Page 45 of 58 FirstFirst ... 353637383940414243444546474849505152535455 ... LastLast
Results 441 to 450 of 575
Thread: Integrated voice control in RR...
  1. #441
    Mo' Programming Mo' Problems
    Sonicxtacy02's Avatar
    Woodbridge, VA
    Blog Entries
    53
    sorry to bring this up again but voice is possessed. i reinstalled the .dll (tried test version, errors... so i went to 5-02 version). at first it worked with my ini settings:
    usekeyword=false
    usehotkey=true
    F10 is my hotkey. Started rr.. "voice is ready" press f10, said audio.. it worked. SWEET! Then without pressing the hotkey.. seemingly for no reason at all it said "BLANK BLANK disabled" (didnt hear it all) Since then, f10 no longer works, voice speaks randomly even with no music playin and quiet environment, and it commands itsself to reset my playlist every minute or so.
    i checked the ini file and my settings are the same. What gives?
    Live mp3Car Facebook Chat
  2. #442
    Nov 2005
    Quote Originally Posted by Sonicxtacy02 View Post
    usekeyword=false
    usehotkey=true
    Did you try it with both set to true?
  3. #443
    Woodbridge, VA
    Blog Entries
    53
    set both to true with the same results. I even muted the mic and the problem was still there.
  4. #444
    Mar 2005
    Sweden/Vaxjo
    its already embedded into road runner now? did you have somethin else that needed to be added?
    hmm... if this is really integrated into RR now... how do I turn it on and configure it...
    Swedish site for CarPC's
    http://www.bilpc.info
  5. #445
    Nov 2005
    Can you PM me your ini file and I will try it here?
  6. #446
    Nov 2005
    Quote Originally Posted by Naesstrom View Post
    1. You will need SAPI installed, there is a link on the first post if it is not.
    2. Run thru the microphone and training wizards in Control Panel -> Speech
    3. Extract the files from the first post (use the 5-02 version) and add a UseVoiceControl=True line to the RR.ini
    4. There should not me any configurations you will need to do but you can customize commands if needed by editing the commands.xml and recompiling (let me know if you need help with this, may not be obvious)
    Let me know if this gets you going
  7. #447
    Mar 2005
    Sweden/Vaxjo
    Quote Originally Posted by whodwho View Post
    Thanks... I got it working last night and took it for a ride today, I have some problems to get it to undestand my commands though, I was trying to pause the music a couple of times and it took it for close an shut down RR while I was shouting "NOOOO!" at it...
    I have a few more questions:
    1. Is it possible to use another enginge then the MS SAPI, I think I might have Dragon Dictate around somewhere, I did the first set of exercise with it, the 10 minute one but it feels like it still doesnt understand me (Might be that I'm a swede and it just cant understand my dialect in english or something...)
    2. How many commands can I give in a row without havin to say boris between them, I was mostly thinking about the volume setting... I changed the command but it's still:
    -(me)Boris
    -(Boris)Speak
    -(Me)Volume up
    -(Boris)Volume up
    -(me)Volume up
    -(me)VOLUME UP
    -(me) For gods sake, VOLUME UP
    -(me)Boris (with a tired voice)
    -(Boris)speak (happy as ever)
    and so on...
  8. #448
    Mar 2005
    Sweden/Vaxjo
    Today I noticed one more thing.. I have done all the training lessons available and have noticed one strange thing...
    Most of the time whe Boris don't get me he just says "now playing playlist" and jumps to song 21... is there any way to turn this off?
  9. #449
    Woodbridge, VA
    Blog Entries
    53
    that is the MOST annoying thing! All the other mishaps are ok, but i'd say 75% of the time there's an error interpreting commands it jumps somewhere in the playlist.
  10. #450
    Nov 2005
    -(me)Boris
    -(Boris)Speak
    -(Me)Volume up
    -(Boris)Volume up
    -(me)Volume up
    -(me)VOLUME UP
    and so on...
    Glad you were able to get it going.
    1. The only engine currently supported is the MS one as that is all I have access too.
    I know how frustrating it is when it won't respond correctly, I use my headset for the mic only and I had the headphone jack plugged into the mic jack so it was using the earpieces for a mic - needless to say there was alot of shouting with words it was not meant to understand!
    2. There is a setting in Voice.ini KeywordTimeout= you can increase this to have more listening for command time. The timer is reset on each recognized command so it is probably aggravated by the difficulties with recognition.
    Some suggestions to try, in the control panel for speech for your profile there is a setting to 'automatically adapt to the speakers voice', I would not use this setting as it may be adapting your commands with background noise of the vehicle. I know it is not fun to go thru but maybe create another profile without this setting and see if helps. "The papaya tastes perfect"
    With helping with this particular scenario instead of using "volume up" multiple times use "volume sixty percent"
    Let me know if any of this helps
  1. Recommendations : Voice Control
    By wolfebaine in forum Input Devices
    Last Post: 01-03-2006, 05:05 PM
  2. SpeakEasy Voice Recognition - Release 0.9.2
    By ruairi in forum Software & Software Development
    Last Post: 11-22-2005, 03:29 PM
  3. Voice control
    By Cheekz185 in forum Centrafuse
    Last Post: 06-23-2005, 10:35 PM
  4. request: voice control for videos
    By ryguy in forum Centrafuse
    Last Post: 06-09-2005, 01:04 AM
  5. Replies: 22
    Last Post: 08-13-2001, 01:42 PM
