Page 11 of 12 FirstFirst ... 23456789101112 LastLast
Results 101 to 110 of 118
Thread: System-Manager
  1. #101
    Nov 2005
    Austria
    hmm
    I have also office 2007 and i got no problems. Maybe is there a difference between the german and english version.
    If you have problems you can rebuild the files out from the recylebin.
    The search-parameter of files which are deleted can you see in the clean-hdd menu.
    Cookies, Windows-temp, and User-temp files were also deleted.
    For example user-temp is: "C:\Dokumente und Einstellungen\QUICKMIC\Lokale Einstellungen\Temp" for me
    In english something like: "C:\documents and settings\QUICKMIC\local settings\Temp"
  2. #102
    FLAC Nomader's Avatar
    Apr 2006
    Greece
    maybe it is the empty folders when deleted..??not sure.
  3. #103
    Jun 2003
    Memphis - TN
    I have an issue with 16.9...
    if my res is @ 1024x768,it runs great.
    if my res is @ 800x600, I get a white box.
    You had mentioned it runs on directx, so I ran my dx diag, and its fine.
    2011 Nissan Frontier SL
    AMD X3 2.2 | M4-ATX | 16Gb SSD | 2GB DDR3-1333 | MSI GF615M-P33 MB
    OBDPROS USB | BU-303 GPS l LILLIPUT TS | Car2PC adapter | XM Direct | USB Dual band N with custom mag-mount antenna.
  4. #104
    Nov 2005
    Austria
    I think the problem is the position setting in the setting.ini. Try position 0/0. That should be the upper left corner.
  5. #105
    Jun 2003
    Memphis - TN
    perfect! thanks.. Nice skin btw
  6. #106
    Nov 2005
    Austria
    But a few settings of the skin-ini files has to be adjusted. i.e. The "copy" screen has still the wrong colors. I try to fix these last optic-"problems" and a few more existings bug next week.
  7. #107
    Jun 2003
    Memphis - TN
    If the skin needs changing, I can do so.
  8. #108
    Nov 2005
    Austria
    Next update is online. I corrected a few bugs, tried to raise the performance and have done some changes by the skin files.
    @Custommx3
    I've found some little problems:
    By "CheckHDD_Active.JPG" the buttons are not pushed in this picture. In "Copy_Active.JPG" is the color of the pushed buttons like the color as disabled. (red text not white text). Same by "Defrag_Active.JPG"
    Maybe you can fix that.
    thx
  9. #109
    Nov 2005
    Austria
    17.6 Update online
  10. #110
    Nov 2005
    Austria
    18.3 Update available
    I fixed some bugs in the window-handling. i.e. minimize, maximize, lostfocus and so on. Also after the hibernate mode the tool should now work correctly.
  1. WANTED: Copy of iGuidance 2.0 GPS Software
    By john94587 in forum Classified Archive
    Last Post: 01-05-2006, 05:17 PM
  2. ColdHeat Soldering Tool!
    By [iG] in forum General Hardware Discussion
    Last Post: 02-04-2005, 09:11 PM
  3. Replies: 5
    Last Post: 08-17-2004, 12:08 PM
  4. After I copy files, they are corrupted.
    By Cliff in forum Software & Software Development
    Last Post: 05-17-2003, 09:49 PM
