERYSTATUS_NORMAL
    Battery operation is in normal state
    BTSDK_AVRCP_BATTERYSTATUS_WARNING
    Unable to operate soon. Specified when battery going down
    BTSDK_AVRCP_BATTERYSTATUS_CRITICAL
    Can not operate any more. Specified when battery going down.
    Connecting to external power supply
    When the device is completely charged.
    Somebody can help me please ?
  2. #52
    Mod - Driveline forum
    ClockWorK's Avatar
    Oct 2003
    Michigan
    I don't know if you'll receive AVRCP events when connected to the HFP profile. Are you also connecting to the AVRCP profile in some way?
  3. #53
    Jul 2013
    Quote Originally Posted by pierrotm777 View Post
    I hacen't iPhone and don't do test !
    Send an sms with your iPhone to your iPhone number , id do my test like that !
    Do you use the last version? Can you send me a picture ?
    I just downloaded again the version in post 34 it says version 1.01 to make sure it was the latest one.
    I tried send an sms with my iPhone to my iPhone number.
    It did not work.
    I also tried to use the LG Lotus which is a basic cell phone to text the iPhone and did not get alert.
    Can anyone else confirm that it is working? (probably my phones) or me
    Here is a pic of the CGMI still showing up.
    I am trying to make a DFX skin for the MobilePhone settings page and changing the stock DFX skin that was used for the Mobilephone.net plugin. Hopefully I will be done in the next couple days.
    First time trying to do this so it will not be perfect.
  4. #54
    Jul 2013
    Can someone help out a newbie on skinning.
    I use the RR skin editor because I am not good at doing it any other way.
    If I copy the custom list from the carwings mobilephone_settings.skin and copy it over to my DFX mobilephone_settings.skin it works! (I copied all the other stuff over too!)
    But then if I try to swap the forground & select colors it does not work.
    I did not change any thing else.
    I can see and select the items in the list but it will not update the other fields like it does in the Carwings version like update the MAC address, phone name, phone status etc.
    EDIT:
    Fixed it!
    For some reason when I edit and or change things in RR screen editor it removes some of the ending commands like:
    It removes ",,,Indicators\BT_01.png" out of the following line
    MOBILEPHONE_SETTINGS_off.png,MOBILEPHONE_SETTINGS_ off.png,MOBILEPHONE_SETTINGS_on.png,MOBILEPHONE_SE TTINGS_off.png,,,Indicators\BT_01.png
    and it also removed ,00,"","MOBILEPHONE_SETTINGS_UPDATEINFODEVICE","" out of the following line:
    SC01,403,87,353,280,255,128,0,1,20,30,200,200,200, 255,255,255,TRUE,16,"Arial:B",00,"","MOBILEPHONE_S ETTINGS_UPDATEINFODEVICE",""
    Don't understand why but once I added it back it worked again.
    EDIT X2 NEED MORE HELP
    Now I am trying to create a button in the mobilephone.skin that will take me to the mobilephone_settings.skin so I don't have to go through the plugin manager to get there.
    I don't know how to do it.
    All I know how to do is look at other code in the skin files and or RR Skineditor
    I tried "LOAD;MOBILEPHONE_SETTINGS.skin" and that loads the skin page but does not show or populate my paired devices in the list, phone name, phone status either.
    How can I load the mobilephone_settings.skin page and show everything like it does if I go through the plugin manager to get to the mobilephone_settings.skin page?
    Now if I go through the plugin settings page first, then I can click on the button I created in the mobilephone.skin page and it shows everything.
    It's probably real simple and easy for most of you skinners but I don't understand any of the code.
  5. #55
    Feb 2011
    i've tested this and for now i got it to work but there are some bugs (things i can't get to work) i use bluesoleil 8.0.370.0:
    - Battery label says always 100
    - Signal label says always 0
    - mobilephone_clear is not working (on mobilephone.net plugin works)
    - mobilephone_incomingcall indicator doesn't work
    - mobilephone_incall indicator doesn't work
    - mobilephone_messagerecived indicator doesn't work
    I've tested with Nokia n82 (Symbian s60v3 if i remember), the most important things to fix in my opinion are clear command and indicators for incoming call and incall.
