Page 8 of 52 FirstFirst 123456789101112131415161718 ... LastLast
Results 71 to 80 of 517
Like Tree2Likes
Thread: BT Mobilephone Plugin
  1. #71
    Jan 2006
    Dublin, Ireland
    Quote Originally Posted by pierrotm777 View Post
    When you have an issue with bluesoleil , a cool option is to shutdown bluesoleil and run again bluesoleil with it's menu !
    Is there a way to do this automatically ? I have a problem sometimes with BlueSoleil talking to my BT GPS and I think this will be my solution. I'm sure I will also run into BlueSoleil to phone issues too
  2. #72
    Jan 2006
    Dublin, Ireland
    I've been playing around with this plugin for the past week with limited success. I have a BT GPS and so, the BT to the phone is having great difficulty with attaching to my phone. It seems like I get one or the other but really not both. Has anyone else experienced a similar issue ? I've BlueSoleil 8.0.395.0
    Also, regarding the transfer of contacts, while my phone has over 300 possibly, I got ONE contact appearing when I pressed the Phone button and THREE when pressing the Sim Card button. I got NONE with the Book button. However, from within BS, I can see the whole lot when clicking on View Contacts
  3. #73
    Raw Wave pierrotm777's Avatar
    May 2008
    Bordeaux, France
    Quote Originally Posted by championc View Post
    May be can you update your Bluesoleil version to the 10.0.453.0 ?
    About the contacts transfer, i work on that . The problem is that the Bluesoleil SDK don't explain well how to use it .
    If some one can help me ?
  4. #74
    Mod - Driveline forum
    ClockWorK's Avatar
    Oct 2003
    Michigan
    As soon as I have some time, I will update my code for BS 10 and the new functions. Just need time. Busy with work projects and trying to find a house.
  5. #75
    May 2008
    Bordeaux, France
    Quote Originally Posted by ClockWorK View Post
    Again and always ClockWorK , thanks for your share and the time than you give !
  6. #76
    May 2008
    Bordeaux, France
    New little version v1.0.3
    -Simplify the settings screen
    -Added a new command that give a list of all services accepted by your phone "mobilephone_settings_updateserviceslist" (see the settings screen)
    -now the plugin don't use the 32feet.NET dll for create the devices list and it's replaced by a full Bluesoleil code (great thanks to ClockWorK and it's Driveline code that help me)
    -add volume commands for micro "mobilephone_microvolume;X" and for speaker "mobilephone_speakervolume;X" for X = 0 to 15 .
    -add a redial command "mobilephone_redial"
    With this new installer, i have added an old Hyperterminal program that help me with the AT command:
    About the SMS event, if the phone isn't ready , the event don't run !
    For now, i don't understand why the plugin don't send the good command AT, but with hyperterminal:
    -see the com port than BT give to your phone.
    -run hyperterminal,choose the good port and use baud rate 9600 by example .
    -type AT and return .
    -if you see AT and OK, the ech is ON but if you see only OK, type ATE1 and return
    -for set to ON the SMS check, type AT+CNMI=1,1,0,0,0 and return , and you are ready .
    -quit hyperterminal !
    Run RR and when you phone is connected send you a SMS, you will see the sms indicator blink.
    This is just for test. Hope a better and comfortable method !
  7. #77
    Jul 2013
    I am trying to use hyperterminial but I need some help again
    In Windows device manager there is 2 ports used, COM 3 & 4 for Bluetooth Serial Ports.
    If I open hyperterminal and create a new connection with COM 3 and change baud rate 9600
    If I type AT and hit return nothing happens. I also tried COM 4.
    On the bottom of hyperterminal it says connected and is counting how long I was connected for but the window with the blinking cursor nothing shows up when I type or after I hit return.
    What am I doing wrong?
    May 2008
    Bordeaux, France
    In your task bar, click right on Bluesoleil and open it .
    Click right on your phone and if you see a com port on the Serial service, this is this com port to use with the hyperterminal !
    You haven't a com port defoned , connect just one time the phone with the serial port and you will obtain the com port !
    Unconnect your phone and retry hyperterminal with the good com port !!!
  9. #79
    May 2008
    Bordeaux, France
    New version v1.0.4
    -solved a big issue with the APPLY settings button.
    -add debug windows "MOBILEPHONE_DEBUGON" and "MOBILEPHONE_DEBUGOFF".
    -add a sort phonebook command "MOBILEPHONE_PHONEBOOKSORT" 'sort the phone book, ME,SM,RC,DC and MC).
    see post 34
  10. #80
    ClockWorK's Avatar
    Oct 2003
    Michigan
    In HyperTerminal, you may also need to enable "Echo typed characters locally" to see your typed characters.
  1. .net Bluetooth Mobilephone Plugin
    By lambosprit in forum RR Released Plugins
    Last Post: 02-24-2015, 10:11 PM
  2. Andrea Stereo USB mic SUMA & Mobilephone Plugin
    By Paul Murray in forum Road Runner
    Last Post: 09-06-2011, 06:37 PM
  3. for Mobilephone Plugin,help!
    By wy_nb in forum Road Runner
    Last Post: 12-22-2009, 07:23 PM
  4. Mobilephone Plugin help
    By Joshc8503 in forum RR Plugins
    Last Post: 12-21-2009, 09:44 AM
  5. MobilePhone v1.0.0.2 (alpha)
    By Lucifer in forum RR Plugins No Longer Supported
    Last Post: 02-19-2009, 04:27 PM
Tags for this Thread
