11view must be the active window and the RR-buttons must be pressed through mouse or touchscreen. I use a keyboard, there is RR the active window. I try to solve it now with Girder.
I've added this to my skin, but I can't get the buttons to work. In 11view I've added shortcuts to keys (R,F,K,A,S,D) and in RR Editor I've made buttons with the keys. When I press them in RR the key is spoken, but the command doesn't work. What could be wrong?
Can I change 11view to be (and stay) the active window?
For me the button to switch between the picture browser and the viewer works ok, but I can't use the next and prev picture buttons. When I press those (with mouse or touch) I just hear 'G' and 'S' and nothing happens..
Then is 11view not the active window. When I start the menu with 11view, it works fine, with my mouse. Girder can send to the window and perhaps also a vb-script. I don't know, how embedding a vb-script as a button.
Code:Set objShell = WScript.CreateObject("WScript.Shell") objShell.AppActivate "11view" objShell.SendKeys "s"
Probably not going to use my self but well done.
May be if you can get Guino to auto detect a drive, camera or BT enabled phone you could switch to this screen automatically - ideal for on the fly viewing.
Terran
i tried this but can't get it to work with the skin... it just opens in the background behind RR... I'm using the Spaced out Skin....
On a touchscreen it works fine. In the 11view config must be insert the keys, these are in RR embedded.
Now is a picture viewer in the new RR update integrated. THX Guino.
I get exactly the same error as Meelobee...
ive been playing around with this and i got it to partially work. i get the skin to load up on the bottom and view 11 to open up but i cant use the bottons on the skin to work with the program?
anybody have a fix for this, or know why its doing this?
thanks
95 Mustang 5.0
Custom Case, VIA m10000, 512 MB, 80gig, M2-ATX, Slot Load DVD, 7" LCD Touchscreen
80% done
how do you get the skin buttons to work 11view?
i've assigned keys in 11view but how do you put them in the skin. i've been trying but cant figure it out. i opened up skin file in the RAR file but that doesnt work.
any help?
95 Mustang 5.0
80% done
