Page 17 of 58 FirstFirst ... 789101112131415161718192021222324252627 ... LastLast
Results 161 to 170 of 575
Thread: Integrated voice control in RR...
  1. #161
    Maximum Bitrate wysocki's Avatar
    Mar 2004
    Los Angeles Area
    Quote Originally Posted by tbird2340
    You got a picture of it mounted?
    Here's a pic of my Logitech mounted on the door column. I cut off the back half of the case and put some heatshrink tubing over it. It works well with the windows closed, not so when they're open. Best feature is the switch on it so I can disable/enable it easily. A couple times when I first turn on my system, before Windows controls the hardware, my soundcard (Extigy) pumps the mic right through to the amps --- bigtime feedback! The switch saves my ears.
    Recommendation for Mic
    Epia-M II M10000 Nehemiah WinXP sp2 Travla C134 case Carnetix 1260 power Xenarc 700TS XM Direct Toslink Extigy USB 5.1 Garmin GPS18 Linksys 802.11g wireless Nokia 6230 Bluetooth Memphis Amps Focal Speakers Frontend: RoadRunner
  2. #162
    Raw Wave tbird2340's Avatar
    Oct 2003
    Poland, OH
    Nice, I had that same mic and ruined it trying to cut it / etc to make work in my truck
    Current Vehicle: 2007 Dodge Nitro
    Second Vehicle: Sold it :( 2005 Dodge Ram 1500 Quad Cab
    First Vehicle: 2003 Ford Ranger
  3. #163
    Newbie carlospelos's Avatar
    Dec 2005
    Spain
    Hi all, I´m very interested about this app, but is focused for English people .
    Maybe if I install a spanish version of sdk51 (I will try to find it) and chaging all phrases from settings into spanish, will it work? thanks.
    Edit: there´s no spanish version from microsoft, maybe can I try with other engine?
  4. #164
    FLAC J187's Avatar
    Nov 2004
    Boston
    My microphone is the logitech $11 voice cancelling one. It works great. I took it completely apart.
    Its not the cards you're dealt, its how you play the hand!
    Quote Originally Posted by ryuandwings View Post
    Where can I get a roll of tin foil?
    I been looking for that all over the net, but I can't find it.
    Please help.
  5. #165
    Oct 2003
    Poland, OH
    Quote Originally Posted by J187
    Pics?
  6. #166
    FLAC J187's Avatar
    Nov 2004
    Boston
    No pics....Its jimmy rigged right now. When I'm done w/ the install, I'll post pics.
    Please help.
  7. #167
    Low Bitrate slantman's Avatar
    Apr 2005
    north augusta SC
    how do you get it to correct "up" it keeps saying papa.
    and "down" keeps saying gama
  8. #168
    Nov 2005
    You have to watch commands being to short, it is currently set to "move up" and "move down".
    FYI, you can change this to whatever you like in the Commands.xml and recompile the grammar file.
    FYI2, if you find that it is overly responding to the alpha - zulu commands, you can either delete that rule or add extra text for it to have to recognize. The purpose of these is so you don't have to say "letter c" "letter a" "letter t" you can say "charlie" "alpha" "tango" to enter the word cat in a textbox, helps with the speed of entering text if the speech profile is close.
    Quote Originally Posted by slantman
  9. #169
    Maximum Bitrate Zebelkhan's Avatar
    Dec 2004
    Bay Area, CA
    Pardon me for asking a dumb question but what does it exactly mean when you say "recompile the grammar file"?
    Compaq Evo D510 e-PC - P4 2.0 - 512M RAM - 120G 3.5 HD - 7" Xenarc 700TSV - DSATX fitted nicely inside the PC case
  10. #170
    Nov 2005
    Quote Originally Posted by Zebelkhan
    Not a dumb question
    FYI, it is in the readme:
    Quote Originally Posted by the readme
    Configuration:
    All of the spoken parts (commands on the right) of this program are changeable in the xml files, currently they are manually edited. I use the Grammar Compiler to edit and then compile them you can also test them for recognition. Open the Grammar Compiler, open one of the xml files make changes and hit tools build. If there is a problem with the xml file it will complain. The structure is a bit sensitive, if you donít follow the structure or double up on the same spoken command it will fail. Make backups before modifying and donít forget to save the xml file as well.
  1. Recommendations : Voice Control
    By wolfebaine in forum Input Devices
    Last Post: 01-03-2006, 05:05 PM
  2. SpeakEasy Voice Recognition - Release 0.9.2
    By ruairi in forum Software & Software Development
    Last Post: 11-22-2005, 03:29 PM
  3. Voice control
    By Cheekz185 in forum Centrafuse
    Last Post: 06-23-2005, 10:35 PM
  4. request: voice control for videos
    By ryguy in forum Centrafuse
    Last Post: 06-09-2005, 01:04 AM
  5. Replies: 22
    Last Post: 08-13-2001, 01:42 PM
