Page 53 of 58 FirstFirst ... 343444546474849505152535455565758 LastLast
Results 521 to 530 of 575
Thread: Integrated voice control in RR...
  1. #521
    Jan 2007
    Greece
    How can we change the values of the voicecommand.dll file?
    I want to change the verification command "Did you say......?" with something else.
    I tryied PE Explorer and found that part, but i can't change it.
    Any help on that?
  2. #522
    Sep 2007
    Please forgive me but could you tell me where is the instruction on how to integrate voice into RR with DFX skin? I know I saw it somewhere last week but I've been searching for 30 minutes but could not find it.
  3. #523
    Jan 2007
    Greece
    Quote Originally Posted by sonvan View Post
    OK
    1)Open RRConfig and check the "Use build-in voice control" command. I think it's in page 3.
    2)Open this http://www.mp3car.com/vbulletin/atta...trol_05-02.zip and extract all the files in your RoadRunner's directory (where RRConfig.exe, RoadRunner.exe are, etc)
    3)Read the AvailableCommands.doc to learn what to say
    4)I suppose you have MS Speech installed.
  4. #524
    Nov 2006
    Need some help
    So, I started playing with voice control... downloaded everything. Open RR and it says Voice control ready. I say "Computer" and it says listening or whatever, but then I say "Audio" or "Iguidance" or anything, and nothing happens. What are the commands? Or why is this not working? Thanks.
  5. #525
    Maximum Bitrate Injector's Avatar
    Mar 2005
    Rockledge, FL
    Quote Originally Posted by synonomous18 View Post
    look in the files you extracted there is a word documents with all the commands, and read the readme file
  6. #526
    Jun 2006
    DuPont, WA
    This is working well for me in the default configuration, using the "computer" keyword. But now I'm trying to use a button on my skin as a hotkey and am having all kinds of trouble. Here's the key parts of my .ini:
    [Program]
    KeyWord=
    RepeatCommand=True
    ReplyOnKeyword=True
    AlwaysOnTop=True
    ShowDetails=True
    UseKeyword=True
    useHotKey=True
    Hotkey_Keyword=VK_F10
    KeywordTimeout=5
    PauseTimeout=5
    First of all, I can press F10 on a keyboard and trigger the hotkey, but my button doesn't seem to do anything. Is there something wrong with this syntax... ?
    B00,20,519,72,82,"SENDKEY;{F10}",""
    Secondly, after each verbal command, it still goes to waiting for a keyword for a few seconds before switching to waiting for a hotkey. I tried setting UseKeyword=false, but then it doesn't wait for a hotkey at all??
    Any ideas?
  7. #527
    Constant Bitrate notion's Avatar
    May 2002
    San Diego, CA
    Are there any known incompatibilities with this?
    I just installed and I get the "ready" command but the system seems heavily loaded or looping, I see my flash clock on the main menu screen stopping for 5 seconds or so at a time, starting and then stopping again.
    Any help appreciated.
    350z Roadster,
    Lilliput 7" touch, Opus 250w, 160gb, AMD3500+, 1gb ddr400, geforce 6500 pcie, SiRF Star 3, Wireless G, Sprint CDMA, Bluetooth, Creative iCam Pro, RR, iG 4, Digital FX 4.0
  8. #528
    Jun 2006
    DuPont, WA
    Quote Originally Posted by jeffw View Post
    I solved this problem by using AutoIt to send the F10, and called the AutoIt script from the button.
  9. #529
    Jun 2006
    DuPont, WA
    Quote Originally Posted by notion View Post
    I've been running voice control on 3 different systems ranging from an old P4, to a centrino laptop, to my Core Duo car pc, and have seen practically 0 CPU utilization by RR and voice control in all cases (when they are idle). Is there anything unique about your setup? Try pulling up Task Manager and sort by CPU to see which process is consuming all the cycles. That might shed some light on the culprit. i.e. is it RoadRunner.exe or sapisvr.exe?
  10. #530
    May 2002
    San Diego, CA
    Yup a quick reboot took care of it, I hadn't rebooted since installing all the speech stuff but now it's working just fine. Lot's of fun to play with, not sure how well it will work with my convertible lol.
    Thanks for this.
    350z Roadster,
  1. Recommendations : Voice Control
    By wolfebaine in forum Input Devices
    Last Post: 01-03-2006, 06:05 PM
  2. SpeakEasy Voice Recognition - Release 0.9.2
    By ruairi in forum Software & Software Development
    Last Post: 11-22-2005, 04:29 PM
  3. Voice control
    By Cheekz185 in forum Centrafuse
    Last Post: 06-23-2005, 11:35 PM
  4. request: voice control for videos
    By ryguy in forum Centrafuse
    Last Post: 06-09-2005, 02:04 AM
  5. Replies: 22
    Last Post: 08-13-2001, 02:42 PM
