Page 15 of 58 FirstFirst ... 5678910111213141516171819202122232425 ... LastLast
Results 141 to 150 of 575
Thread: Integrated voice control in RR...
  1. #141
    Constant Bitrate Mattkins99's Avatar
    Mar 2005
    Seattle Area
    Quote Originally Posted by whodwho
    So are you running Windows Vista? Or did you find a download for her voice? If you are running Vista, I beleive that is SAPI 5.3! It would be nice to know that programming done now will not have to be revisited for 5.3.
    kth
    No, I just downloaded it from searching somewhere when I was searching for voices. I haven't had a chance to play with Vista yet, but I should in the next week or two. Still... I'd be a little worried about sticking it on my carputer until at least Beta 2.
    Matt Atkins
    Seattle5s | President
    '01 M5 Lemans Blue/two tone black and silver interior
    Factory nav.... for now
    Old Car (almost sold)
    '98 540i-6 blk/blk
    Dell 300m | Xenarc 7" | Road Runner | iBusCOMM | NaviVoice | Streets & Trips GPS
  2. #142
    Mar 2005
    Seattle Area
    I'm seeing some funky stuff with the latest build. I tried the pause command, and I can see that it picks up what I'm saying and even sends the pause command to RR, but it's not pausing the music. I saw this with a few other commands too.
    I tried the latest playlist commands to try and call music, but that doesn't work either. every time I say play list, it picks up play next. I haven't gone into the Commands.xml file to see if I can change this.
    Matt Atkins
    '98 540i-6 blk/blk
  3. #143
    Variable Bitrate roadhog's Avatar
    Jul 2005
    Hampshire UK
    From my experiences (and pestering whodwho!) the playlist command doesn't work until the playlist is built. It then exists in a dynamic array alongside the compiled command.cfg. It isn't in the command.xml.
  4. #144
    Nov 2005
    Just wanted to update to let you know I have been working on it. I wanted to step back and cleanup the existing code and try to catch a couple of these issues before moving forward.
    I updated the keyword grammar file to be a dynamic one. You can set the keyword in the voice.ini file now. I have it set for one word or phrase, does anyone feel a need for more that one?
    I cleaned up some of the code for pausing and hope that catches some of the above issues.
    I worked on the playlist and found an issue was that if it found a duplicate title it would fail to build the grammar file. I also test against a 4000+ playlist and it builds in a couple seconds. (this one had worried me)
    I also worked on the dictation mode. It takes a bit to get used to but show a lot of potential. I need to add a routine to undo as doing a ^z does not undo it. I think I will approach it with getting the length of the recognized string and using backspaces.
    kth
  5. #145
    Jul 2005
    Hampshire UK
    Like the idea of a single keyword, not only does mean one less cfg file but reduces the chances of unwanted recognition.
    The playlist will be the killer app though.
    Sounds like you've been hard at work, can't wait to try it out!
  6. #146
    Mar 2005
    Seattle Area
    Can you send out a link with the latest build? I'm still having issues with the latest builds working with the USB Microphone I have in my car, but I need to do more testing.
    Matt Atkins
    '98 540i-6 blk/blk
  7. #147
    Apr 2005
    kth
    Is this the latest availible on first post?
  8. #148
    RoadRunner Mastermind
    guino's Avatar
    Nov 2004
    Toronto, Canada
    RR hides the mouse in different modes, there is a setting in the rr.ini hidemouse I don't know if this would help you. I am basically just converting voice commands to button presses, so it should not behave any different than the version without voice.
    I just now had the time "glance" at this thread and it seems like a nice effort.. although, I wondered how you were getting commands into RR... The truth is I never integrated voice commands directly into RR because its a feature that most don't use. In any case, I see you have made a "version" of RR with built-in voice support (or so I believe).. and if that's the case, I wouldn't mind including that in the official sources once it's well tested, that is of course, if you'd like to have it there (so you don't have to keep making new versions).
    In any case, it would still be well possible to make the same application separately from RR but yet well integrated using RR's SDK to send/receive commands and data back and forth -- I can not think of any reason why it would *have* to be built in. Having it separately would allow you more freedom and control to this side of the application (and I'd be glad to point you in the right direction), but it's your code, your choice... I'm sure there'll be an interest from the community regardless.
    Ride Runner RR's Myspace
  9. #149
    FLAC J187's Avatar
    Nov 2004
    Boston
    Quote Originally Posted by guino
    The truth is I never integrated voice commands directly into RR because its a feature that most don't use. .
    I definitely know what you mean, until this thread, I never really had an interest in voice control. However, I realized I never reallly though much about it either. It is certainly a feature I would love to have for certain things most definitely, like Iguidance. I think much of the lack of interest is directly because nothing has come directly from you yet, Guino. I think that most people are somewhat frightened by the idea of open source and at best are skeptical of anything that appears to be added outside of the source originator's efforts. I bet an endorsment from you, or at least a semi-endorsement will greatly improve the interest in voice control. I know I would appreciate it integrated in RR and I am very hesitant to get too use to it knowing you may have a RR update right around the corner and it would need to be modified again....
    Its not the cards you're dealt, its how you play the hand!
    Quote Originally Posted by ryuandwings View Post
    Where can I get a roll of tin foil?
    I been looking for that all over the net, but I can't find it.
    Please help.
  10. #150
    Jul 2005
    Hampshire UK
    When planning and building my CarPC I didn't give a lot of thought to voice control; my previous experience was limited to Microsoft Voice 1.0 on my iPaq. This was an excellent prog, with all of the features of VC, but due to the mic type and position on the iPaq it never worked while driving.
    Now I've used a touchscreen, a mouse, a trackball, and finally voice control (navi voice), and I have to say the most reliable method has been voice control. It still has limitations (after about 80mph depending on road surface and when the music is up loud) but for navigation and playlist manoeuvring it has been unbeatable. Unfortunately, many commands in Navi Voice are hard coded, leading to gaps in control with say the UK version of iGuidance or RoadRunner. Whodwho has had the initiative to make all the commands fully configurable through the command.xml file, allowing any regional changes to be made with ease.
    I believe this software to be a core method of CarPC control, and would vote that it remain an independent program in its own right, (there is a VC.exe) allowing community progress on all programs without muddying the scene with many different file versions.
  1. Recommendations : Voice Control
    By wolfebaine in forum Input Devices
    Last Post: 01-03-2006, 05:05 PM
  2. SpeakEasy Voice Recognition - Release 0.9.2
    By ruairi in forum Software & Software Development
    Last Post: 11-22-2005, 03:29 PM
  3. Voice control
    By Cheekz185 in forum Centrafuse
    Last Post: 06-23-2005, 10:35 PM
  4. request: voice control for videos
    By ryguy in forum Centrafuse
    Last Post: 06-09-2005, 01:04 AM
  5. Replies: 22
    Last Post: 08-13-2001, 01:42 PM
