Results 1 to 6 of 6
Thread: How to fill Customlist via Plugin
    Sep 2012
    Germany - Munich
    Hi Folks
    I want create an own Contactlist incl. Name, Number and Photo.
    How can i fill a customlist with my vb6 plugin?
    regards
    Aug 2007
    harryberlin , i want something like that , you make that ? thanks
    Sep 2012
    Germany - Munich
    In my Case with VB6
    to add without Image:
    frm.CLAddItem "Numberstring" & vbCrLf & "Namestring"
    vbCrLf is the seperator for listtext and listdesc
    to add with Image(since RR Version Jul01 2014):
    frm.CLAddItemWithImage "Numberstring" & vbCrLf & "Namestring", "ImageFullpathString"
    before you should check, if a customlist on screen exist:
    If frm.IsShowCL Then ....
    or
    If Not frm.IsShowCL Then Exit Sub
    and clear the customlist before fill a complete new list:
    frm.CLClear
    For other Things check the Documetation Folder these files:
    "Extension Plugin Form properties.txt"
    "dot Net Extension Plugin frm Object.txt"
    I use this to import Names, Numbers, Photos of exported VCard from S3 mini, for my plugin.
    Raw Wave pierrotm777's Avatar
    May 2008
    Bordeaux, France
    Thanks for this share . How do you download from your S3 to your plugin the VCARD ?
    Sep 2012
    Germany - Munich
    in contactlist or phonebook there is an option to export all contacts to SD.
    in Phonebook >> Settings >> Import/Export >> to SD Card
    after than you have a vcf file on your SD Card.
    for Filetransfer to PC, i'm using MyPhoneExplorer.
    May 2008
    Bordeaux, France
    Quote Originally Posted by harryberlin View Post
    Ok , thanks
  1. RR Deletes Iconpath in Customlist after saving
    By harryberlin in forum Road Runner
    Last Post: 04-26-2013, 02:04 AM
  2. What do I use to fill pinholes?
    By MAZDABOY in forum Fabrication
    Last Post: 08-12-2008, 06:53 PM
  3. TV out on VIA doesn't fill the whole screen
    By bob^ in forum General Hardware Discussion
    Last Post: 05-26-2007, 12:04 AM
  4. Can someone fill in the blank?
    By guizai in forum General Hardware Discussion
    Last Post: 04-16-2007, 03:52 PM
  5. fill the edges
    By bmwperson in forum Fabrication
    Last Post: 09-07-2004, 01:32 PM
