Page 46 of 58 FirstFirst ... 363738394041424344454647484950515253545556 ... LastLast
Results 451 to 460 of 575
Thread: Integrated voice control in RR...
  1. #451
    Mar 2005
    Sweden/Vaxjo
    Quote Originally Posted by whodwho View Post
    With helping with this particular scenario instead of using "volume up" multiple times use "volume sixty percent"
    Let me know if any of this helps
    Thanks... didnt even know that existed... will try that one later...
    So I shouls just skip the mic volume autoconfig thingy and set it to some lvl I think works... and then adjusting it..?
    Will try that 2 later... thanks for the help
    Swedish site for CarPC's
    http://www.bilpc.info
  2. #452
    Nov 2005
    Quote Originally Posted by Naesstrom View Post
    Today I noticed one more thing.. I have done all the training lessons available and have noticed one strange thing...
    Most of the time whe Boris don't get me he just says "now playing playlist" and jumps to song 21... is there any way to turn this off?
    Quote Originally Posted by Sonicxtacy02
    that is the MOST annoying thing! All the other mishaps are ok, but i'd say 75% of the time there's an error interpreting commands it jumps somewhere in the playlist.
    I have not had this happen and is the first time I have been approached on it.
    I will have to look into this one
    Sonicxtacy02 - did you get passed the hotkey issue?
  3. #453
    Nov 2005
    I am not seeing any autoconfig mic volume, only a microphone boost. There is a auto input that I beleive is the selection of microphone?
    I should of mentioned that there are commands set for 10 -100 percent volume not just the sixty and you can add additional if wanting a finer control:
    <P VALSTR="VOL+">master volume up</P>
    <P VALSTR="VOL-">master volume down</P>
    <P VALSTR="SETVOL;master;10">volume ten</P>
    <P VALSTR="SETVOL;master;20">volume twenty</P>
    <P VALSTR="SETVOL;master;30">volume thirty</P>
    <P VALSTR="SETVOL;master;40">volume fourty</P>
    <P VALSTR="SETVOL;master;50">volume fifty</P>
    <P VALSTR="SETVOL;master;60">volume sixty</P>
    <P VALSTR="SETVOL;master;70">volume seventy</P>
    <P VALSTR="SETVOL;master;80">volume eighty</P>
    <P VALSTR="SETVOL;master;90">volume ninety</P>
    <P VALSTR="SETVOL;master;100">volume one hundred</P>
    <P VALSTR="SETVOL;master;100">volume max</P>
  4. #454
    Mo' Programming Mo' Problems
    Sonicxtacy02's Avatar
    Woodbridge, VA
    Blog Entries
    55
    havent had the opportunity to test the title bar as discussed in pm. I will try it and let you know. I"m pretty sure that the reason the playlist is doing that is related to my problem. I'll do it today or tomorrow n let you know.
    Live mp3Car Facebook Chat
  5. #455
    Mar 2005
    Sweden/Vaxjo
    So do I need to add this or will it work without it?
  6. #456
    Nov 2005
    Those are currently in there, if you needed a finer control you could add 5,15,25, etc or just go with "volume fifty percent" and a couple "master volume up"
  7. #457
    Mar 2005
    Sweden/Vaxjo
    hmm... This is what I have with volume in it, and the row above and below
    Code:
         <P VALSTR="F11">full screen</P>
         <P VALSTR="PAUSE">pause</P>
    Do I have a to old version, didnt get the version numbering on the first post...
  8. #458
    Nov 2005
    Code:
    You are right, those are only in the last version (5-25) I would use the 5-02 version (dll) with the commands.xml and commands.cfg from the 5-25 version (5-25 has an issue I beleive)
    I need to get my drive and dev enviorment back together (drive crash) and get crackin on some coding again.
  9. #459
    Woodbridge, VA
    Blog Entries
    55
    good news ... I sorted out my problems. I reinstalled the soundcard driver and things are working as they should. Just have one more question. Is it possible to adjust the settings so that i press the hotkey and only ONE command is sent thru before the hotkey is needed again. I'm running into the problem now that when i press the hotkey, send a command, the command is completed then the ambient noises are making other commands happen
  10. #460
    Nov 2005
    Quote Originally Posted by Sonicxtacy02 View Post
    That is good news! You can try to shorten the timer value 'KeywordTimeout='
    Let me know if that helps
  1. Recommendations : Voice Control
    By wolfebaine in forum Input Devices
    Last Post: 01-03-2006, 06:05 PM
  2. SpeakEasy Voice Recognition - Release 0.9.2
    By ruairi in forum Software & Software Development
    Last Post: 11-22-2005, 04:29 PM
  3. Voice control
    By Cheekz185 in forum Centrafuse
    Last Post: 06-23-2005, 11:35 PM
  4. request: voice control for videos
    By ryguy in forum Centrafuse
    Last Post: 06-09-2005, 02:04 AM
  5. Replies: 22
    Last Post: 08-13-2001, 02:42 PM
