Page 2 of 2 FirstFirst 12
Results 11 to 18 of 18
Thread: How to check the RR message (Command Not Executed: MYCOMMAND) into a VB6 plugin
  1. #11
    Sep 2012
    Germany - Munich
    not correct.
    the cmd mycommand runs the function in the plugin. has nothing to do with exectbl.
    if you send from plugin and set in exectbl, you just see the following command in skintool. the command from plugin is hidden, but working.
    if you don't set in exectbl, you get the error.
  2. #12
    Raw Wave pierrotm777's Avatar
    May 2008
    Bordeaux, France
    Quote Originally Posted by harryberlin View Post
    not correct.
    Exact , but with VB.NET , if you don't set the RR event into the exctbl.ini that don't give an error into the skintool !!!
  3. #13
    Sep 2012
    Germany - Munich
    oh,now i think to understand.
    Does it mean you want get this error with vb .net?
    or
    You want cancel the error with vb6? But why?
  4. #14
    May 2008
    Bordeaux, France
    I want cancel the error with vb6 ! My goal was to create RR EVENT as that already exist into RR .BY example ONEXIT etc...
  5. #15
    Sep 2012
    Germany - Munich
    ok. i have an idea. will try it today evening.
  6. #16
    Sep 2012
    Germany - Munich
    this is my solution. i hope this is what you need:
    Few seconds ago, have seen, in RR exist a cmd called ONCOMMANDINVALID
    1. declare outside the function
    Code:
    Public globCMD As String
    2.
    new function to run cmd to rr
    to compare a cmd execute like CMDtoRR "MYCOMMAND"
    Code:
    Public Function CMDtoRR(CMD As String)
        globCMD = CMD
        RRSDK.Execute (globCMD)
    End Function
    3. add this to function ProcessCommand in RRExtension.cls
    Code:
    Case LCase(globCMD) 'if cmd don't exist in exectbl.ini
                globCMD = ""
                'yourfunction what ever you want
                ProcessCommand = 2
    or in your case
    Code:
                globCMD = ""
                RRSDK.ErrScrn "RR plugin Error !!!", "The '" & CMD & "' command isn't found into your ExecTBL.ini file !", "ex : ''MYCOMMAND'',''MENU;MYSCREEN.SKIN''", 15
                ProcessCommand = 2
  7. #17
    Sep 2012
    Germany - Munich
    ok?
  8. #18
    May 2008
    Bordeaux, France
    ok?
    Thanks for your help !
    I see that as soon as possible !
  1. Check when RR send a ONSONGSTART command with autoit
    By pierrotm777 in forum Road Runner
    Last Post: 11-01-2011, 10:40 AM
  2. Replies: 1
    Last Post: 07-01-2010, 03:10 PM
  3. Replies: 3
    Last Post: 06-23-2009, 12:13 PM
  4. Pass Plugin Command To Flash?
    By mezz64 in forum RR Skins
    Last Post: 11-10-2008, 06:35 PM
  5. RR Full Screen Visualization Command/Window Message
    By HarryBash in forum Road Runner
    Last Post: 10-27-2007, 11:06 AM
