Results 1 to 10 of 18
Thread: How to check the RR message (Command Not Executed: MYCOMMAND) into a VB6 plugin
    Raw Wave pierrotm777's Avatar
    May 2008
    Bordeaux, France
    Hello all,
    I try in a VB6 plugin to check if a RR command return or not an RR error into skintool as : (Command Not Executed: MYCOMMAND)
    I have tried these lines but without success !
    Code:
    Public Sub Test(text As String)
        On Error GoTo ErrorHandler
        RRSDK.Execute ("MYCOMMAND")
    ErrorHandler:
        RRSDK.ErrScrn "RR plugin Error !!!", "The 'MYCOMMAND' command isn't found into your ExecTBL.ini file !", "ex : ''MYCOMMAND'',''MENU;MYSCREEN.SKIN''", 15
    End Sub
    Thanks for your help
    May 2008
    Bordeaux, France
    No guy can help me ?
    Sep 2012
    Germany - Munich
    How do you compare the command in exectbl.ini?
    Why do you need this?
    May 2008
    Bordeaux, France
    My goal was to have RR EVENTS into VB6 as i can to have in VB.NET
    Sep 2012
    Germany - Munich
    insert to RRExtension.cls
    Code:
    Public Function ProcessCommand(CMD As String, frm As Object) As Integer
        Select Case LCase(CMD)
            Case "mycommand"
                yourfunction()
                ProcessCommand = 2
        End Select
    End Function
    Don't understand why do you want compare the exectbl.ini with working commands in riderunner.
    edit:
    did a test. becauseof the LCase use small letters to catch the command.
    May 2008
    Bordeaux, France
    Quote Originally Posted by harryberlin View Post
    Code:
            Case "mycommand"
                yourfunction()
                ProcessCommand = 2
        End Select
    End Function
    edit:
    I know already know that ! I work with each day ! It's the base of the RR plugin !
    The RaiseEvent function don't exist in VB6 and it's a problem
    Sep 2012
    Germany - Munich
    Sorry, don't wanted to disabuse you.
    Why is there a probleme?
    May 2008
    Bordeaux, France
    Create your specific RR event into your exectbl.ini file as:
    "ONMYSPECIALEVENTTHATILOVE","MYSPECIALCOMMAND"
    The goal would be to send a RR command from the plugin that RR can see an run the MYSPECIALCOMMAND defined into your exctbl.ini file
    Sep 2012
    Germany - Munich
    don't know why you have problems. in my case, it is working.
    May 2008
    Bordeaux, France
    Code:
            Case "mycommand"
                yourfunction()
                ProcessCommand = 2
        End Select
    End Function
    With this code example, if you add nothing into your exectbl.ini, the skintool return that the command mycommand isn't found
  1. Check when RR send a ONSONGSTART command with autoit
    By pierrotm777 in forum Road Runner
    Last Post: 11-01-2011, 10:40 AM
  2. Replies: 1
    Last Post: 07-01-2010, 03:10 PM
  3. Replies: 3
    Last Post: 06-23-2009, 12:13 PM
  4. Pass Plugin Command To Flash?
    By mezz64 in forum RR Skins
    Last Post: 11-10-2008, 06:35 PM
  5. RR Full Screen Visualization Command/Window Message
    By HarryBash in forum Road Runner
    Last Post: 10-27-2007, 11:06 AM
