Page 43 of 58 FirstFirst ... 333435363738394041424344454647484950515253 ... LastLast
Results 421 to 430 of 575
Thread: Integrated voice control in RR...
  1. #421
    Nov 2005
    Quote Originally Posted by fury
    Quick question...is there an RR command to reenable the voice control after one tells it "go away" or "stop listening"?
    In a system I'm developing, there isn't a mouse or a touch screen, so the user cannot press the Enable button on the voice control window.
    So voice is the only input? I would remove the commands that disable voice. You would need some input device to re-enable it. Would a switch on the serial port be an option?
  2. #422
    Nov 2005
    Quote Originally Posted by djmickyg
    have u set the "RepeatCommand=" setting int he voice.ini file to false?
    ive found with alot of these voice control apps that when it says the comand and it understands itself it sends the pc into a crazy loop.
    This would definitely stop that but recognition is disabled for the duration of any spoken replys so it should not be looping. This one has me a bit purplexed, let me know what becomes of this.
  3. #423
    Mo' Programming Mo' Problems
    Sonicxtacy02's Avatar
    Woodbridge, VA
    Blog Entries
    55
    Odd problem. My voice.ini file seems to be being ignored. I have it set to use f10 as a hotkey, use keyword=false, and other settings. When i start rr the f10 button doesnt work as a hotkey. Only way to get it receiving commands is to say computer again. Also it started reading dialog boxes n stuff when its disabled. Whats goin on?
    Live mp3Car Facebook Chat
  4. #424
    Nov 2005
    Quote Originally Posted by Sonicxtacy02
    I think the hotkey issue is the UseKeyword=False, that will set if it listens continuously or if it listens for a keyword/hotkey. This was setup prior to adding hotkey support, hotkey is a hardware equivalent to a keyword...I can see where the confusion is from.
    You have Hotkey_Keyword=VK_F10
    The reading of window dialogs should not happen with ReadWindowsMsgs=False
    Curious, what is the datestamp of the VoiceControl.dll you are using?
    Let me know if this helps
  5. #425
    Woodbridge, VA
    Blog Entries
    55
    i dont see a datestamp on the .dll but its from the 5-02 release on the first post. So your saying i need to have usekeyword=true to have the hotkey work? I guess it makes sense now that u put it that way.
  6. #426
    Newbie vidason's Avatar
    Apr 2006
    long island ny
    FAQ on phone and voice.
    I also have a request for guino....would it be possible to add 2 new sections to the Road Runner FAQ page? First, FAQ: How to set up Voice Recognition in RR. Second, FAQ: How to set up Phone Control with RR. I think that the FAQ is a very helpful place to help the users get set up and it also prevents us from asking silly questions over and over again.[/QUOTE]
  7. #427
    Confusion Master
    Enforcer's Avatar
    Sep 2003
    They should be something whodwho and RobbyBMW should do, as they wrote the code for those functions.
    Also the dual monitor functions should have a FAQ as well.
  8. #428
    Maximum Bitrate Civic03's Avatar
    Dec 2005
    Does anyone want to share their command files or voice files? I'm also using LSX skin if anyone has one that works well with that.
    PROGRESS 95%[//////////]Complete - Software configurations
    Current Task: Just adding on...
    Needed:wireless keyboard/mouse
    My Carputer Blog
    Car System Site
  9. #429
    Apr 2006
    long island ny
    i am having a problem with v/c not pausing when in sirius radio, does any one have this problem and what can i do about it.
  10. #430
    Variable Bitrate madkad's Avatar
    Jul 2005
    uk
    Is there any way to add more comands, say thinks like to turn webcam on and record and stop recording?
    [B]Car Computer 98%[|||||||||-]
    Install Plan 100%[||||||||||]
    Styling 20%[||--------]
    Install 0%[----------]
  1. Recommendations : Voice Control
    By wolfebaine in forum Input Devices
    Last Post: 01-03-2006, 06:05 PM
  2. SpeakEasy Voice Recognition - Release 0.9.2
    By ruairi in forum Software & Software Development
    Last Post: 11-22-2005, 04:29 PM
  3. Voice control
    By Cheekz185 in forum Centrafuse
    Last Post: 06-23-2005, 11:35 PM
  4. request: voice control for videos
    By ryguy in forum Centrafuse
    Last Post: 06-09-2005, 02:04 AM
  5. Replies: 22
    Last Post: 08-13-2001, 02:42 PM
