Hi Guys
well does any 1 control RR with NAVI
My navi works fine with frodo ( almost all commands ) but with RR it simply wont go any where...
Can some i help pls
thanks
I had this working fine in my house, but as soon as I moved the computer to the car, it stopped working. When RR starts up, it no longer says "Voice Control Ready" or whatever it use to say. I know my mic works because the windows training hears my voice easily. I tried downloading the files again and also made sure I had UseVoiceControl=true but it still doesn't work. Any ideas?
Hi Guys
Can some i help pls
thanks
Commell LV-677 DC 6 x 6" Mother Board
2.6 GHz; 1 Gb Ram
120 Gb Laptop HD
7" InDash Xenarc MTD - X7000 Screen
Gyration Mouse ; GPS Mouse ; ELM Scan ; TPMS
Parrot MK 6000 & iPhone
Re done the carputer...Into the Glove Box !!
Hey Gang,
Is there a command to turn the mic on/off? I want to send a command via girder to do so and "mic" doesn't seem to do the trick.
Nasa
Is anybody still working on this or is it a dead project now ?
This is very nice project! Please don't stop updating it...
BTW, can I make it not to stop the music when the computer is speaking?![]()
I want it to lower the music's volume to -let's say- 20%, but not stop it.
Also, can I make it not to say the menu's name upon entering in a menu?
Example, when I get into Audio player, it says "Music". I don't want this. What can I do?
You can override the "text" names by adding exectbl.ini entries like:
"AUDIO","LOAD;audio_player.skin;<MY TEXT>"
and so on.. the voices will not speak by default if you are already playing music, but if you want to disable speaking altogether, simply set voice=false in RR.INI.
Ride Runner RR's Myspace
Can anyone make a 'Grammer Builder' like PowerVoice uses?
I believe this is just an app that powervoice uses to edit/create/delete values from the XML command file.
But its a lot easier to use/view than looking directly at an XML file. It shows heirarchy quite neatly too
J!
Thanks guino, I'll try it!You can override the "text" names by adding exectbl.ini entries like:
It works, thank you![]()
