RRSkAug
A Skin Augmentor plugin for RideRunner.
Thanks to Mitch for the idea of this plugin.
This plugin is meant to help skinners when it comes to handling different active sources. At one point in time, active sources were enumerated from 0 to X. Then extra sources were added that would get appended to the end of the list. But it won't be the enumeration won't be the same on different setups. Skinners used to be able to use BYVAR to change what happens or what shows up on a skin. Until this plugin, a skinner would have to check each individual guid using a IFVAR command. This plugin will do the lookup based on the ACTIVESOURCEGUID. All configuration is done with XML config files.
There is a default Sources.xml file that is installed in the plugin configuration directory. It should be in RRProfileDirectory\Plugins\RRSkAug\
The skinner should modify this Sources.xml file to customize the skin.
The source element has several parameters:
Guid : The GUID of the active source in RR.
Name : A friendly name of this source. Currently unused.
Cycle : A boolean of whether or not to use this source when cycling through a list of sources. See RRSKAUG_SRC_CYCLE_NEXT
RRCommand : The RRCommand that should be used to switch to this source. See RRSKAUG_SRC_CYCLE_NEXT
Each Source can have an array of commands, labels, and indicators that can be customized specifically for this source.
The Command element has two parameters:
RRSkAugVar : The command lookup code that should be put in the skin file.
command : The command that will be executed if this source is active.
The Indicator element has several options
RRSkAugVar : The indicator lookup code that should be in the skin file.
image : The absolute path to the image file to be used if this source is active.
or
indicator : The Ride Runner indicator to base the image off of.
image_on : The absolute path to the image file to be used if the indicator is in the on state and this source is active.
image_off : The absolute path to the image file to be used if the indicator is in the off state and this source is active.
The Label element has 2 parameters:
RRSkAugVar : The label lookup code that should be in the skin file.
label : The Ride Runner label to use if this source is active.
This plugin will cycle through a list sources when the RRSKAUG_SRC_CYCLE_NEXT command is executed. The list is assigned by specifying Cycle="true" for each source that is to by cycled through. Only those sources will be used when switching to the next source. The order that the sources are entered into the Sources.xml file determines the cycle order.