    Last thing would be better to change the RESUME wehen call end, cause if music is paused then it starts, would be better to save the status of the player when call is arriving and when call is end restore the player status
    Hope to have helped
  6. #56
    Jul 2013
    Quote Originally Posted by Diavoletto View Post
    Hope to have helped
    I am just confirming what happens on my system.
    Battery label says always 100 (Mine stays at 100 too)
    Signal label says always 0 (mine works most of the time) once in a while I have to go into bluesoleil and disconnect everything that is currently connect to the phone (keep the phone paired still) and then reopen RR and then it works again.
    mobilephone_incomingcall indicator doesn't work (Don't work for me too)
    mobilephone_incall indicator doesn't work (Don't work for me too)
    mobilephone_messagerecived indicator doesn't work (Don't work for me too)
    mobilephone_clear is not working (on mobilephone.net plugin works) (Don't work for me too) I just use mobilephone_del
    Overall I am very happy to have this plugin!! I kept on getting RR crashed with mobilephone.net plugin
    I have a question though:
    Does anyone know if there is a way to make the Mobilecall.skin (the skin when someone calls you) be able to close out the skin or be able to minimize the screen while in a call that way I can still move around in RR when in a call?
  7. #57
    May 2008
    Bordeaux, France
    Quote Originally Posted by ClockWorK View Post
    I don't now what is AVRCP profile ! With mobilephone , we use only hands free no ?
    Do you know how i can to check if the power is connected ? For the full mention , it's easy !
  8. #58
    May 2008
    Bordeaux, France
    About the settings, use the command 'mobilephone_settings'
    In fact, skineditor delete the optionals onclclick and ondblclclick commands . It's a know issue !
  9. #59
    May 2008
    Bordeaux, France
    Quote Originally Posted by Philip21 View Post
    Battery isn't always to 100 (for me)
    Signal level is update after 30s
    Use mobilephone_messagereceived and not mobilephone_messagerecived indicator (ok for me)
    I have added :
    mobilephone_clear command !
    mobilephone_incommingcall indicator !
  10. #60
    May 2008
    Bordeaux, France
    How to keep the custom list options into SkinEditor !
    Edit the file C:\Program Files\RideRunner\Skin Editor\objects.txt !
    Replace the line:
    /, (SC) Custom List
    Custom List,SC,x,y,w,h,forecolor R;RGB,G,B,backcolor R;RGB,G,B,selected color R;RGB,G,B,select color R;RGB,G,B,trs,font size;FONT,font name
    by
    /, (SC) Custom List
    Custom List,SC,x,y,w,h,forecolor R;RGB,G,B,backcolor R;RGB,G,B,selected color R;RGB,G,B,select color R;RGB,G,B,trs,font size;FONT,font name,00,Nothing,One Click,Double Click
    Each RR install delete this file , so if the skineditor hasn't the same version, backup this file before your new RR install !!!
  1. .net Bluetooth Mobilephone Plugin
    By lambosprit in forum RR Released Plugins
    Last Post: 02-24-2015, 10:11 PM
  2. Andrea Stereo USB mic SUMA & Mobilephone Plugin
    By Paul Murray in forum Road Runner
    Last Post: 09-06-2011, 06:37 PM
  3. for Mobilephone Plugin,help!
    By wy_nb in forum Road Runner
    Last Post: 12-22-2009, 07:23 PM
  4. Mobilephone Plugin help
    By Joshc8503 in forum RR Plugins
    Last Post: 12-21-2009, 09:44 AM
  5. MobilePhone v1.0.0.2 (alpha)
    By Lucifer in forum RR Plugins No Longer Supported
    Last Post: 02-19-2009, 04:27 PM
Tags for this Thread
