Getting a type mismatch upgrading from 17.3 to the other upgrades. Nice program! Will definitely use this one, thanks so much for making it. Is it possible to add a GIANT taskmanager as well?
Printable View
Taskmanager should be no problem to implement, but it will take some time. For the moment I try to fix some still existing errors. After these corrections I will start some new features.
Cause of the type mismatch I tested again the update from 17.3 to 18.3. I couldn't find any problem. Maybe you have a problem in your settings.ini?
Ill check that out, thanks for a really nice program that is surely needed. About the taskmanager, hope it gets on your plate one day ever seen taskmanater on a 7 inch screen? lol
Update available
http://www.quickmic.at.tt/Public/Sys...nager_18_9.rar
The taskmanager isn't implemented yet. I had no time to implement this, sorry. But I fixed some bugs, and now the system-manager can be embedded to rr without any problems. RR-Skin & Startcommand is in the archiv included.
Hi Mic,
If you're around or if someone else can help, can you please upload this somewhere, so I can have a play??
Many thanks
The link in the post right above yours works. I just downloaded it to test .
Hi John, hope you're well? was sorry to read about your sad news. Got the download now, thnx.
ps.. My copy of DFX 3.0 is coming on leaps and bounds - keep at it mate! and it was my pleasure for the small donation. Can't wait for the next release!!!
QuicMic,
Well done for all this work, I'm just downloading now to play with, but I have confidence it will work flawlessly.
The main reason for me using this is to allow me to bluetooth images,music/videos to the nessecary destination.
The way it will work;-
Setup a location on your HDD for bluetooth file transfer (unsecure to avoid the passcode) on my PC this is D:\BTInbox.
Then set this up as browse location instead of USB drive letter.
I should then be able to bluetooth a track to my PC, then transfer it to my music folder, and play it through the audioplayer.
Handy if a mate has something I want on their mobile.
A thought for others too, as I know a lot of people run bluetooth.
Once again quicmic, thank you.
