no rush man, your work is much appreciated, thanks a lot.
2011 Nissan Frontier SL
AMD X3 2.2 | M4-ATX | 16Gb SSD | 2GB DDR3-1333 | MSI GF615M-P33 MB
OBDPROS USB | BU-303 GPS l LILLIPUT TS | Car2PC adapter | XM Direct | USB Dual band N with custom mag-mount antenna.
First fully skinable version is now online, but I haven't tested it a long time.
i'll let you know, thanks a lot quickmic. great job!!.
BASSRR ==> [Audio Player/MusicDB/Cd Player/Ripper/Rate/Internet Radio/Audio Capture/Youtube Video]
RRTube ==> [View/Download Youtube Videos]
WifiMan ==> [Wifi Manager]
RRec ==> [Audio Capture]
If You Want To Be Given Everything, Give Everything Up ...
Bird York -- In The Deep --
thx
I have uploaded a update which fixes probs with smaller resolutions than 800x600
Works well so far. Im working on a Brushed Metal Skin.
About 50% done so far.
Do you have the PSD you used to create your skin? I will share my PSD once I have it finished, but its a PITA having to re-create this keyboard.
PSD? Is this a Photoshop template or something like this?
I created the skin only by screenshots from VB6 which was useful, cause I got the coordinates of the buttons.
The Brushed Metal Skin is perfect...thx Maybe you can upload it when finished.
I'm currently working on an update, which is much faster than the 12.7. I think I can upload it in a few days. It's based on DirectX and also I have preloaded all skin-files at startup. So there comes an additional "Loading" Screen.
I have changed the color-codes in the skin-ini-files to RGB values, so this has also to be updated in next version. Then the skin-structure is imo perfect.
Heres a few screens to show you what Ive done so far..
16.9 Version ist online. Custommx3 created this new skin and looks very fine. Thx for that, I know its a lot of work.
Also new:
- skin-files loaded on startup
- graphics routines are now using DirectDraw
- the startup-position now works correct
- it's possible to start the programm hidden (settings.ini)
- colorcodes now in rgb
- many bugfixes...
when i used it some months ago there was a problem with office2007..it deleted some files when HDD clean was run and then i had to reinstall office2007 all over again..does anyone know which are the file types?
