Page 49 of 58 FirstFirst ... 3940414243444546474849505152535455565758 LastLast
Results 481 to 490 of 575
Thread: Integrated voice control in RR...
  1. #481
    May 2007
    Kate does not work
    Quote Originally Posted by JagPuter View Post
    CLick on this link and you can get a good demo for comparison of the voices
    http://www.digitalfuturesoft.com/tex...ferer=adwords1
    I'm using Kate ffrom NeoSpeach as my text to speech voice. This is the best computer generated voice I've heard so far. This voice was so good my wife didn't know at first that it was computer generated. Problem is, I can't get it to work with voice command. If I change the speaker to the default Sam, then I hear speech. I change it back to Kate and nothing. I am using the Office 2003 Speech recognition and everything else works fine. Thanks for your help,
    Darin
  2. #482
    Aug 2006
    Anyone know how/where to get new voices?
    I've been looking at the AT&T Natural Voices and they sound pretty good. Is there a way to get these (or something similar) compatible with the Microsoft SDK Speech recognition?
    If so, how/where would I install them?
    Thanks!
  3. #483
    Jul 2006
    Line Volume issue
    Hey all...I got the voice control setup and working pretty well but I have my Sirius connected to my Line in and when I go to issue a command the voice control software doesn't mute the line in like it does with audio mode. Do I have to change the mastervol setting the rr.ini or is there something else I can do ?
    Thanks in advance.
    UPDATE:
    I acquired the AT&T Natural Voice Crystal and installed it then selected it in the Speech setup and it works great and sounds SO much better. I then used autohotkey to detect if the Line Volume indicator is on and if it's not I just send F10 key, just so the MIC isn't on all the time, then I used the PS3 wireless keyboard I read about in another post and bound it to a key. Now I'm just adding commands and it's working out great and sounds great!
  4. #484
    Newbie Niob's Avatar
    May 2007
    Norway
    Quote Originally Posted by whodwho View Post
    This entry allows media commands when it is not in command mode. It will allow you to "stop music", "pause music", "resume music", "play next", "play previous"
    Hi.
    I love your job. But this is my issue that hawe forsed me to stop using it (dissabled it from starting) as i actually cant hawe it on. It does random kommands when i play music or talk to friends in the car. Al is media related commands that i can not find i the list. The most common is "play first" or "playlist first" i think the command is. So i serarch the forums after info. Then i se the post i am replying to here. But i hawe in the "Voice.ini" file te line "allowMediaCmds=False" so then it should not do this? newest version i am able to find is "test_Version_05-25"
    besides this issue. its werry fun playing with it and showing of to friends They all get impressed when i tell the pc to start playing a dvd in the back for later bringing up the navigation system in the front. And give it some vocabulary so i can give an ipression of talking "with" the computer. And they all smiles when i say thank you and it replay with some nice vords back
    Edit:I want it to only listen for keyword. Not do things like this without giving the keyword first (Ands sorry for lousy english from my side).
  5. #485
    Jun 2006
    Simi Valley, CA
    This software works awesome. I am having a problem though, when on my desktop everything works great, but in the car with the same settings the following happens:
    with out road runner open the mic works fine and i can hear my self talk into it, but when road runner opens it mutes the mic so i cannot call out commands.
    any idea if this is a simple setting in the rr.ini?
    thanks guys! awesome work
  6. #486
    Confusion Master
    Enforcer's Avatar
    Sep 2003
    Have a look in rrconfig to see what your setting for 'Map Master Volume to Control Linefor weak sound cards) is set to. Should be just Master and not all.
  7. #487
    May 2007
    Norway
    Quote Originally Posted by joey View Post
    If you use PhoCo. I would check that one to. As there is a "mute mic" settings in it.
  8. #488
    Jun 2006
    Simi Valley, CA
    Thanks Enforcer and Niob, I messed with it some more and got it to work. I think it had something to do with my audigy card and its software getting confused. I had also installed office 2003 to use 6.1 instead of the SDK, not sure if that fixed the issue...
    The only thing im having trouble with is iGuidance. When I go to the GPS screen and call out say "Zoom out" it repeats it back but the screen flashes real quick and the command doesn't work. I am using IG 3.0 with the newest version of DigitalFX.
    Also when im at the GPS screen and want to call out for address do i just say address or do I have to say iguidance > destination > address?
  9. #489
    Maximum Bitrate jonessc's Avatar
    Nov 2006
    Wales, UK
    Quote Originally Posted by hoodlum View Post
    When I say computer it hears me, but from that point on it doesnt. Just ignores me. in "hypothesis" i see -1-computer and thats it.
    is it possible to play a wav file when the microphone is activated? so that you know is listening for an input?
    thanks
    CarPuter Progress:
    Planning:-----> [||||||||||] 100%
    Hardware Buying:-> [||||||||||] 100%
    Software:-----> [||||||||||] 100%
    Installing:-----> [||||||||||] 100%
    Current Project= Making skins in photoshop...
  10. #490
    May 2007
    Norway
    Quote Originally Posted by jonessc View Post
    thanks
    It doesn't play a .wav file. But it should respond on triggerword. Mine does. The code in "voice.ini" for this looks like this...
    Code:
    [KeywordReplies]
    Reply0=Speak!
    Reply1=What's Up!
    Reply2=Here!
    Reply3=Ready!
    Reply4=Yes?
    Edit: Or did you think about after you mut/un-mute mic by button? If so. I dont know howto or if possible at this time
  1. Recommendations : Voice Control
    By wolfebaine in forum Input Devices
    Last Post: 01-03-2006, 05:05 PM
  2. SpeakEasy Voice Recognition - Release 0.9.2
    By ruairi in forum Software & Software Development
    Last Post: 11-22-2005, 03:29 PM
  3. Voice control
    By Cheekz185 in forum Centrafuse
    Last Post: 06-23-2005, 10:35 PM
  4. request: voice control for videos
    By ryguy in forum Centrafuse
    Last Post: 06-09-2005, 01:04 AM
  5. Replies: 22
    Last Post: 08-13-2001, 01:42 PM
