Page 13 of 58 FirstFirst ... 34567891011121314151617181920212223 ... LastLast
Results 121 to 130 of 575
Thread: Integrated voice control in RR...
  1. #121
    Nov 2005
    Quote Originally Posted by Mr.Fabio
    One suggestion only for us Phoco Users...
    When a call is incoming the mic should go OFF (in NON Listening mode) to restore the right mic settings and avoid any interference with voice recognition... and then return ON (in Listening Mode) when the call is finished to permit the normal Voice recognition...
    When I started looking into Phoco it didn't sound like many were using it because it was not fully functional, I am glad I read it wrong. I will work on this.
  2. #122
    Variable Bitrate Mr.Fabio's Avatar
    Feb 2005
    Italy
    Quote Originally Posted by whodwho
    Thanks a lot whodwho
    Fabio
    _______________________
    Travla C134
    Jetway J7F2WE 1Gb DDR2 - HD SATA 3.5" 80Gb + HD 2.5" 40Gb - Lilliput 7" TS - Holux GR-213 - Bluetooth - Belkin 802.11g WiFi - Silabs Radio - HTC Leo
    RoadRunner - PC Navigator 7.1 - FreeFone
  3. #123
    Jan 2006
    Great program,
    However here are a few bugs / problems I have encountered.
    1) when RR starts, voice control is looking for a command, not a keyword. The problem is until issued a command it will never go back to looking for a keyword. There was no voice.ini setting I could find to fix this.
    What it should do: when RR starts it should be looking only for the keyword when set to keyword=yes in the ini.
    2) The volume set in the voice.ini does not work, it is always at 100 %, the only way to change this is to actually move the volume slider on voice control after the program starts. That will change the volume, but when the program is restarted it is back to 100%.
    What it should do: voice.ini volume should take effect when the program starts, and moving the volume slider shoud update the ini value for future use.
    3) Some commands do not unpause the music, while others do. "Weather", "Thank you", "Just Checking" do not unpause the music, however commands like "audio mode" and "Main menu" do..... I have not tested all the commands yet.(tested with the lastest version in the first post)
    What it should do: all commands should unpause the music unless the "pause" command is given.
    Other than those 3 issues, this is the best voice control software I have used. Once all the bugs are worked out this will be awesome.
  4. #124
    Nov 2005
    Quote Originally Posted by gonthorn
    Great program,
    What it should do: when RR starts it should be looking only for the keyword when set to keyword=yes in the ini..
    I did catch that one, will be in the next update.
    So the speech volume or the pc volume is at 100%? Sounds like it could be related to this issue: Voice control, windows When you start the program does the slider show the 70% or what ever you have it set for? following the RR format, nothing is saved to the ini from the rr.exe only from the config program.
    I guess I need to do some better testing after adding new functions
  5. #125
    Variable Bitrate roadhog's Avatar
    Jul 2005
    Hampshire UK
    One thing I've noticed is that VC appears to set the option "Map Master Volume to Control Line: (For Weak Sound Card)" to [All Lines]. I guess most people have it set to [Master Volume]. Check it out in RRConfig.
  6. #126
    Nov 2005
    Quote Originally Posted by roadhog
    The only volume that I adjust would be the speech volume, I don't believe that effects the PC volume?
    So that saved setting changes on you? Mine has stayed on 'Master Volume', I switched it to 'All Lines' and it stayed as well.
    Are you having issues with the volume or just an observation?
  7. #127
    Constant Bitrate Mattkins99's Avatar
    Mar 2005
    Seattle Area
    the latest version seems to be working fine when I'm on my home computer, but when in my car, I can't get it to pick up voice commands, and when I press the hotkey, it toggles from listening for Command, not listening and waiting for keyword. It might be the USB Mic... we'll see.
    Matt Atkins
    Seattle5s | President
    '01 M5 Lemans Blue/two tone black and silver interior
    Factory nav.... for now
    Old Car (almost sold)
    '98 540i-6 blk/blk
    Dell 300m | Xenarc 7" | Road Runner | iBusCOMM | NaviVoice | Streets & Trips GPS
  8. #128
    Jul 2005
    Hampshire UK
    It may have been the first release changed a setting in the rr.ini file. If not, then it's something I have inadvertently changed. It doesn't do it now anyway.
  9. #129
    Constant Bitrate randomjohn's Avatar
    Sep 2005
    CT
    I was just looking through the readme and see that you've got the alphabet spelled out up to Yankee... I assume Zulu is in there and it just got left out of the readme? Also, do we have to pronounce these words the way they taught us in the Army? (e.g., Quebec = Key Beck, Uniform = You Knee Form)
    GA-K8VM800M, Sempron 64 2800+, 512mb DDR400, D-Link USB BT, Linksys .11g NIC, 250gb IDE, BU-353, SIR-ALP1 w/ MJS, DSATX 220w, DWW-700H
    Worklog: http://www.mp3car.com/vbulletin/worklogs/65059-03-jetta-if-i-can-any-idiot-can.html
    Now with pictures!
  10. #130
    Nov 2005
    Quote Originally Posted by randomjohn
    No, actually I did not have it in there, thank you for catching that. FYI, there are two ways to enter letters, one is this way where you would say 'alpha' without having to give a group name or you can say 'letter a' which is the 'letter' group and the letter 'a'.
    It is pretty good about recognizing words, although maybe better phonetically as that is how speech rec appears to work.
  1. Recommendations : Voice Control
    By wolfebaine in forum Input Devices
    Last Post: 01-03-2006, 05:05 PM
  2. SpeakEasy Voice Recognition - Release 0.9.2
    By ruairi in forum Software & Software Development
    Last Post: 11-22-2005, 03:29 PM
  3. Voice control
    By Cheekz185 in forum Centrafuse
    Last Post: 06-23-2005, 10:35 PM
  4. request: voice control for videos
    By ryguy in forum Centrafuse
    Last Post: 06-09-2005, 01:04 AM
  5. Replies: 22
    Last Post: 08-13-2001, 01:42 PM
